    Model for Rendering Samples - Green Dragon
    61 Posts 24 Posters 17.3k Views 24 Watching
      Renditioner V3.
      Advanced glass.
      Background for small object.
      studio neutral 2 lighting.
      Quality medium.
      Render time 9 minutes.
      Photo chopped for light levels.
      Green Dragon.
        • K Offline
          kaas
          As far as I know Lightup can't do SSS so I used some liquid material settings instead because the glass didn't look nice. Rendering time 2 minutes 30 seconds. Maybe Adam himself has a trick for making it look more like glass?
            http://i.minus.com/ib1y5EsR6slOde.gif
            • massimoM Offline
              massimo Moderator
              πŸ˜„
              now put some fire in its mouth please.
              • andybotA Offline
                andybot
                Rich - is that Blender cycles?
                Ah, guessing from the animation, I presume it is Blender...
                  @massimo
                  don't waste my day further....
                  but...yes.....i'm looking into it
                  @andy
                  Blender Render
                  UV unwrapped (@Kim - I couldn't resist)
                  AO baked
                  Freestyle edges on for silhouette and border only
                  • Al HartA Offline
                    Al Hart
                    @massimo said:
                    Sorry, not sure to understand this. You mean where is placed the camera?
                    Yes - I meant: "Where is the camera with regard to the schematic"
                    Al Hart
                    http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
                    IRender nXt from Render Plus
                    • massimoM Offline
                      massimo Moderator
                      Ok, here you go.
                      • ginchiusG Offline
                        ginchius
                        Stone dragon
                        You can find my models at http://sketchucation.com/shop/models
                          d12dozr
                          How does my simulation look? πŸ˜„
                          Ok, these are real photos, if you couldn't tell. πŸ˜‰ I scaled the model down to 2" long and printed it on my little Solidoodle 3D printer. My printer needs some calibration, as you can tell from the stringy bits and uneven layers, but at least the photos can be used as reference for real world lighting conditions.
                          http://goo.gl/f7ooYh
                          • FrederikF Offline
                            Frederik
                            The wooden texture used for the table looks low res... πŸ˜›
                            Cheers
                            Kim Frederik
                              d12dozr
                              Too funny, Kim! πŸ˜„ It IS one of those fake wood countertops.
                              • andybotA Offline
                                andybot
                                Real nice SSS πŸ˜„
                                • ElibjrE Offline
                                  Elibjr
                                  I used IRender nXt...
                                  I was first going to do a simple light around the table, but then I decided to MODEL a room as opposed to using an HDRI image. Then I decided to complicate matters by making the material 48% transparent, w/ 1.5 refraction, 73%+/- Translucency, and then checked Thick and Gather (this gives it the speckles when light goes through it). Attenuation at about 35%, 10% Dispersion and about 70% Saturation. I made the reflection intensity over 70% and Sharpness about 50%. Because of this, it took a while to render! The chairs lamps and vase are from the 3D Warehouse. The room is a rectangle with 5 windows into it. There is a lamp in each corner. I with the nXt image editor I did one render and created 6 images with the lighting channels. There is a Sun channel, a Sky channel, and a Lighting channel. I can add color variations too. I had too way much fun here. Thanks all for posting this thread Al. πŸ˜†
                                  Elibjr - EB
                                  IRender nXt raw run though a free Gif animator. One render, 6 images.
                                  • ElibjrE Offline
                                    Elibjr
                                    [attachment=2:1q2508sj]<!-- ia2 -->dragon01.jpg<!-- ia2 -->[/attachment:1q2508sj]
                                    [attachment=1:1q2508sj]<!-- ia1 -->dragon02.jpg<!-- ia1 -->[/attachment:1q2508sj]
                                    [attachment=0:1q2508sj]<!-- ia0 -->dragon03.jpg<!-- ia0 -->[/attachment:1q2508sj]
                                    This is awesome! How long did it take this thing to finish? What is it made out of? Cool! I want one! πŸ˜†
                                      d12dozr
                                      Hi Eli, it took 55 minutes to print at this scale (2" long). It's made of ABS plastic, the same stuff Lego blocks are made of.
                                      If you want to get one made, I have attached the file I used to print. It is converted to an STL file and fixed up so that it's solid for 3D printing. You can send it to a print service like Shapeways, or even better find someone near you with a 3D printer. Here's a good place to look: http://hackerspaces.org/wiki/List_of_Hacker_Spaces
                                      As a bonus, I found a photo of a the same dragon made on a $200,000 printer πŸ˜„
                                      http://blog.sculpteo.com/wp-content/uploads/2014/03/translucent-detail_hires.jpg
                                      Talk about fine detail and SSS!
                                      Dragon 2inch (repaired).zip
                                      • marked001M Offline
                                        marked001
                                        messed around with KeyShot this weekend...here's a quick render. 10 second setup time.
                                        http://www.revision21vis.com
                                        instagram: revi21on
                                        • jeff hammondJ Offline
                                          jeff hammond
                                          had to test a material importer so i used the dragon..
                                          then fredo's thruPaint > Natural did a pretty good job at laying out the tiles in the way they'd go down if you were to really attempt tiling this thing.. anybody got a diamond saw?
                                          click pic -> bigger
                                          dotdotdot
                                          • Al HartA Offline
                                            Al Hart
                                            @brighter3d said:
                                            Brighter3D 1.14.2 PRO
                                            Thanks - I liked the solid one better, and put a copy on SketchUpRendering.com
                                            Al Hart
                                            • 3 / 4
