    Model for Rendering Samples - Green Dragon
    61 Posts 24 Posters 15.9k Views 24 Watching
      kaas
      As far as I know Lightup can't do SSS so I used some liquid material settings instead because the glass didn't look nice. Rendering time 2 minutes 30 seconds. Maybe Adam himself has a trick for making it look more like glass?
        http://i.minus.com/ib1y5EsR6slOde.gif
        • massimoM Offline
          massimo Moderator
          πŸ˜„
          now put some fire in its mouth please.
          • andybotA Offline
            andybot
            Rich - is that Blender cycles?
            Ah, guessing from the animation, I presume it is Blender...
              @massimo
              don't waste my day further....
              but...yes.....i'm looking into it
              @andy
              Blender Render
              UV unwrapped (@Kim - I couldn't resist)
              AO baked
              Freestyle edges on for silhouette and border only
              • Al HartA Offline
                Al Hart
                @massimo said:
                Sorry, not sure to understand this. You mean where is placed the camera?
                Yes - I meant: "Where is the camera with regard to the schematic"
                Al Hart
                IRender nXt from Render Plus
                • massimoM Offline
                  massimo Moderator
                  Ok, here you go.
                  • ginchiusG Offline
                    ginchius
                    Stone dragon
                    You can find my models at http://sketchucation.com/shop/models
                      d12dozr
                      How does my simulation look? πŸ˜„
                      Ok, these are real photos, if you couldn't tell. πŸ˜‰ I scaled the model down to 2" long and printed it on my little Solidoodle 3D printer. My printer needs some calibration, as you can tell from the stringy bits and uneven layers, but at least the photos can be used as reference for real world lighting conditions.
                      http://goo.gl/f7ooYh
                      • FrederikF Offline
                        Frederik
                        The wooden texture used for the table looks low res... πŸ˜›
                        Cheers
                        Kim Frederik
                          d12dozr
                          Too funny, Kim! πŸ˜„ It IS one of those fake wood countertops.
                          • andybotA Offline
                            andybot
                            Real nice SSS πŸ˜„
                            • ElibjrE Offline
                              Elibjr
                              I used IRender nXt...
                              I was first going to do a simple light around the table, but then I decided to MODEL a room as opposed to using an HDRI image. Then I decided to complicate matters by making the material 48% transparent, w/ 1.5 refraction, 73%+/- Translucency, and then checked Thick and Gather (this gives it the speckles when light goes through it). Attenuation at about 35%, 10% Dispersion and about 70% Saturation. I made the reflection intensity over 70% and Sharpness about 50%. Because of this, it took a while to render! The chairs lamps and vase are from the 3D Warehouse. The room is a rectangle with 5 windows into it. There is a lamp in each corner. I with the nXt image editor I did one render and created 6 images with the lighting channels. There is a Sun channel, a Sky channel, and a Lighting channel. I can add color variations too. I had too way much fun here. Thanks all for posting this thread Al. πŸ˜†
                              Elibjr - EB
                              IRender nXt raw run though a free Gif animator. One render, 6 images.
                              • ElibjrE Offline
                                Elibjr
                                [attachment=2:1q2508sj]<!-- ia2 -->dragon01.jpg<!-- ia2 -->[/attachment:1q2508sj]
                                [attachment=1:1q2508sj]<!-- ia1 -->dragon02.jpg<!-- ia1 -->[/attachment:1q2508sj]
                                [attachment=0:1q2508sj]<!-- ia0 -->dragon03.jpg<!-- ia0 -->[/attachment:1q2508sj]
                                This is awesome! How long did it take this thing to finish? What is it made out of? Cool! I want one! πŸ˜†
                                  d12dozr
                                  Hi Eli, it took 55 minutes to print at this scale (2" long). It's made of ABS plastic, the same stuff Lego blocks are made of.
                                  If you want to get one made, I have attached the file I used to print. It is converted to an STL file and fixed up so that it's solid for 3D printing. You can send it to a print service like Shapeways, or even better find someone near you with a 3D printer. Here's a good place to look: http://hackerspaces.org/wiki/List_of_Hacker_Spaces
                                  As a bonus, I found a photo of a the same dragon made on a $200,000 printer πŸ˜„
                                  http://blog.sculpteo.com/wp-content/uploads/2014/03/translucent-detail_hires.jpg
                                  Talk about fine detail and SSS!
                                  Dragon 2inch (repaired).zip
                                  • marked001M Offline
                                    marked001
                                    messed around with KeyShot this weekend...here's a quick render. 10 second setup time.
                                    http://www.revision21vis.com
                                    instagram: revi21on
                                    • jeff hammondJ Offline
                                      had to test a material importer so i used the dragon..
                                      then fredo's thruPaint > Natural did a pretty good job at laying out the tiles in the way they'd go down if you were to really attempt tiling this thing.. anybody got a diamond saw?
                                      click pic -> bigger
                                      • Al HartA Offline
                                        Al Hart
                                        @brighter3d said:
                                        Brighter3D 1.14.2 PRO
                                        Thanks - I liked the solid one better, and put a copy on SketchUpRendering.com
                                        Al Hart
                                          Brighter3D
                                          Material:
                                          Dragon Green[[dif:0.00,ref:0.20,tra:0.79,ior:1.30,dens:21,beer:1,fre:1]]
                                          Brighter3D 1.15.0 PRO
                                          144 seconds
                                          Material:
                                          Dragon Green[[dif:0.72,ref:0.28,fre:1]]
                                          72 seconds
                                          diffuse + little reflection
                                          Settings (caustics=0 for second image):
                                          Settings
                                          • 3 / 4
