    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 540.5k Views 153 Watching
      REGIS
      Thanks a lot CPhilips, I really enjoy your plugin.
      cheers
      • C
        CPhillips
        I just tried it out under SU7 (free version) and it seems to work ok. How is it failing for you?
          REGIS
          Hi the FFD menu doesn't appear in contextual menu.
          cheers
          • C
            CPhillips
            Are you sure you installed it in the right place. Should be in the plugins folder.
            Can anyone else confirm it does or doesn't work with SU7?
              johnsenior1973
              FFD isn't appearing for me in SU7.
              It's probably my fault for trying to copy the plugins straight from 6 to 7 though.
                johnsenior1973
                Downloaded it again and installed it. It's working for me now.
                  REGIS
                  downloaded and installed in google sketchup 7 plugins folder.
                  Doesn't work
                  cheers
                    REGIS
                    It works fine now.
                    Thanks a lot.
                    cheers
                    • ToboboT
                      Tobobo
                      Chris,
                      I can't get it to work.
                      I an trying to bend the centre of the netting but when i move the control points there is no 'Update FFD' option on the right-click menu.
                      I've posted the model so you can have a look and tell what i'm doing wrong.
                      Thanks in advance.
                      Netting.skp
                      Toby
                      Philippians 4:13
                        REGIS
                        Hi Tobobo
                        It's due to the hidden geometry.
                        Look at this one, it's different with the hidden geometry, you can easilly deform it where you want.
                        Just create the group and choose your FFD setting.
                        curtain.skp
                        cheers
                        Edit
                        After some FFD
                        curtainFFDv6.skp
                        cheers
                        • ToboboT
                          Tobobo
                          Thanks REGIS
                          I'll have to think of another way to deform the netting.
                          Toby
                          Philippians 4:13
                            REGIS
                            Perhaps ypu can subdvide it using subdivide=true when you create your FFD control box.
                            Cheers
                              SKELL
                              I am trying to take a simple rectangular solid and deform it. i have to sub divide the surface? how can i go about this?
                              Thanks,
                              -Tony
                                One possibility
                                Draw a rectangle
                                Pull it with Ctrl any time you want
                                Select all (triple click)
                                Move it one time + CTRL = Copy
                                Type "10*" (or more) = Multiple
                                Group it
                                Select group Right Click / FFD
                                Edit the goup "FFD"
                                Move points
                                Et voilà 😉
                                rec.skp
                                  michaelland
                                  Hi Chris, I've to say your work for this amazing RB is really great help for me! Thanks for your great job and sharing with us!!
                                  Michael Xie
                                  • B
                                    BTM
                                    Thanks,
                                    -Tony
                                    There's a subdivide feature in the script.right click> FFD> NxN> set subdivide to true.
                                      Yes but will be any effect on the subdivide of a simple rectangle!!!
                                      Nothing will arrive when you will move a point of the FFD!
                                      Seems the only easy methode is draw a rectangle with the Sandbox 😄
                                        jonorman
                                        Hi..
                                        I think there might be a problem with FFD an ASGVIS V-ray for scetchup.. FFD did not work while i had V-ray installed but now that i have uninstalled V-ray FFD works fine again.. Same problem as with subdivide and smooth script..
                                        can anyone else confirm this ?? Btw, FFD is a brilliant script. 👍
                                        • G
                                          GJV
                                          woooaaaa
                                          amazing plugin
                                          just what I needed
                                          thanx a lot 😄 !!!!
                                            Dee256
                                            Works nice! But "transformations reset" needs sometimes before FFD starts.
                                            • 11
                                            • 12
                                            • 20
                                            • 21
                                            • 10 / 21
