    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 381.3k Views 57 Watching
    • Z
      ZFRPS
      This plugin very useful !
      but...
      When I was in the test of time, some is not stable, very bad,Don't know why!
      sketchup is bim
      • Z
        ZFRPS
        sketchup is bim
        • fredo6F
          @zfrps
          The Simplify tool does not analyze the cylinder. It just simplifies each circle independently. Then it eliminates edges which have their two bordering faces coplanar. So, sometimes the simplified contours matches, sometimes not.
            I have your new plugin and it shows that it needs to be updated, screen shot illustration below,
            That does not say Curvizard needs to be updates - the blue means no update information is availibile. If there is an update for a plugin it's highlighted red and the status will say "Update availible" (or similar) Note that in your screenshot it says nothing. No update is availibile.
            • Z
              ZFRPS
              Thanks Fredo !
              sketchup is bim
              • mitcorbM
                mitcorb
                Thank you once again.
                • OxerO
                  Oxer
                  Thanks Fredo for this new plugin!! 👍
                  I have translated the plugin to Spanish (Spain) but some words don't appear translated i don't know why.
                  Problem with the translation
                  Spanish (Spain) Translation
                  • I
                    ideas_arte
                    @Fredo, Thanks for the useful plugin
                    @Oxer, gracias por la traducción, Saludos!
                    • fredo6F
                      This is a bug (not just for Spanish). Thanks for signaling.
                      I fixed it and your translation will appear at next release.
                      Fred
                        smicha
                        This plugin is so useful! Thank you so much.
                          RICALBUR
                          Thank you for this post
                          • guanjinG
                            guanjin
                            Hello:Fredo6
                            Translated language files, and can not be changed!
                            • B
                              blajnov
                              Thanks for the plugin!!!
                              Translation into Russian...
                              Curvizard_RU.lang
                              • cottyC
                                cotty
                                I've seen the new features of V1.1 on youtube, can't wait to try 😉
                                my SketchUp gallery
                                • JClementsJ
                                  JClements
                                  I saw the You-Tube demo too. Very interesting!
                                    Wow....thanks Fredo
                                    • fredo6F
                                      NEW RELEASE: Curvizard v1.1a - 28 Nov 12
                                      Curvizard 1.1 is an interim version which introduces 3 new functions:
                                      • Smooth Contour, with 2 methods and several options for adjustments
                                      • Cleanup Contour, which just removes collinear edges and small spikes
                                      • Change Edge properties, which allows modifying properties such as Smooth, Soft, Hidden and Cast Shadows of selected edges
                                      There is now some rudimentary error checking when you select contours (needle eyes and spines). This is also applicable to Curviloft.
                                      There is a video for the Smooth Contours function
                                      [flash=425,344:3e0cw7kh]http://www.youtube.com/v/AHT6ZUR3qiQ&hl[/flash:3e0cw7kh]
                                      Curvizard 1.1 requires an upgrade to LibFredo6 4.7 or higher.
                                      • utilerU
                                        utiler
                                        Double WOW!!! Thank you Fredo. I can't say enough about what you contribute to my SketchUp workflow....! 👍 👍 👍
                                        Just Curious...
                                        • guanjinG
                                          guanjin
                                          Thanks for update again, but the language translation problems still exist, thank you!
                                            Research of the perfect voluptuous inaccessible curves! ☀
                                            • 2 / 10
