    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 836.4k Views 121 Watching
      driven
      I saw it there, and tried both 'delete all' and then individuals 'delete' when it was the only one left.
      the standalone rubies all purged fine.
      • fredo6F
        Is there anyway to prevent the loading in the contextual menu? I try to keep as much as I can away from the contextual menu.
        Sorry for that. I usually do it for the other plugins. So, try version 1.0b and go to the Default Parameters dialog box.
        • MALAISEM
          MALAISE
          Nice Fredo, 👍 ........ 👍 So we have more space for drawing. 😆
          Pierre
            Un petit cadeau de Noël 😉
            A little Chrismas gift 😉
            • erikBE
              erikB
              Very handy fredo !!!
              thanks ( and happy holidays !)
              erikB
              • P
                Panga
                Thanks a lot Fredo, nice addition. 👍
                  RichardCherry
                  Thanks for the nice Christmas present 😄
                  Wonderful set of tools 😄
                  • V
                    Vicspa
                    Ditto Fredo 👍 👍 👍
                    • irwanwrI
                      irwanwr
                      no curviloft? 😞
                      • B
                        boilingsnow
                        Can you tell why I can't load the plugin?
                        I have already installed the latest version of LibFredo6.
                        • fredo6F
                          Can you check the footprint of the files.
                          In the Plugins directory, you should have the Folder FREDOTOOLS_Dir_10 with all the files in it.
                          It looks like you have the rb files directly in the Plugins directory, not in this folder.
                          • B
                            boilingsnow
                            Thanks for your explanation. It works!
                            • halroachH
                              halroach
                              Hi Fredo,
                              very nice plugin!
                              I've been thinking of a similar plugin, which you could incorporate into this one:
                              1. For planning and adjusting areas of a house (to suit program requirements) - it would be nice to have the option to save a selection of faces, and see how the areas update as you change them in sketchup.
                                You have the "areas report" window on ALL THE TIME. You select the faces and components you want once - which gives you the areas. After that you can continue editing the model and the numbers change as you drag lines and change areas - kind of like a set of "entity infos" open all the time for a specific set of pre selected faces. If it cannot be updated "live" you could have an update button (with a keyboard shortcut of course) that would update the info in the box + the different tags.
                              see attached mockup image (numbers are just gibberish for illustration)
                              1. you could have selection sets in pre selected colors for interiors, exteriors etc... kind of like the areas by material, but rather by custom selection.
                              2. you could have sub-totals for faces that were marked together.
                              3. selecting a face or faces in the list will mark them in the model
                              4. I noticed that if I use the standard tool for marking the area of a face in a scaled component, it will show the same area for the component in each of it's differently scaled instances (which makes sense). By what I've noticed, your plugin knows how to over come that, right?
                              ![live or manually updated "areas report" for pre selected faces](/uploads/imported_attachments/Rgwk_preselectedfaceareas.jpg "live or manually updated "areas report" for pre selected faces")
                              FlexTools - Super Quick Windows, Doors, Slats...
                              • fredo6F
                                This is possible, but this requires a slightly different design, especially because you need this information to be persistent across Sketchup sessions. I may give it a try whenever I have time, either as an extension of the plugin or as a new plugin.
                                1. I noticed that if I use the standard tool for marking the area of a face in a scaled component, it will show the same area for the component in each of it's differently scaled instances (which makes sense). By what I've noticed, your plugin knows how to over come that, right?
                                Yes, the plugin counts the real areas within each component, taking into account the scaling factor and shear factor.
                                • halroachH
                                  halroach
                                  This is possible, but this requires a slightly different design, especially because you need this information to be persistent across Sketchup sessions. I may give it a try whenever I have time, either as an extension of the plugin or as a new plugin.Fredo
                                  That would be really cool Fredo!
                                  I'd be glad to contribute with the conceptual design whenever you get around to it. I may have some further ideas as to how this tool could be useful, more effective and easy to use.
                                  • fredo6F
                                    Your comments are welcome. I am not really user of the tool, and it's good to hear from users who have practice and requirement about areas in Sketchup.
                                      DesignerPro
                                      Tried the new curveloft tool set. This is all the errors it generates when I open SketchUp. 😞
                                      Now WHAT? 😐
                                      Error Loading File bootstrap_Curviloft.rb
                                      uninitialized constant Curviloft::T6Error Loading File CurviloftAlgo.rb
                                      uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
                                      uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
                                      uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
                                      uninitialized constant Curviloft::T6Error Loading File FredoTools.rb
                                      uninitialized constant FredoTools::T6Error Loading File FredoTools__ConstructFaceNormal.rb
                                      undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__CountFacesBySides.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__CurviShear.rb
                                      undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__MarkVertices.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__RemoveLonelyVertices.rb
                                      undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__ReportLabelArea.rb undefined method register_plug' for FredoTools:ModuleError Loading File FredoTools__RevertCurve.rb
                                      undefined method register_plug' for FredoTools:ModuleError Loading File __loader.rb undefined method effective_load' for nil:NilClass
                                      • fredo6F
                                        @DesignerPro
                                        This seems to be a problem of installation, probably coming from an erroneous unzip operation.
                                        The right footprint is indicated in the first post:
                                        • file LibFredo6.rb
                                        • Folder LIBFREDO6_Dir_43
                                        • Folder FREDOTOOLS_Dir_10
                                        • N
                                          niks
                                          thank you very much fredo 👍
                                          • H
                                            hebeijianke
                                            thanks fredo
                                            chinese language
                                            FredoTools_CN.lang
                                            • 23
                                            • 24
                                            • 1 / 24
