    Problema na instalação ERROR_A04
    Scheduled Pinned Locked Moved Solved Extensions & Applications Discussions
    extensions
    37 Posts 6 Posters 4.6k Views 6 Watching
      Rich O Brien Moderator @Andre Zucco
      @Andre-Zucco
      Have you tried on another device?
      Unless @TIG or @Gabor have further ideas?
      A 1 Reply Last reply
        Andre Zucco @Rich O Brien
        @Rich-O-Brien Não tentei, mas gostaria muito de resolver esse problema, os pligins me fazem muita falta.
        Pensei que o problema talvez estivesse relacionado com a minha conta na sketchucation, ou outra possibilidade seria as relacionado a permissões, algo que estivesse bloqueando a conexão do plugin com a internet para realizar o download e ativar as licenças.
          @Andre-Zucco I agree. A fix would be the best solution.
          In 2022 you activated Roundcorner
          Is this still working?
          When you activate now you still get A04 error?
            @Rich-O-Brien todos eles funcionavam antes de trocar de notebook, agora eu recebo a mensagem que o período de teste expirou e pede para validar a licença, quando vou validar a licença da o erro A04.
            Teria como excluir essa conta e todos seus registros para posterior fazer uma nova conta e liberar os plugins novamente?
              @Andre-Zucco Deleting an account is unnecessary.
              All info points to an issue between your signature file and the device.
              In particular the signature file is detecting a mismatch between the device name and what is on the signature file.
              This happens when someone migrates files from an older device or changes the device name.
              Deleting the signature file at C:\Users\SomeName\AppData\Local\SCF Licenses and restarting SketchUp should fix your signature issues.
              But from your replies this has not rectified it. This suggests there is something else that is causing instability.
              Hopefully @TIG @Gabor or even @fredo6 might have further options.
                @Rich-O-Brien, Obrigado, aguardamos o @TIG, @Gabor e @fredo6 nos ajudar.
                G 1 Reply Last reply
                • G
                  Gábor @Andre Zucco
                  @Andre-Zucco I write my email address via private chat to you. Could you please send me your signature file by email?
                  N 1 Reply Last reply
                  • G
                    Gábor
                    The issue has been solved via private emailing.
                    • G Gábor has marked this topic as solved on
                    • N
                      nataliaseraos @Gábor
                      @Gábor Hello! I'm having the same problem as Andre, and I've tried all the options suggested earlier to fix it. Even reinstalled sketchup and it keeps happening. Errors B03 ans A_04. Can you help me, please?
                      • G
                        Gábor @nataliaseraos
                        @nataliaseraos Could you send me your signature file (Filename: SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt) and the name of your computer in private? I send you my email address by chat.
                        • G
                          gna young Newcomers
                          Hello! I'm having the same problem as Andre, and I've tried all the options suggested earlier to fix it. Even reinstalled sketchup and it keeps happening. Errors B03 ans A_04. Can you help me, please? e-mail : gna-khy@naver.com
                          • G
                            gna young Newcomers @Gábor
                              @Gábor needs to become involved...
                              but these error messages relate to issues with your licensing file - e.g. your Computer's name contains non-ASCII characters that can't be decoded or your User-name is similarly badly formed...
                                Rich O Brien Moderator @gna young
                                @gna-young said in Problema na instalação ERROR_A04:
                                Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                                • G
                                  gna young Newcomers @Rich O Brien
                                  @Rich-O-Brien
                                  Fredo6 Plugins Information on 2025-02-06 15:21:58 +0900
                                  • Sketchup: 24.0.594
                                  • LibFredo6: v15.0a
                                  • LibFredo6 Binary loaded
                                  • Sketchucation ExtensionStore: 4.4.1
                                  • SCFLicense: v6.4a - 74
                                  • Fredo6 Plugins
                                    FredoScale v3.6a
                                    Signature File: 2025-02-05 17:43:55 +0900
                                  • LibFredo6: v15.0a
                                  • Fredo6 Plugins
                                    FredoScale v3.6a
                                  Error: #<SyntaxError:"(eval):2: syntax error, unexpected integer literal, expecting end-of-input\n...ns Information on 2025-02-06 15:21:58 +0900\n... ^~\n">
                                  SketchUp:in `eval'
                                  => nil
                                    @gna-young
                                    Please delete SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt file in C:\Users\SomeName\AppData\Local\SCF Licenses
                                    Restart SketchUp
                                    If you device has special characters please rename it using only alphanumeric characters.
                                    G 2 Replies Last reply
                                    • G
                                      @Rich-O-Brien I finally solved it~ I was stressed out for two days, but I finally solved it~ I was stressed out for two days, but thank you so much for solving this problemthank you so much for solving this problem
                                      TIGT 1 Reply Last reply
                                        No probs. Glad its sorted for you
                                          TIG Moderator @gna young
                                          @gna-young
                                          What was your solution ? [for other members who might have similar issues]
                                          • G
                                            @Rich-O-Brien
                                            I purchased a paid license for FredoScale and am currently using it on one computer, but I keep getting errors when I try to install it on another computer. Could you please help me resolve this?
                                            I already deleted everything and reinstalled it.
                                            The error codes keep appearing alternately as 02, 03, and 04.!
                                            • 2 / 2
