    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 548.5k Views 153 Watching
      shnash
      I have downloaded your program sketchy FFD and have put it in the plugins folder. I see it in sketchup when i right click but when i apply it to a group i do not see the update ffd option. can u please tell me wot I'm doing wrong? thanks
        remus
        If youve got the latest version you shouldnt need the update option, it should do it automatically.
        • K
          kwistenbiebel
          Not always. as a matter of fact I would vote to get the 'update' button re-instated, just for the cases the auto-update doesn't work.
          • C
            CPhillips
            Yeah, the update menu option was removed when I figured out how to auto update. Ill remove it from the post.
            I can put it back. But I would rather fix the bug that keeps auto updating from working. Can you send me a model that the FFD doesn't auto update I might be able to figure it out.
              andrew1184
              Wonderful plugin, thank you very much. If I do anything useful I'll try to upload it . . .
                aby
                cheer man u are rockin
                for base users like me ur genius
                go on
                  REGIS
                  Hi CPhillips, it appears that your very great plugin doesn't work within google sketchup 7.
                  Any idea ?
                  Thanks in advance
                  cheers
                  • C
                    CPhillips
                    I'll post an updated version tonight.
                      sepo
                      Nice one Chris. Will the updated version be any different than previous and will it work with SU6?
                        REGIS
                        Thanks a lot CPhilips, I really enjoy your plugin.
                        cheers
                        • C
                          CPhillips
                          I just tried it out under SU7 (free version) and it seems to work ok. How is it failing for you?
                            REGIS
                            Hi the FFD menu doesn't appear in contextual menu.
                            cheers
                            • C
                              CPhillips
                              Are you sure you installed it in the right place. Should be in the plugins folder.
                              Can anyone else confirm it does or doesn't work with SU7?
                                johnsenior1973
                                FFD isn't appearing for me in SU7.
                                It's probably my fault for trying to copy the plugins straight from 6 to 7 though.
                                  johnsenior1973
                                  Downloaded it again and installed it. It's working for me now.
                                    REGIS
                                    downloaded and installed in google sketchup 7 plugins folder.
                                    Doesn't work
                                    cheers
                                      REGIS
                                      It works fine now.
                                      Thanks a lot.
                                      cheers
                                      • ToboboT
                                        Tobobo
                                        Chris,
                                        I can't get it to work.
                                        I an trying to bend the centre of the netting but when i move the control points there is no 'Update FFD' option on the right-click menu.
                                        I've posted the model so you can have a look and tell what i'm doing wrong.
                                        Thanks in advance.
                                        Netting.skp
                                        Toby
                                        Philippians 4:13
                                          REGIS
                                          Hi Tobobo
                                          It's due to the hidden geometry.
                                          Look at this one, it's different with the hidden geometry, you can easilly deform it where you want.
                                          Just create the group and choose your FFD setting.
                                          curtain.skp
                                          cheers
                                          Edit
                                          After some FFD
                                          curtainFFDv6.skp
                                          cheers
                                          • ToboboT
                                            Tobobo
                                            Thanks REGIS
                                            I'll have to think of another way to deform the netting.
                                            Toby
                                            Philippians 4:13
                                            • 11
                                            • 20
                                            • 21
                                            • 9 / 21
