    Batch rendering?
    renderpluginsextensions
    37 Posts 15 Posters 33.8k Views 15 Watching
      lvl1201
      It is very simple.
      First you set up your scenes in sketchup.
      Scene1 scene2 scene 3 etc
      In some older version of vray the scene 1 will be rendered 2 times in version 1.49.01 this no longer happens.
      In sketchup go to view/animation/settings enable scene transition with 0 seconds.
      And below that put the scene delay to 1 second.
      Now in vray option be sure to have batch render enabled (options/globalsiwtches/batch render)
      Then go to the output section, select render output save and name the file whatever you want, i always use simple things like A,B or C.
      Below select animation on, instead of NTSC select in the frame rate custom, fps=1 and enable the include frame number thingie.
      Yes i want to become an Architect.
      Yes im pretty close to that.
      • rodrigonotorR Offline
        rodrigonotor
        In sketchup, make the number of scenes what you need to render.
        First. In Menu: View->Animation->settings
        Disable Scene transitions and put scene delay = 1
        http://img199.imageshack.us/img199/9763/10092011012339pm.png
        Second. In V-ray->options->Output
        Check the animation On
        http://img263.imageshack.us/img263/3866/10092011011639pm.png
        Last. Go to dinner.
        Regards
        • Sketchando.net • www.arqcad.net •
        • bagateloB Offline
          bagatelo
          Is not needed to assign on "Save file"? And the option "Batch render"?
          Last. Go to dinner.
          Regards
            rodrigonotor
            Sorry. Yep, you have to check the save option and put a name.
              rendell2009
              how can we play the render animation in SU?
                rodrigonotor
                Menu->View->Animation->Play
                http://img718.imageshack.us/img718/8482/12112011070011pm.jpg
                • V Offline
                  valerostudio
                  It sounded like the question was asking about rendering different files and not different scenes of the same file. If this is the case, the answer is no. You cannot setup renderings for different files to batch.
                  • peter_shawP Offline
                    peter_shaw
                    BUT if you have multiple files, you could merge them to 1 file (copy paste) and do it the way described here, with scenes
                    in addition, u can use something like http://sourceforge.net/projects/shutdown/ to shut down your PC after it finished rendering (use the CPU usage option).
                    btw: this is my first post here, hello! 🎉
                      davelee100
                      Am I missing something here?
                      I follow the instructions above but don't know how to actually set the rendering in motion as nothing I try works.
                      I click render and the screen scrolls rapidly through the scene tabs and the frame buffer renders all the scenes one by one but why are the renders not being stored as JPEGs in the folder that I assigned on my hard drive?
                      If I export using sketchups export option I get all the scenes saved as you see them on the sketchup screen but I want the vray rendered images... Can anyone help please?
                      Dave
                      • andybotA Offline
                        andybot
                        @davelee: which version of vfsu? Also, is the vray frame buffer window (render window) showing up? If not, can you do a rendering without animation from that file? If you don't see the window, the render isn't happening.
                          davelee100
                          I am using the latest version for the mac 1.49 i think.
                          The frame buffer shows yes and I see the scenes render one by one on the screen but only on the screen. Shouldn't they save out to my drive?
                          Ill try rendering one scene to disk as per your advice.
                          • andybotA Offline
                            andybot
                            It sounds like the render works fine. You need to make sure in your output option you have an autosave file name specified.
                            • V Offline
                              valerostudio
                              You also have to make sure you have INCLUDE FRAME NUMBER ticked on.
                              • FlatchoumF Offline
                                Flatchoum
                                Hello, I don't know wether or not Davelle solved his problem, but I do have the same one, with sketchup 8 and I think the last version of VFSU, but on PC. The batch rendering operates, but doesn't save the picture files anywhere, that's very frustrating. Any idea?
                                • panixiaP Offline
                                  panixia
                                  did you check "enable scene transition" in sketchup animation settings???
                                    Flatchoum
                                    Yes I did, the scenes render, but just don't get saved anywhere...
                                      Flatchoum
                                      HI, still haven't found a solution, except for wacking up every hour last night, change scenes manually, pray and go back to bed...for one hour. I tryed several ways, calculating pictures of 5x5...They always calculate but don't get saved anywhere. I wish I could find a solution before the end of this world, please help!
                                      • ATLAStudioA Offline
                                        ATLAStudio
                                        This tutorial has fairly comprehensive options setup, not sure if it'll solve the issues though as haven't tried animation myself.
                                        http://sketchupvrayresources.blogspot.co.uk/2011/08/tutorial-vray-sketchup-animation.html
                                        http://www.atlas-studio.co.uk
                                        • andybotA Offline
                                          andybot
                                          Just a simple thing to check - have you specified a file name for your saved images? You have to have autosave enabled so vray can save your images.
                                            pierreaudouin
                                            I also had this problem recording.
                                            I did a search in windows and the files were stored in TEMP / vfstextureCache.
                                            I hope you find it!
