    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 528.7k Views 153 Watching
      REGIS
      Hi CPhillips, it appears that your very great plugin doesn't work within google sketchup 7.
      Any idea ?
      Thanks in advance
      cheers
        CPhillips
        I'll post an updated version tonight.
          sepo
          Nice one Chris. Will the updated version be any different than previous and will it work with SU6?
            REGIS
            Thanks a lot CPhilips, I really enjoy your plugin.
            cheers
              CPhillips
              I just tried it out under SU7 (free version) and it seems to work ok. How is it failing for you?
                REGIS
                Hi the FFD menu doesn't appear in contextual menu.
                cheers
                  CPhillips
                  Are you sure you installed it in the right place. Should be in the plugins folder.
                  Can anyone else confirm it does or doesn't work with SU7?
                    johnsenior1973
                    FFD isn't appearing for me in SU7.
                    It's probably my fault for trying to copy the plugins straight from 6 to 7 though.
                      johnsenior1973
                      Downloaded it again and installed it. It's working for me now.
                        REGIS
                        downloaded and installed in google sketchup 7 plugins folder.
                        Doesn't work
                        cheers
                          REGIS
                          It works fine now.
                          Thanks a lot.
                          cheers
                          • ToboboT Offline
                            Tobobo
                            Chris,
                            I can't get it to work.
                            I an trying to bend the centre of the netting but when i move the control points there is no 'Update FFD' option on the right-click menu.
                            I've posted the model so you can have a look and tell what i'm doing wrong.
                            Thanks in advance.
                            Netting.skp
                            Toby
                            Philippians 4:13
                              REGIS
                              Hi Tobobo
                              It's due to the hidden geometry.
                              Look at this one, it's different with the hidden geometry, you can easilly deform it where you want.
                              Just create the group and choose your FFD setting.
                              curtain.skp
                              cheers
                              Edit
                              After some FFD
                              curtainFFDv6.skp
                              cheers
                              • ToboboT Offline
                                Tobobo
                                Thanks REGIS
                                I'll have to think of another way to deform the netting.
                                Toby
                                Philippians 4:13
                                  REGIS
                                  Perhaps ypu can subdvide it using subdivide=true when you create your FFD control box.
                                  Cheers
                                    SKELL
                                    I am trying to take a simple rectangular solid and deform it. i have to sub divide the surface? how can i go about this?
                                    Thanks,
                                    -Tony
                                      One possibility
                                      Draw a rectangle
                                      Pull it with Ctrl any time you want
                                      Select all (triple click)
                                      Move it one time + CTRL = Copy
                                      Type "10*" (or more) = Multiple
                                      Group it
                                      Select group Right Click / FFD
                                      Edit the goup "FFD"
                                      Move points
                                      Et voilà 😉
                                      rec.skp
                                        michaelland
                                        Hi Chris, I've to say your work for this amazing RB is really great help for me! Thanks for your great job and sharing with us!!
                                        Michael Xie
                                          BTM
                                          Thanks,
                                          -Tony
                                          There's a subdivide feature in the script.right click> FFD> NxN> set subdivide to true.
                                            Yes but will be any effect on the subdivide of a simple rectangle!!!
                                            Nothing will arrive when you will move a point of the FFD!
                                            Seems the only easy methode is draw a rectangle with the Sandbox 😄
                                            • 11
                                            • 20
                                            • 21
                                            • 9 / 21
