    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 378.8k Views 57 Watching
    • fredo6F
      @zfrps
      The Simplify tool does not analyze the cylinder. It just simplifies each circle independently. Then it eliminates edges which have their two bordering faces coplanar. So, sometimes the simplified contours matches, sometimes not.
        I have your new plugin and it shows that it needs to be updated, screen shot illustration below,
        That does not say Curvizard needs to be updates - the blue means no update information is availibile. If there is an update for a plugin it's highlighted red and the status will say "Update availible" (or similar) Note that in your screenshot it says nothing. No update is availibile.
        • Z
          ZFRPS
          Thanks Fredo !
          sketchup is bim
          • mitcorbM
            mitcorb
            Thank you once again.
            • OxerO
              Oxer
              Thanks Fredo for this new plugin!! 👍
              I have translated the plugin to Spanish (Spain) but some words don't appear translated i don't know why.
              Problem with the translation
              Spanish (Spain) Translation
              • I
                ideas_arte
                @Fredo, Thanks for the useful plugin
                @Oxer, gracias por la traducción, Saludos!
                • fredo6F
                  This is a bug (not just for Spanish). Thanks for signaling.
                  I fixed it and your translation will appear at next release.
                  Fred
                    smicha
                    This plugin is so useful! Thank you so much.
                      RICALBUR
                      Thank you for this post
                      • guanjinG
                        guanjin
                        Hello:Fredo6
                        Translated language files, and can not be changed!
                        • B
                          blajnov
                          Thanks for the plugin!!!
                          Translation into Russian...
                          Curvizard_RU.lang
                          • cottyC
                            cotty
                            I've seen the new features of V1.1 on youtube, can't wait to try 😉
                            my SketchUp gallery
                            • JClementsJ
                              JClements
                              I saw the You-Tube demo too. Very interesting!
                                Wow....thanks Fredo
                                • fredo6F
                                  NEW RELEASE: Curvizard v1.1a - 28 Nov 12
                                  Curvizard 1.1 is an interim version which introduces 3 new functions:
                                  • Smooth Contour, with 2 methods and several options for adjustments
                                  • Cleanup Contour, which just removes collinear edges and small spikes
                                  • Change Edge properties, which allows modifying properties such as Smooth, Soft, Hidden and Cast Shadows of selected edges
                                  There is now some rudimentary error checking when you select contours (needle eyes and spines). This is also applicable to Curviloft.
                                  There is a video for the Smooth Contours function
                                  [flash=425,344:3e0cw7kh]http://www.youtube.com/v/AHT6ZUR3qiQ&hl[/flash:3e0cw7kh]
                                  Curvizard 1.1 requires an upgrade to LibFredo6 4.7 or higher.
                                  • utilerU
                                    utiler
                                    Double WOW!!! Thank you Fredo. I can't say enough about what you contribute to my SketchUp workflow....! 👍 👍 👍
                                    Just Curious...
                                    • guanjinG
                                      guanjin
                                      Thanks for update again, but the language translation problems still exist, thank you!
                                        Research of the perfect voluptuous inaccessible curves! ☀
                                        • pbacotP
                                          Thank you Fredo! This looks fantastic. Thanks for everything...looking of Donate button.
                                          • cottyC
                                            cotty
                                            Thank you not only for the impressive plugin, but also especially for the excellent and detailed documentation (PDF)!
                                            my SketchUp gallery
                                            • 2 / 10
