    Problema na instalação ERROR_A04
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    extensions
    37 Posts 6 Posters 5.1k Views 6 Watching
    • G
      gna young Newcomers
      Hello! I'm having the same problem as Andre, and I've tried all the options suggested earlier to fix it. Even reinstalled sketchup and it keeps happening. Errors B03 ans A_04. Can you help me, please? e-mail : gna-khy@naver.com
      • G
        gna young Newcomers @Gábor
        @Gábor Hello! I'm having the same problem as Andre, and I've tried all the options suggested earlier to fix it. Even reinstalled sketchup and it keeps happening. Errors B03 ans A_04. Can you help me, please?
          @Gábor needs to become involved...
          but these error messages relate to issues with your licensing file - e.g. your Computer's name contains non-ASCII characters that can't be decoded or your User-name is similarly badly formed...
            Rich O Brien Moderator @gna young
            @gna-young said in Problema na instalação ERROR_A04:
            Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
            G 1 Reply Last reply
            • G
              gna young Newcomers @Rich O Brien
              @Rich-O-Brien
              Fredo6 Plugins Information on 2025-02-06 15:21:58 +0900
              • Sketchup: 24.0.594
              • LibFredo6: v15.0a
              • LibFredo6 Binary loaded
              • Sketchucation ExtensionStore: 4.4.1
              • SCFLicense: v6.4a - 74
              • Fredo6 Plugins
                FredoScale v3.6a
                Signature File: 2025-02-05 17:43:55 +0900
              • LibFredo6: v15.0a
              • Fredo6 Plugins
                FredoScale v3.6a
              Error: #<SyntaxError:"(eval):2: syntax error, unexpected integer literal, expecting end-of-input\n...ns Information on 2025-02-06 15:21:58 +0900\n... ^~\n">
              SketchUp:in `eval'
              => nil
                @gna-young
                Please delete SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file in C:\Users\SomeName\AppData\Local\SCF Licenses
                Restart SketchUp
                If you device has special characters please rename it using only alphanumeric characters.
                G 2 Replies Last reply
                • G
                  @Rich-O-Brien I finally solved it~ I was stressed out for two days, but I finally solved it~ I was stressed out for two days, but thank you so much for solving this problemthank you so much for solving this problem
                  TIGT 1 Reply Last reply
                    No probs. Glad its sorted for you
                      TIG Moderator @gna young
                      @gna-young
                      What was your solution ? [for other members who might have similar issues]
                      • G
                        @Rich-O-Brien
                        I purchased a paid license for FredoScale and am currently using it on one computer, but I keep getting errors when I try to install it on another computer. Could you please help me resolve this?
                        I already deleted everything and reinstalled it.
                        The error codes keep appearing alternately as 02, 03, and 04.!
                          The B errors relate to license file issues.
                          Rich will comment in detail.
                          Have you copied the .license files over to your new PC ?
                          Have you tried activating the license [green button] ?
                          Have you logged in and checked your used licenses under the SketchUcation.. PluginStore > My Licenses page ?
                            The errors are all signature file related. It might be that SketchUp does not have read/write permissions.
                            You can fix that by repairing SketchUp's installation.
                            Download the SketchUp installer. Right click the .exe and choose Run as Admin nd when prompted choose Repair.
                            • G
                              gna young Newcomers @TIG
                              @TIG I tried it with a license, but if I go back in, I get the same 03 error message. And only 1 out of 3 people used my page's license. Is there a way to give permission to the computer I'm going to use now?
                                Have you got the latest versions of the extensions and SketchUcation toolset ? This is needed to manage the licenses effectively.
                                Have you tried the forums 'My Licenses' page in the PluginStore, or perhaps easier to use, the page accessed from the ExtensionStore dialog's 'Quick Menu' called 'Licenses' both of which let you manage your licenses Release/Activate etc...
                                • 2 / 2
