    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 718.6k Views 121 Watching
    • fredo6F Offline
      fredo6
      The information on FredoTools is maintained on the Plugin Home Page of FredoTools. This is also where you can download the RBZ file.
      • LibFredo v14.3b or above
      • SU2017 and above
      If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
      FredoTools groups a number of my standalone plugins, some already published, some new. By delivering them as a single package, it reduces the footprint on Sketchup:
      • A single folder in the Plugins directory (Fredo6_FredoTools)
      • A single menu entry (by default in Tools > FredoTools)
      • A single contextual menu
      • A single toolbar, with control of the icons displayed
      • A Quick Launcher
      • Also, only a small part of the plugins is loaded at Sketchup startup (only the menus). The rest of the code is loaded the first time you launch the plugin
      Plugins currently included in FredoTools are:
      • DrawAlong
      • MoveAlong
      • ThruPaint
      • ReverseOrientFaces
      • EdgeInspector
      • ColorBySlope
      • ColorByAltitude
      • ColorPaint
      • ColorFlatMode
      • AngleInspector
      • ReportLabelArea
      • ElementStats
      • DivideEdges
      • AutoReverseFaces
      • Convexify
      • SolidVolume
      • RevertCurve
      • CurviShear
      • ConstructFaceNormal
      • MarkVertices
      • CountFacesBySides
      • RemoveLonelyVertices
      • FaceTriangulator
      Tools are documented individually in their own thread.
      Most tools have their own videos included in their individual threads.
      There is a good overview of most tools in a tutorial designed by Tutorials Up.
        Thanks Fredo
        ThruPaint is very useful. ๐Ÿ‘
        • fredo6F Offline
          fredo6
          Oooops!! ThruPaint is not ready yet. It was in the release by mistake.
          Fredo
          • kenK Offline
            ken
            Fredo
            Is there anyway to prevent the loading in the contextual menu? I try to keep as much as I can away from the contextual menu.
            Thanks in advance
            Ken
              I won't use it ๐Ÿ˜‰
                driven
                the pin is a great idea...
                all seems to work on mac...
                from additional folders on and off...
                john
                PS. I had to manually remove .._DIR_42, it wouldn't 'purge' from the additional folder, should it?
                john
                • fredo6F Offline
                  fredo6
                  Normally you don't need to remove it. It should work even if present, as 43 > 42.
                  Did you see it in the Purge Obsolete Files... dialog box?
                  Fredo
                    driven
                    I saw it there, and tried both 'delete all' and then individuals 'delete' when it was the only one left.
                    the standalone rubies all purged fine.
                    john
                    • fredo6F Offline
                      fredo6
                      Sorry for that. I usually do it for the other plugins. So, try version 1.0b and go to the Default Parameters dialog box.
                      Fredo
                      • MALAISEM Offline
                        MALAISE
                        Nice Fredo, ๐Ÿ‘ ........ ๐Ÿ‘ So we have more space for drawing. ๐Ÿ˜†
                        Pierre
                        La Connaissance n'a de valeur que partagรฉe
                          Un petit cadeau de Noรซl ๐Ÿ˜‰
                          A little Chrismas gift ๐Ÿ˜‰
                          • erikBE Offline
                            erikB
                            Very handy fredo !!!
                            thanks ( and happy holidays !)
                            erikB
                            • P Offline
                              Panga
                              Thanks a lot Fredo, nice addition. ๐Ÿ‘
                                RichardCherry
                                Thanks for the nice Christmas present ๐Ÿ˜„
                                Wonderful set of tools ๐Ÿ˜„
                                • V Offline
                                  Vicspa
                                  Ditto Fredo ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                  • irwanwrI Offline
                                    irwanwr
                                    no curviloft? ๐Ÿ˜ž
                                      boilingsnow
                                      Can you tell why I can't load the plugin?
                                      I have already installed the latest version of LibFredo6.
                                      • fredo6F Offline
                                        fredo6
                                        Can you check the footprint of the files.
                                        In the Plugins directory, you should have the Folder FREDOTOOLS_Dir_10 with all the files in it.
                                        It looks like you have the rb files directly in the Plugins directory, not in this folder.
                                        Fredo
                                          boilingsnow
                                          Fredo
                                          Thanks for your explanation. It works!
                                          • halroachH Offline
                                            halroach
                                            Hi Fredo,
                                            very nice plugin!
                                            I've been thinking of a similar plugin, which you could incorporate into this one:
                                            1. For planning and adjusting areas of a house (to suit program requirements) - it would be nice to have the option to save a selection of faces, and see how the areas update as you change them in sketchup.
                                              You have the "areas report" window on ALL THE TIME. You select the faces and components you want once - which gives you the areas. After that you can continue editing the model and the numbers change as you drag lines and change areas - kind of like a set of "entity infos" open all the time for a specific set of pre selected faces. If it cannot be updated "live" you could have an update button (with a keyboard shortcut of course) that would update the info in the box + the different tags.
                                            see attached mockup image (numbers are just gibberish for illustration)
                                            1. you could have selection sets in pre selected colors for interiors, exteriors etc... kind of like the areas by material, but rather by custom selection.
                                            2. you could have sub-totals for faces that were marked together.
                                            3. selecting a face or faces in the list will mark them in the model
                                            4. I noticed that if I use the standard tool for marking the area of a face in a scaled component, it will show the same area for the component in each of it's differently scaled instances (which makes sense). By what I've noticed, your plugin knows how to over come that, right?
                                            ![live or manually updated "areas report" for pre selected faces](/uploads/imported_attachments/Rgwk_preselectedfaceareas.jpg "live or manually updated "areas report" for pre selected faces")
                                            FlexTools - Super Quick Windows, Doors, Slats...
                                            • 23
                                            • 24
                                            • 1 / 24
