    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 386.9k Views 57 Watching
    • OxerO
      Oxer
      Thanks Fredo for this new plugin!! 👍
      I have translated the plugin to Spanish (Spain) but some words don't appear translated i don't know why.
      Problem with the translation
      Spanish (Spain) Translation
      • I
        ideas_arte
        @Fredo, Thanks for the useful plugin
        @Oxer, gracias por la traducción, Saludos!
        • fredo6F
          This is a bug (not just for Spanish). Thanks for signaling.
          I fixed it and your translation will appear at next release.
          Fred
            smicha
            This plugin is so useful! Thank you so much.
              RICALBUR
              Thank you for this post
              • guanjinG
                guanjin
                Hello:Fredo6
                Translated language files, and can not be changed!
                • B
                  blajnov
                  Thanks for the plugin!!!
                  Translation into Russian...
                  Curvizard_RU.lang
                  • cottyC
                    cotty
                    I've seen the new features of V1.1 on youtube, can't wait to try 😉
                    my SketchUp gallery
                    • JClementsJ
                      JClements
                      I saw the You-Tube demo too. Very interesting!
                        Wow....thanks Fredo
                        • fredo6F
                          NEW RELEASE: Curvizard v1.1a - 28 Nov 12
                          Curvizard 1.1 is an interim version which introduces 3 new functions:
                          • Smooth Contour, with 2 methods and several options for adjustments
                          • Cleanup Contour, which just removes collinear edges and small spikes
                          • Change Edge properties, which allows modifying properties such as Smooth, Soft, Hidden and Cast Shadows of selected edges
                          There is now some rudimentary error checking when you select contours (needle eyes and spines). This is also applicable to Curviloft.
                          There is a video for the Smooth Contours function
                          [flash=425,344:3e0cw7kh]http://www.youtube.com/v/AHT6ZUR3qiQ&hl[/flash:3e0cw7kh]
                          Curvizard 1.1 requires an upgrade to LibFredo6 4.7 or higher.
                          • utilerU
                            utiler
                            Double WOW!!! Thank you Fredo. I can't say enough about what you contribute to my SketchUp workflow....! 👍 👍 👍
                            Just Curious...
                            • guanjinG
                              guanjin
                              Thanks for update again, but the language translation problems still exist, thank you!
                                Research of the perfect voluptuous inaccessible curves! ☀
                                • pbacotP
                                  Thank you Fredo! This looks fantastic. Thanks for everything...looking of Donate button.
                                  • cottyC
                                    cotty
                                    Thank you not only for the impressive plugin, but also especially for the excellent and detailed documentation (PDF)!
                                    my SketchUp gallery
                                    • fredo6F
                                      [attachment=0:2dklo00h]<!-- ia0 -->未命名.jpg<!-- ia0 -->[/attachment:2dklo00h]
                                      Thanks for signaling the bug. I fixed it and will republish.
                                      But before I do, do you have the Curvizard_ZH.lang file so that I integrate it in the release.
                                      • guanjinG
                                        guanjin
                                        [attachment=0:22t88ozw]<!-- ia0 -->未命名.jpg<!-- ia0 -->[/attachment:22t88ozw]
                                        Dear Fredo6: Chinese language file has been sent to your mailbox, please find Thank you!
                                        • OxerO
                                          Oxer
                                          Thanks Fredo for the update it's very useful !! 👍
                                          The problem with the translation continues and missing some translations. I have done the Spanish translation (Spain) but how i say you there are missing translations.
                                          Thanks again Fredo.
                                          Spanish Language (Spain)
                                          • fredo6F
                                            Oxer,
                                            Thanks very much for the update.
                                            Note that part of the transaltion is in LibFredo
                                            The issue with the translation effective in the Luancher and tooltips of the main icons will be fixed in release 1.1b.
                                            • 2 / 10
