    Rayscaper New Releases
    rayscaperrender
    785 Posts 14 Posters 363.6k Views 15 Watching
    • pixelcruncherP
      Hey, Rayscaper users!
      Rayscaper 0.9.94 Beta is available. You can get it via:
      • The SketchUcation store.
      • Direct download: Rayscaper_Win_0.9.94_Beta.rbz.
      I recommend upgrading to the latest version.
      What Changed?
      • Fix occasional skewed or corrupted textures in renders.
      • Fix render failures when emissive materials are assigned to a group or component instance instead of directly to faces. (Cheers @krass for helping me find this bug!)
      Full release notes: rayscaper.com/manual/release-notes
      Help Me Build the Community 👍
      If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
      and helps me showcase its capabilities to new users.
      Follow me on X.
      Happy Rendering!
      Thomas
      • pixelcruncherP
        Rayscaper 0.9.95 Beta is available. You can get it via:
        • Direct download: Rayscaper_Win_0.9.95_Beta.rbz.
        What Changed?
        • Improve asset setup feedback. Rayscaper now shows the asset name during setup.
        • Improve asset download reliability. Large Poly Haven assets now use less memory and complete more reliably.
        • Add Max Transparent Depth render control for GI and Approx. GI. Increase it when layered transparent or opacity-based materials render black where several panes overlap.
        Follow me on X.
        Happy Rendering!
        Thomas
        KrassK 1 Reply Last reply
        • KrassK
          Krass @pixelcruncher
          @pixelcruncher
          Hello Thomas,
          An exercise using a previous client project with version 0.9.95.
          A 4K render at 3000 spp, taking 1 hour 44 minutes on an RTX 3060 GPU.
          Then downscaled to 1080p to use with GPT images for the characters (it’s a lot of work!).
          Followed by compositing the characters back onto my original Rayscaper render.
          I definitely messed up the glass on the pendant light, and forgot to finish the window view background...but I stayed honest and didn't ask ChatGPT to fix it! It’s a chandelier from 3D Warehouse, after all—naturally!
          raw RS 1080p render:
          alt text
          with characters:
          alt text
          Krass
          Reply Quote 2
          • pixelcruncherP
            That's actually a very nice use of classic rendering + AI. Thanks for sharing! Why not render directly in 1080p if you have to downscale it for use with AI?
            • KrassK
              Krass
              I hold the view that renders should always be generated at high resolution. I still believe that. It allows for error correction during post-production and adds details that you wouldn't get at low resolution. You also gain sharpness. However, I've noticed that using a high number of SPP doesn't make much of a difference. I think that's what you were saying.
              Krass
              • KrassK
                Krass
                And I feel compelled to emphasize—for users of true path-tracing renderers—that the denoiser really compromises image quality. You only have to test it yourself: even though Rayscaper’s denoiser is excellent, a 1080p render won't be particularly sharp or detailed. Paradoxically, simply increasing the render resolution actually saves time in the end; once displayed at a smaller size or downsampled, the result is far superior to simply increasing the samples per pixel (spp) at a lower resolution.
                Krass
                • KrassK
                  Krass
                  hello Pixelcruncher,
                  I tryied to edit a sketchup material of a shrub in photoshop and saved it, save the model and rayscaper did this. Any idea or solution? Thanjs
                  Krass
                  • pixelcruncherP
                    @krass - That means Rayscaper can't find the image after you edited it in Photoshop. Did you happen to save it under a different filename?
                    As a workaround, try reloading this material to see if it works.
                    I will have a fix in the next release, which will land shortly.
                    Regards,
                    Thomas
                    • KrassK
                      Krass
                      yes thanks Thomas, I made a copy ok the texture file in a other folder, and it works. It Keeps UV's
                      Krass
                      • KrassK
                        Krass
                        One of the options I’d like to have in Rayscaper is the ability to adjust the colors and values ​​of a photo texture for a PBR material.
                        Krass
                        • KrassK
                          Krass
                          the Hide assets function is great !
                          Krass
                          • KrassK
                            Krass
                            I set the HDRI map resolution to the maximum, but it's quite blurry.
                            Krass
                            • KrassK
                              Krass
                              I reloaded the HDRI from Polyhaven. Here are some views with the latest version of Rayscaper. For a bird's eye view chat GPT only produced the context, the background.
                              Krass
                              • pixelcruncherP
                                Rayscaper 0.9.96 Beta is available. You can get it via:
                                • Direct download: Rayscaper_Win_0.9.96_Beta.rbz.
                                I recommend upgrading to the latest version. This release is all about water and light 🌊💡
                                New: Water Material
                                Rayscaper now has a dedicated Water material for pools, ponds, lakes and spas. Assign it to a single face or a closed box, pick a preset, and you're done.
                                • Realistic waves: layered swell and fine ripples, with direction, size and strength controls.
                                • Depth you can see: water gets darker and more tinted as it gets deeper, so a pool's deep end actually looks deep.
                                • Controllable reflections: from crisp mirror-like water at sunset to soft, choppy reflections.
                                Clarity controls how far you can see into the water:
                                It ships with presets to get you started, including the new Tropical, Reflecting Pool and Spa.
                                New: IES Light Profiles for Spotlights
                                Spotlights can now use IES profiles for realistic, architectural light patterns: batwing, wall wash, narrow and medium spot, wide flood and elliptical beam. The light editor shows a preview of each distribution so you can see what you're picking.
                                Other Improvements
                                • Add procedural material previews, so material thumbnails render faster and no longer hang.
                                • Select newly placed lights automatically and show the active light tool in the toolbar.
                                • Refresh the user interface with a consistent set of toolbar icons, sharper icon scaling, clearer list selection, and a tidier settings layout.
                                Fixes
                                • Fix textures rendering cyan after editing a texture image in an external editor, saving, and reopening the model.
                                • Fix vignette falloff at high strength.
                                Follow me on X.
                                Happy Rendering!
                                Thomas
                                • KrassK
                                  Krass
                                  Great, thanks Thomas. I needed water materials this morning and you granted my wish tonight...!
                                  Krass
                                  • pixelcruncherP
                                    @Krass I will be waiting for those awesome renders!
                                    • KrassK
                                      Krass
                                      rayscayper pool with water material
                                      Krass
                                      • pixelcruncherP
                                        @Krass Nice!
                                        • KrassK
                                          Krass
                                          I really like the two buttons for hiding the settings and assets—you can quickly switch to a large-scale view of the render—and the minimalist icon design.
                                          And this time, it successfully loaded the HDRI map at full resolution
                                          for this render, which features actual waves in the geometry.
                                          Krass
                                            Sharp, I am missing the splash where my ex jumped in to create the waves though.......
