    Sample Model for Rendering - Water
    25 Posts 17 Posters 8.0k Views 17 Watching
    • Al HartA Offline
      Al Hart
      I have placed this model, created by Boothy, on the 3D Warehouse to use for making rendering samples with various rendering products: Water Effects Sample
      http://doc-0s-8g-3dwarehouse.googleusercontent.com/3dwarehouse/secure/hhulr73hmmak89paul31eote4ben7ngk/e90veje835vu6kervtarplc017hab7or/1342526400000/lt/*/5035ffe88e539ae46696f5ae64df05eb?ts=1341761563000&ctyp=other
      Render it with your favorite rendering package, post the results here, and I will place them in the Sample Renderings section of SketchUpRendering.com.
      Besides seeing samples of various rendering packages, the purpose of this thread and/or the SketchUpRendering.com site, where we will post these images, is to show SketchUp users the value of using add-on rendering packages to improve the quality and value of SketchUp models and images for internal or client presentations.
      It is OK to change materials, backgrounds, lights, and other rendering settings – but do not add or change other geometry – unless there is something wrong with the original model.
      Al Hart
      IRender nXt from Render Plus
      • oganocaliO Offline
        oganocali
        Using vray. I essentially kept the original materials, just added reflective layers and bump maps. The fake caustics on the shark are added to the shark skin texture before the render using gimp.
        • CarlohC Offline
          Carloh
          once again an attempt with lumion free version.
          • CarlohC Offline
            Carloh
            as lumion is almost predicted for it i also made a quick animation.
            • Al HartA Offline
              Al Hart
              Nice work on the video.
              It really highlights how the water is a procedural bump map and not just a flat material
              Al Hart
              • jo-keJ Offline
                jo-ke
                left all materials, changed only settings and bumps,
                placed lights, placed a background sphere
                removed backsides,
                took a rough water procedural (by madjid)
                used twilight render Preset low
                no postpro
                http://www.zz7.de
                • P Offline
                  pibuz
                  Nice scene Al!
                  Could you post a v7 skp file too?
                  WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                  • Al HartA Offline
                    Al Hart
                    @pibuz said:
                    Nice scene Al!
                    Tye 3D Warehouse page has both SU7 and SU8 downloads: D Warehouse page
                    Al Hart
                    • Al HartA Offline
                      Al Hart
                      For this image, I placed some lights below the water level, turned off the sun, turned down the sun and placed a procedural bump on on the water, and zoomed in on the shark.
                      Rendered with IRender nXt - using alternate Rendering Engine 4 - which s better for caustic effects. Allowed to "cook" overnight for 625 passes. No post-processing
                      Al Hart
                      • V Offline
                        vidy
                        using Renderin, no post pro, everything pretty much what is existing on the file, just touch it with reflection and refraction only, for night scene added illumination on existing spot light and adding pool light.
                        Rendered on my AMD Dual Core 2.61 GHz, 1 GB RAM (pretty cheap old spec here)
                        regards,
                        rendered time 34 minutes
                        rendered time 5 Hr
                        still so much to learn..
                        • massimoM Offline
                          massimo Moderator
                          The shark attacks! 😮
                          A very quick set up, just trying out some (true) sun pool caustics with Thea's new TR1 improved preset. Motion blur and CRF in Thea and only a very slight colour correction in post pro.
                          • O Offline
                            Ollo81
                            Here is my attempt. This was a 3 and a half hour render with 70 passes using Thea with TR1. I kept the original materials and only added custom bump and reflection maps. I also did some post processing work with Gimp and DenoiseMyImage_Free. The HDR image that I used is form http://www.hdrlabs.com
                              sketchgeek
                              Good thread - like seeing the different styles/rendering engines. My attempt with Lumion. Left all the original materials.
                              (edit: forgot to post the stats - scene setup time approx 30-40mins. render time approx 7 secs. No post work)
                              Marc
                              • V Offline
                                vidy
                                indeed.. i'd love to see all the render that provides for SU..(i know it's a long listing) but it will be very fun..
                                unity in diversity 👍
                                regards,
                                • P Offline
                                  pibuz
                                  @al hart said:
                                  @pibuz said:
                                  Nice scene Al!
                                  ....so sorry Al... 😳 😳 😳
                                  Thanks....
                                  • micioneM Offline
                                    micione
                                    Hello, Here is a test Renditioner. time: 4 minutes.
                                    • G Offline
                                      giomelkadze
                                      Hi, anyone can you teach me how do same realistic water with twilight render, i want to get realistic transparent water. thanks.
                                        jpalm32
                                        Why don't you post on Twilight site?
                                        They have plenty of examples and tuts.
                                        • jo-keJ Offline
                                          jo-ke
                                          Download majid's poolwater, it works fine
                                          http://www.zz7.de
                                          • K Offline
                                            kaas
                                            Here a go at this scene with LightUp.
                                            Added some light emitters in front of the windows. Changed the transparency of the roof because the scene was too bright. Changed several materials, added a watershader, turned some backfaces. Added a hdr as a background and as lighting source from http://www.hdrlabs.com
                                            Calculation time: 6 minutes 15 seconds.
                                            Edit:No post-processing.
                                            Greetings, Max
                                            • 1 / 2
