    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 386.9k Views 57 Watching
    • cottyC
      cotty
      Thank you very much for another wonderful plugin.
      (a donation is on the way "as a sign of reward and recognition")
      my SketchUp gallery
      • fredo6F
        @daniel s said:
        PS: It´s possible to make contours more complex? something like the opposite of simplify contour
        This is planned, as Smooth Contour.
        • EarthMoverE
          EarthMover
          This is great. Thanks Fredo! 👍 Would also like to see a divide (length & increment) curve, comparable to the one in BZ Convert, except that respects angles in the manner of your simplify tool. Simply put, a polyline divider that respects corners over a certain degree.
          Content Creator at Skapeup
          • brookefoxB
            brookefox
            I'm just going to jump right in and say thanks again for epitomizing the way to share a most potent, stealthy tool set, gloved with generous explicating tutorial and annotated pics. You try to make it easier to get with the power of Fredo .
            (We can, as a rule, be slow, lazy, impatient... I should know. Sometimes these things need to be said.)
            ~ Brooke
            • JClementsJ
              JClements
              A very BIG THANK YOU.
              Of course another request :smile:
              What if a selection consists of segments, who by definition (equal length, connected segments with equal angles at their vertices), define a native SU arc or circle.  Could they be converted into SU arcs or circles?
              This could be very useful when editing imported DXF files.
              • C
                cuttingedge
                Fredo, We applaud your passion in perfecting tools to keep Sketchup afloat in the competition of 3d modelling softwares. Such a wonderful plugin indeed.
                • kenK
                  ken
                  I have your new plugin and it shows that it needs to be updated, screen shot illustration below, however, I believe I have all the required files. Note, I renamed the folders with a leading "1" so they would be grouped at the top of the list so I could show all directories in the illustration, I remove the "1" when using Sketchup. I have one folder, curviloft_dir_12Ken, which I have renamed,as it appears not to be needed for curvilof and adding "ken" to the end of the folder name is my way of trying to determine if the folder is required.
                  Could you please look at my directory and try to help me to find out what is going on with the updated plugin.
                  Thanks you in advance
                  Ken
                  • EdsonE
                    Edson
                    this is fantastic! one more great plugin from one of the greats! 🎉 👍 😍
                    http://www.mahfuz.arq.br
                    • Z
                      ZFRPS
                      This plugin very useful !
                      but...
                      When I was in the test of time, some is not stable, very bad,Don't know why!
                      sketchup is bim
                      • Z
                        ZFRPS
                        sketchup is bim
                        • fredo6F
                          @zfrps
                          The Simplify tool does not analyze the cylinder. It just simplifies each circle independently. Then it eliminates edges which have their two bordering faces coplanar. So, sometimes the simplified contours matches, sometimes not.
                            That does not say Curvizard needs to be updates - the blue means no update information is availibile. If there is an update for a plugin it's highlighted red and the status will say "Update availible" (or similar) Note that in your screenshot it says nothing. No update is availibile.
                            • Z
                              ZFRPS
                              Thanks Fredo !
                              sketchup is bim
                              • mitcorbM
                                mitcorb
                                Thank you once again.
                                • OxerO
                                  Oxer
                                  Thanks Fredo for this new plugin!! 👍
                                  I have translated the plugin to Spanish (Spain) but some words don't appear translated i don't know why.
                                  Problem with the translation
                                  Spanish (Spain) Translation
                                  • I
                                    ideas_arte
                                    @Fredo, Thanks for the useful plugin
                                    @Oxer, gracias por la traducción, Saludos!
                                    • fredo6F
                                      This is a bug (not just for Spanish). Thanks for signaling.
                                      I fixed it and your translation will appear at next release.
                                      Fred
                                        smicha
                                        This plugin is so useful! Thank you so much.
                                          RICALBUR
                                          Thank you for this post
                                          • guanjinG
                                            guanjin
                                            Hello:Fredo6
                                            Translated language files, and can not be changed!
                                            • 2 / 10
