    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 548.5k Views 153 Watching
      REGIS
      Hi Tobobo
      It's due to the hidden geometry.
      Look at this one, it's different with the hidden geometry, you can easilly deform it where you want.
      Just create the group and choose your FFD setting.
      curtain.skp
      cheers
      Edit
      After some FFD
      curtainFFDv6.skp
      cheers
      • ToboboT
        Tobobo
        Thanks REGIS
        I'll have to think of another way to deform the netting.
        Toby
        Philippians 4:13
          REGIS
          Perhaps ypu can subdvide it using subdivide=true when you create your FFD control box.
          Cheers
            SKELL
            I am trying to take a simple rectangular solid and deform it. i have to sub divide the surface? how can i go about this?
            Thanks,
            -Tony
              One possibility
              Draw a rectangle
              Pull it with Ctrl any time you want
              Select all (triple click)
              Move it one time + CTRL = Copy
              Type "10*" (or more) = Multiple
              Group it
              Select group Right Click / FFD
              Edit the goup "FFD"
              Move points
              Et voilà 😉
              rec.skp
                michaelland
                Hi Chris, I've to say your work for this amazing RB is really great help for me! Thanks for your great job and sharing with us!!
                Michael Xie
                • B
                  BTM
                  Thanks,
                  -Tony
                  There's a subdivide feature in the script.right click> FFD> NxN> set subdivide to true.
                    Yes but will be any effect on the subdivide of a simple rectangle!!!
                    Nothing will arrive when you will move a point of the FFD!
                    Seems the only easy methode is draw a rectangle with the Sandbox 😄
                      jonorman
                      Hi..
                      I think there might be a problem with FFD an ASGVIS V-ray for scetchup.. FFD did not work while i had V-ray installed but now that i have uninstalled V-ray FFD works fine again.. Same problem as with subdivide and smooth script..
                      can anyone else confirm this ?? Btw, FFD is a brilliant script. 👍
                      • G
                        GJV
                        woooaaaa
                        amazing plugin
                        just what I needed
                        thanx a lot 😄 !!!!
                          Dee256
                          Works nice! But "transformations reset" needs sometimes before FFD starts.
                          • I
                            ideas_arte
                            .. thanks a million!
                            really useful too 👍
                            • N
                              niarfe
                              this looks like a wonderful ruby!!!
                              too bad it's not working for me, it doesn't do anything, and when I try undoing it beaks my geometry apart!
                              would have loved to use it 😞
                              • Chris FullmerC
                                Its not over yet. If its not working, then its installed wrong or your using it wrong. Or you have version 4 of SU 😄
                                Could you provide a better description of what its doing wrong? Perhaps screenshots, maybe a video. Just give us some more detail and we'll get it working for you.
                                  sprezzaturon
                                  I'm running Sketchup 7 and just added your FFD tool. I can move points but there is no 'update FFD' option when I'm finished. Is FFD not compatible with Sketchup 7?
                                    remus
                                    The shape should update automatically, you might have to give it a bit of time, though.
                                    If that doesnt work delete the control points, explode the group, regroup and try again.
                                      sprezzaturon
                                      After waiting on a 2.4 GHz dual core XP system, nothing changed. I've just installed FFD on my computer (2.1 GHz dual core) and created a circle so I could elongate one point. Nothing. This is disappointing.
                                        remus
                                        Have you tried it on 3d geometry? i think it can work on 2d things, but ive never gotten the hang of it.
                                        • H
                                          hasan
                                          @cphillips said:
                                          I can't get this script to work. Nothing happens.
                                          I create a sphere, group it, right-click and do 3x3 FFD, enter the new group with Construction Points, move some to another position, exit the group, right-click the sphere group and choose Update FFD. Nothing happens.
                                          Can you open the ruby console and see if it is printing any errors?
                                            steven-arts
                                            Hi Chriss,
                                            it really makes fun to work with FFD! I looked at your code and found the factorial function where you mentioned to encrease performance by adding a table for factorials. I made it dynamic and it boosts your code! Just replace the section with:
                                            #used by calcBernstein. could be replaced by a table since in
                                            #this application n is never more than 3 (number of control points).
                                            $fTable = []
                                            def factorial(n)
                                                sum = $fTable.rassoc(n)
                                                if sum
                                                	return sum[0]
                                                else
                                            	sum = 1
                                            	sum.upto(n) { |i| sum *= i }
                                            	$fTable << [sum, n]
                                            	return sum
                                            Ciao, Stefan
                                            • 11
                                            • 12
                                            • 20
                                            • 21
                                            • 10 / 21
