    Model for Rendering Samples - Green Dragon
    61 Posts 24 Posters 17.6k Views 24 Watching
    • micioneM
      micione
      angry dragon...
      (Renditioner v3)
      • massimoM
        massimo Moderator
        @al hart said:
        without spending a lot if time trying to achieve a more profound studio effect.
        That's indeed time consuming, but you have a lot more control on the effects and, at the end, indeed a "more profound effect" as you said.
        @al hart said:
        Woukd you mind if i included your schematic and rendering in another article I am writing about basic rendering concepts. I will be glad to credit you your contribution.
        No problem. Anyway I took the basic set-up from here. It's in italian, but you have a lot of images to look at.
        @al hart said:
        Did you actually use a model like the schematic
        Yes, what I've posted is the Thea's workspace view from above.
        @al hart said:
        ...and if so, where dud the eye go?
        Sorry, not sure to understand this. You mean where is placed the camera?
          Renditioner V3.
          Advanced glass.
          Background for small object.
          studio neutral 2 lighting.
          Quality medium.
          Render time 9 minutes.
          Photo chopped for light levels.
          Green Dragon.
            • K
              kaas
              As far as I know Lightup can't do SSS so I used some liquid material settings instead because the glass didn't look nice. Rendering time 2 minutes 30 seconds. Maybe Adam himself has a trick for making it look more like glass?
                http://i.minus.com/ib1y5EsR6slOde.gif
                • massimoM
                  massimo Moderator
                  πŸ˜„
                  now put some fire in its mouth please.
                  • andybotA
                    andybot
                    Rich - is that Blender cycles?
                    Ah, guessing from the animation, I presume it is Blender...
                      @massimo
                      don't waste my day further....
                      but...yes.....i'm looking into it
                      @andy
                      Blender Render
                      UV unwrapped (@Kim - I couldn't resist)
                      AO baked
                      Freestyle edges on for silhouette and border only
                      • Al HartA
                        Al Hart
                        Yes - I meant: "Where is the camera with regard to the schematic"
                        Al Hart
                        IRender nXt from Render Plus
                        • massimoM
                          massimo Moderator
                          Ok, here you go.
                          • ginchiusG
                            ginchius
                            Stone dragon
                            You can find my models at http://sketchucation.com/shop/models
                              d12dozr
                              How does my simulation look? πŸ˜„
                              Ok, these are real photos, if you couldn't tell. πŸ˜‰ I scaled the model down to 2" long and printed it on my little Solidoodle 3D printer. My printer needs some calibration, as you can tell from the stringy bits and uneven layers, but at least the photos can be used as reference for real world lighting conditions.
                              http://goo.gl/f7ooYh
                              • FrederikF
                                Frederik
                                The wooden texture used for the table looks low res... πŸ˜›
                                Cheers
                                Kim Frederik
                                  d12dozr
                                  Too funny, Kim! πŸ˜„ It IS one of those fake wood countertops.
                                  • andybotA
                                    andybot
                                    Real nice SSS πŸ˜„
                                    • ElibjrE
                                      Elibjr
                                      I used IRender nXt...
                                      I was first going to do a simple light around the table, but then I decided to MODEL a room as opposed to using an HDRI image. Then I decided to complicate matters by making the material 48% transparent, w/ 1.5 refraction, 73%+/- Translucency, and then checked Thick and Gather (this gives it the speckles when light goes through it). Attenuation at about 35%, 10% Dispersion and about 70% Saturation. I made the reflection intensity over 70% and Sharpness about 50%. Because of this, it took a while to render! The chairs lamps and vase are from the 3D Warehouse. The room is a rectangle with 5 windows into it. There is a lamp in each corner. I with the nXt image editor I did one render and created 6 images with the lighting channels. There is a Sun channel, a Sky channel, and a Lighting channel. I can add color variations too. I had too way much fun here. Thanks all for posting this thread Al. πŸ˜†
                                      Elibjr - EB
                                      IRender nXt raw run though a free Gif animator. One render, 6 images.
                                      • ElibjrE
                                        Elibjr
                                        [attachment=2:1q2508sj]<!-- ia2 -->dragon01.jpg<!-- ia2 -->[/attachment:1q2508sj]
                                        [attachment=1:1q2508sj]<!-- ia1 -->dragon02.jpg<!-- ia1 -->[/attachment:1q2508sj]
                                        [attachment=0:1q2508sj]<!-- ia0 -->dragon03.jpg<!-- ia0 -->[/attachment:1q2508sj]
                                        This is awesome! How long did it take this thing to finish? What is it made out of? Cool! I want one! πŸ˜†
                                          d12dozr
                                          Hi Eli, it took 55 minutes to print at this scale (2" long). It's made of ABS plastic, the same stuff Lego blocks are made of.
                                          If you want to get one made, I have attached the file I used to print. It is converted to an STL file and fixed up so that it's solid for 3D printing. You can send it to a print service like Shapeways, or even better find someone near you with a 3D printer. Here's a good place to look: http://hackerspaces.org/wiki/List_of_Hacker_Spaces
                                          As a bonus, I found a photo of a the same dragon made on a $200,000 printer πŸ˜„
                                          http://blog.sculpteo.com/wp-content/uploads/2014/03/translucent-detail_hires.jpg
                                          Talk about fine detail and SSS!
                                          Dragon 2inch (repaired).zip
                                          • marked001M
                                            marked001
                                            messed around with KeyShot this weekend...here's a quick render. 10 second setup time.
                                            http://www.revision21vis.com
                                            instagram: revi21on
                                            • 3 / 4
