    Batch rendering?
    renderpluginsextensions
    37 Posts 15 Posters 33.7k Views 15 Watching
      dav21
      How can i do rendering like this? The second one starts when first one finishes. there are two files. When the second one finishes and gets completed the third one starts, so on and so forth. Is there an option in vray for su too like this? Many times all the modeling gets complete and all the views are set. There's only the need to hit the render button and go for dinner 😄.
        lvl1201
        It is very simple.
        First you set up your scenes in sketchup.
        Scene1 scene2 scene 3 etc
        In some older version of vray the scene 1 will be rendered 2 times in version 1.49.01 this no longer happens.
        In sketchup go to view/animation/settings enable scene transition with 0 seconds.
        And below that put the scene delay to 1 second.
        Now in vray option be sure to have batch render enabled (options/globalsiwtches/batch render)
        Then go to the output section, select render output save and name the file whatever you want, i always use simple things like A,B or C.
        Below select animation on, instead of NTSC select in the frame rate custom, fps=1 and enable the include frame number thingie.
        Yes i want to become an Architect.
        Yes im pretty close to that.
        • rodrigonotorR Offline
          rodrigonotor
          In sketchup, make the number of scenes what you need to render.
          First. In Menu: View->Animation->settings
          Disable Scene transitions and put scene delay = 1
          http://img199.imageshack.us/img199/9763/10092011012339pm.png
          Second. In V-ray->options->Output
          Check the animation On
          http://img263.imageshack.us/img263/3866/10092011011639pm.png
          Last. Go to dinner.
          Regards
          • Sketchando.net • www.arqcad.net •
          • bagateloB Offline
            bagatelo
            Is not needed to assign on "Save file"? And the option "Batch render"?
            Last. Go to dinner.
            Regards
              rodrigonotor
              Sorry. Yep, you have to check the save option and put a name.
                rendell2009
                how can we play the render animation in SU?
                  rodrigonotor
                  Menu->View->Animation->Play
                  http://img718.imageshack.us/img718/8482/12112011070011pm.jpg
                  • V Offline
                    valerostudio
                    It sounded like the question was asking about rendering different files and not different scenes of the same file. If this is the case, the answer is no. You cannot setup renderings for different files to batch.
                    • peter_shawP Offline
                      peter_shaw
                      BUT if you have multiple files, you could merge them to 1 file (copy paste) and do it the way described here, with scenes
                      in addition, u can use something like http://sourceforge.net/projects/shutdown/ to shut down your PC after it finished rendering (use the CPU usage option).
                      btw: this is my first post here, hello! 🎉
                        davelee100
                        Am I missing something here?
                        I follow the instructions above but don't know how to actually set the rendering in motion as nothing I try works.
                        I click render and the screen scrolls rapidly through the scene tabs and the frame buffer renders all the scenes one by one but why are the renders not being stored as JPEGs in the folder that I assigned on my hard drive?
                        If I export using sketchups export option I get all the scenes saved as you see them on the sketchup screen but I want the vray rendered images... Can anyone help please?
                        Dave
                        • andybotA Offline
                          andybot
                          @davelee: which version of vfsu? Also, is the vray frame buffer window (render window) showing up? If not, can you do a rendering without animation from that file? If you don't see the window, the render isn't happening.
                            davelee100
                            I am using the latest version for the mac 1.49 i think.
                            The frame buffer shows yes and I see the scenes render one by one on the screen but only on the screen. Shouldn't they save out to my drive?
                            Ill try rendering one scene to disk as per your advice.
                            • andybotA Offline
                              andybot
                              It sounds like the render works fine. You need to make sure in your output option you have an autosave file name specified.
                              • V Offline
                                valerostudio
                                You also have to make sure you have INCLUDE FRAME NUMBER ticked on.
                                • FlatchoumF Offline
                                  Flatchoum
                                  Hello, I don't know wether or not Davelle solved his problem, but I do have the same one, with sketchup 8 and I think the last version of VFSU, but on PC. The batch rendering operates, but doesn't save the picture files anywhere, that's very frustrating. Any idea?
                                  • panixiaP Offline
                                    panixia
                                    did you check "enable scene transition" in sketchup animation settings???
                                      Flatchoum
                                      Yes I did, the scenes render, but just don't get saved anywhere...
                                        Flatchoum
                                        HI, still haven't found a solution, except for wacking up every hour last night, change scenes manually, pray and go back to bed...for one hour. I tryed several ways, calculating pictures of 5x5...They always calculate but don't get saved anywhere. I wish I could find a solution before the end of this world, please help!
                                        • ATLAStudioA Offline
                                          ATLAStudio
                                          This tutorial has fairly comprehensive options setup, not sure if it'll solve the issues though as haven't tried animation myself.
                                          http://sketchupvrayresources.blogspot.co.uk/2011/08/tutorial-vray-sketchup-animation.html
                                          http://www.atlas-studio.co.uk
                                          • andybotA Offline
                                            andybot
                                            Just a simple thing to check - have you specified a file name for your saved images? You have to have autosave enabled so vray can save your images.
                                            • 1 / 2
