    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 386.9k Views 57 Watching
    • N
      notareal
      Looking great!
        Daniel S
        @daniel s said:
        PS: It´s possible to make contours more complex? something like the opposite of simplify contour
        you can do things like that with fredo's BezierSpline
        select the lines then right click -> BZ convert to…
        and pick one of the different splines depending on desired curve (catmull, Bspline, Fspline, etc)
        Yesss!! I didn´t remember that option 😳
        Thank you!!!,
        Daniel S
        • cottyC
          cotty
          Thank you very much for another wonderful plugin.
          (a donation is on the way "as a sign of reward and recognition")
          my SketchUp gallery
          • fredo6F
            This is planned, as Smooth Contour.
            • EarthMoverE
              EarthMover
              This is great. Thanks Fredo! 👍 Would also like to see a divide (length & increment) curve, comparable to the one in BZ Convert, except that respects angles in the manner of your simplify tool. Simply put, a polyline divider that respects corners over a certain degree.
              Content Creator at Skapeup
              • brookefoxB
                brookefox
                I'm just going to jump right in and say thanks again for epitomizing the way to share a most potent, stealthy tool set, gloved with generous explicating tutorial and annotated pics. You try to make it easier to get with the power of Fredo .
                (We can, as a rule, be slow, lazy, impatient... I should know. Sometimes these things need to be said.)
                ~ Brooke
                • JClementsJ
                  JClements
                  A very BIG THANK YOU.
                  Of course another request :smile:
                  What if a selection consists of segments, who by definition (equal length, connected segments with equal angles at their vertices), define a native SU arc or circle.  Could they be converted into SU arcs or circles?
                  This could be very useful when editing imported DXF files.
                  • C
                    cuttingedge
                    Fredo, We applaud your passion in perfecting tools to keep Sketchup afloat in the competition of 3d modelling softwares. Such a wonderful plugin indeed.
                    • kenK
                      ken
                      I have your new plugin and it shows that it needs to be updated, screen shot illustration below, however, I believe I have all the required files. Note, I renamed the folders with a leading "1" so they would be grouped at the top of the list so I could show all directories in the illustration, I remove the "1" when using Sketchup. I have one folder, curviloft_dir_12Ken, which I have renamed,as it appears not to be needed for curvilof and adding "ken" to the end of the folder name is my way of trying to determine if the folder is required.
                      Could you please look at my directory and try to help me to find out what is going on with the updated plugin.
                      Thanks you in advance
                      Ken
                      • EdsonE
                        Edson
                        this is fantastic! one more great plugin from one of the greats! 🎉 👍 😍
                        http://www.mahfuz.arq.br
                        • Z
                          ZFRPS
                          This plugin very useful !
                          but...
                          When I was in the test of time, some is not stable, very bad,Don't know why!
                          sketchup is bim
                          • Z
                            ZFRPS
                            sketchup is bim
                            • fredo6F
                              @zfrps
                              The Simplify tool does not analyze the cylinder. It just simplifies each circle independently. Then it eliminates edges which have their two bordering faces coplanar. So, sometimes the simplified contours matches, sometimes not.
                                That does not say Curvizard needs to be updates - the blue means no update information is availibile. If there is an update for a plugin it's highlighted red and the status will say "Update availible" (or similar) Note that in your screenshot it says nothing. No update is availibile.
                                • Z
                                  ZFRPS
                                  Thanks Fredo !
                                  sketchup is bim
                                  • mitcorbM
                                    mitcorb
                                    Thank you once again.
                                    • OxerO
                                      Oxer
                                      Thanks Fredo for this new plugin!! 👍
                                      I have translated the plugin to Spanish (Spain) but some words don't appear translated i don't know why.
                                      Problem with the translation
                                      Spanish (Spain) Translation
                                      • I
                                        ideas_arte
                                        @Fredo, Thanks for the useful plugin
                                        @Oxer, gracias por la traducción, Saludos!
                                        • fredo6F
                                          This is a bug (not just for Spanish). Thanks for signaling.
                                          I fixed it and your translation will appear at next release.
                                          Fred
                                            smicha
                                            This plugin is so useful! Thank you so much.
                                            • 2 / 10
