    Problema na instalação ERROR_A04
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    extensions
    32 Posts 6 Posters 141 Views 6 Watching
    • G Online
      Gábor
      The issue has been solved via private emailing.
      • G Gábor has marked this topic as solved on
      • N Offline
        nataliaseraos @Gábor
        @Gábor Hello! I'm having the same problem as Andre, and I've tried all the options suggested earlier to fix it. Even reinstalled sketchup and it keeps happening. Errors B03 ans A_04. Can you help me, please?
        G 1 Reply Last reply Reply Quote 0
        • G Online
          Gábor @nataliaseraos
          @nataliaseraos Could you send me your signature file (Filename: SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt) and the name of your computer in private? I send you my email address by chat.
          • G Offline
            gna young Newcomers
            Hello! I'm having the same problem as Andre, and I've tried all the options suggested earlier to fix it. Even reinstalled sketchup and it keeps happening. Errors B03 ans A_04. Can you help me, please? e-mail : gna-khy@naver.com
            • G Offline
              gna young Newcomers @Gábor
                @Gábor needs to become involved...
                but these error messages relate to issues with your licensing file - e.g. your Computer's name contains non-ASCII characters that can't be decoded or your User-name is similarly badly formed...
                  Rich O Brien Moderator @gna young
                  @gna-young said in Problema na instalação ERROR_A04:
                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                  • G Offline
                    gna young Newcomers @Rich O Brien
                    @Rich-O-Brien
                    Fredo6 Plugins Information on 2025-02-06 15:21:58 +0900
                    • Platform: x64-mswin64_140 - Ruby: 3.2.2
                    • Sketchup: 24.0.594
                    • LibFredo6: v15.0a
                    • LibFredo6 Binary loaded
                    • Sketchucation ExtensionStore: 4.4.1
                    • SCFLicense: v6.4a - 74
                    • Fredo6 Plugins
                      FredoScale v3.6a
                    • SCFLicense directory present
                      Signature File: 2025-02-05 17:43:55 +0900
                    • LibFredo6: v15.0a
                    • Fredo6 Plugins
                      FredoScale v3.6a
                    Error: #<SyntaxError:"(eval):2: syntax error, unexpected integer literal, expecting end-of-input\n...ns Information on 2025-02-06 15:21:58 +0900\n... ^~\n">
                    SketchUp:in `eval'
                    => nil
                      @gna-young
                      Please delete SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file in C:\Users\SomeName\AppData\Local\SCF Licenses
                      Restart SketchUp
                      If you device has special characters please rename it using only alphanumeric characters.
                      • G Offline
                        @Rich-O-Brien I finally solved it~ I was stressed out for two days, but I finally solved it~ I was stressed out for two days, but thank you so much for solving this problemthank you so much for solving this problem
                        TIGT 1 Reply Last reply Reply Quote 1
                          No probs. Glad its sorted for you
                            TIG Moderator @gna young
                            @gna-young
                            What was your solution ? [for other members who might have similar issues]
                            • 2 / 2
