    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 386.9k Views 57 Watching
    • kenK
      ken
      I have your new plugin and it shows that it needs to be updated, screen shot illustration below, however, I believe I have all the required files. Note, I renamed the folders with a leading "1" so they would be grouped at the top of the list so I could show all directories in the illustration, I remove the "1" when using Sketchup. I have one folder, curviloft_dir_12Ken, which I have renamed,as it appears not to be needed for curvilof and adding "ken" to the end of the folder name is my way of trying to determine if the folder is required.
      Could you please look at my directory and try to help me to find out what is going on with the updated plugin.
      Thanks you in advance
      Ken
      • EdsonE
        Edson
        this is fantastic! one more great plugin from one of the greats! 🎉 👍 😍
        http://www.mahfuz.arq.br
        • Z
          ZFRPS
          This plugin very useful !
          but...
          When I was in the test of time, some is not stable, very bad,Don't know why!
          sketchup is bim
          • Z
            ZFRPS
            sketchup is bim
            • fredo6F
              @zfrps
              The Simplify tool does not analyze the cylinder. It just simplifies each circle independently. Then it eliminates edges which have their two bordering faces coplanar. So, sometimes the simplified contours matches, sometimes not.
                That does not say Curvizard needs to be updates - the blue means no update information is availibile. If there is an update for a plugin it's highlighted red and the status will say "Update availible" (or similar) Note that in your screenshot it says nothing. No update is availibile.
                • Z
                  ZFRPS
                  Thanks Fredo !
                  sketchup is bim
                  • mitcorbM
                    mitcorb
                    Thank you once again.
                    • OxerO
                      Oxer
                      Thanks Fredo for this new plugin!! 👍
                      I have translated the plugin to Spanish (Spain) but some words don't appear translated i don't know why.
                      Problem with the translation
                      Spanish (Spain) Translation
                      • I
                        ideas_arte
                        @Fredo, Thanks for the useful plugin
                        @Oxer, gracias por la traducción, Saludos!
                        • fredo6F
                          This is a bug (not just for Spanish). Thanks for signaling.
                          I fixed it and your translation will appear at next release.
                          Fred
                            smicha
                            This plugin is so useful! Thank you so much.
                              RICALBUR
                              Thank you for this post
                              • guanjinG
                                guanjin
                                Hello:Fredo6
                                Translated language files, and can not be changed!
                                • B
                                  blajnov
                                  Thanks for the plugin!!!
                                  Translation into Russian...
                                  Curvizard_RU.lang
                                  • cottyC
                                    cotty
                                    I've seen the new features of V1.1 on youtube, can't wait to try 😉
                                    my SketchUp gallery
                                    • JClementsJ
                                      JClements
                                      I saw the You-Tube demo too. Very interesting!
                                        Wow....thanks Fredo
                                        • fredo6F
                                          NEW RELEASE: Curvizard v1.1a - 28 Nov 12
                                          Curvizard 1.1 is an interim version which introduces 3 new functions:
                                          • Smooth Contour, with 2 methods and several options for adjustments
                                          • Cleanup Contour, which just removes collinear edges and small spikes
                                          • Change Edge properties, which allows modifying properties such as Smooth, Soft, Hidden and Cast Shadows of selected edges
                                          There is now some rudimentary error checking when you select contours (needle eyes and spines). This is also applicable to Curviloft.
                                          There is a video for the Smooth Contours function
                                          [flash=425,344:3e0cw7kh]http://www.youtube.com/v/AHT6ZUR3qiQ&hl[/flash:3e0cw7kh]
                                          Curvizard 1.1 requires an upgrade to LibFredo6 4.7 or higher.
                                          • utilerU
                                            utiler
                                            Double WOW!!! Thank you Fredo. I can't say enough about what you contribute to my SketchUp workflow....! 👍 👍 👍
                                            Just Curious...
                                            • 2 / 10
