    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 372.4k Views 57 Watching
    • EdsonE Offline
      Edson
      this is fantastic! one more great plugin from one of the greats! 🎉 👍 😍
      http://www.mahfuz.arq.br
      • Z Offline
        ZFRPS
        This plugin very useful !
        but...
        When I was in the test of time, some is not stable, very bad,Don't know why!
        sketchup is bim
        • Z Offline
          ZFRPS
          sketchup is bim
          • fredo6F Offline
            fredo6
            @zfrps
            The Simplify tool does not analyze the cylinder. It just simplifies each circle independently. Then it eliminates edges which have their two bordering faces coplanar. So, sometimes the simplified contours matches, sometimes not.
            Fredo
              I have your new plugin and it shows that it needs to be updated, screen shot illustration below,
              That does not say Curvizard needs to be updates - the blue means no update information is availibile. If there is an update for a plugin it's highlighted red and the status will say "Update availible" (or similar) Note that in your screenshot it says nothing. No update is availibile.
              • Z Offline
                ZFRPS
                Thanks Fredo !
                sketchup is bim
                • mitcorbM Offline
                  mitcorb
                  Thank you once again.
                  • OxerO Offline
                    Oxer
                    Thanks Fredo for this new plugin!! 👍
                    I have translated the plugin to Spanish (Spain) but some words don't appear translated i don't know why.
                    Problem with the translation
                    Spanish (Spain) Translation
                    http://www.oxervision.blogspot.com/
                    • I Offline
                      ideas_arte
                      @Fredo, Thanks for the useful plugin
                      @Oxer, gracias por la traducción, Saludos!
                      • fredo6F Offline
                        fredo6
                        This is a bug (not just for Spanish). Thanks for signaling.
                        I fixed it and your translation will appear at next release.
                        Fred
                          smicha
                          This plugin is so useful! Thank you so much.
                            RICALBUR
                            Thank you for this post
                            • guanjinG Offline
                              guanjin
                              Hello:Fredo6
                              Translated language files, and can not be changed!
                              I come from China, is to learn
                                blajnov
                                Thanks for the plugin!!!
                                Translation into Russian...
                                Curvizard_RU.lang
                                • cottyC Offline
                                  cotty
                                  I've seen the new features of V1.1 on youtube, can't wait to try 😉
                                  my SketchUp gallery
                                  • JClementsJ Offline
                                    JClements
                                    I saw the You-Tube demo too. Very interesting!
                                      Wow....thanks Fredo
                                      • fredo6F Offline
                                        fredo6
                                        NEW RELEASE: Curvizard v1.1a - 28 Nov 12
                                        Curvizard 1.1 is an interim version which introduces 3 new functions:
                                        • Smooth Contour, with 2 methods and several options for adjustments
                                        • Cleanup Contour, which just removes collinear edges and small spikes
                                        • Change Edge properties, which allows modifying properties such as Smooth, Soft, Hidden and Cast Shadows of selected edges
                                        There is now some rudimentary error checking when you select contours (needle eyes and spines). This is also applicable to Curviloft.
                                        There is a video for the Smooth Contours function
                                        [flash=425,344:3e0cw7kh]http://www.youtube.com/v/AHT6ZUR3qiQ&hl[/flash:3e0cw7kh]
                                        Curvizard 1.1 requires an upgrade to LibFredo6 4.7 or higher.
                                        See main post of this thread for Download.
                                        Fredo
                                        • utilerU Offline
                                          utiler
                                          Double WOW!!! Thank you Fredo. I can't say enough about what you contribute to my SketchUp workflow....! 👍 👍 👍
                                          Just Curious...
                                          • guanjinG Offline
                                            guanjin
                                            Thanks for update again, but the language translation problems still exist, thank you!
                                            • 9
                                            • 10
                                            • 2 / 10
