    Batch rendering?
    renderpluginsextensions
    37 Posts 15 Posters 33.5k Views 15 Watching
    • peter_shawP Offline
      peter_shaw
      @valerostudio said:
      It sounded like the question was asking about rendering different files and not different scenes of the same file. If this is the case, the answer is no. You cannot setup renderings for different files to batch.
      BUT if you have multiple files, you could merge them to 1 file (copy paste) and do it the way described here, with scenes
      in addition, u can use something like http://sourceforge.net/projects/shutdown/ to shut down your PC after it finished rendering (use the CPU usage option).
      btw: this is my first post here, hello! 🎉
        davelee100
        Am I missing something here?
        I follow the instructions above but don't know how to actually set the rendering in motion as nothing I try works.
        I click render and the screen scrolls rapidly through the scene tabs and the frame buffer renders all the scenes one by one but why are the renders not being stored as JPEGs in the folder that I assigned on my hard drive?
        If I export using sketchups export option I get all the scenes saved as you see them on the sketchup screen but I want the vray rendered images... Can anyone help please?
        Dave
        • andybotA Offline
          andybot
          @davelee: which version of vfsu? Also, is the vray frame buffer window (render window) showing up? If not, can you do a rendering without animation from that file? If you don't see the window, the render isn't happening.
            davelee100
            I am using the latest version for the mac 1.49 i think.
            The frame buffer shows yes and I see the scenes render one by one on the screen but only on the screen. Shouldn't they save out to my drive?
            Ill try rendering one scene to disk as per your advice.
            • andybotA Offline
              andybot
              It sounds like the render works fine. You need to make sure in your output option you have an autosave file name specified.
              • V Offline
                valerostudio
                You also have to make sure you have INCLUDE FRAME NUMBER ticked on.
                • FlatchoumF Offline
                  Flatchoum
                  Hello, I don't know wether or not Davelle solved his problem, but I do have the same one, with sketchup 8 and I think the last version of VFSU, but on PC. The batch rendering operates, but doesn't save the picture files anywhere, that's very frustrating. Any idea?
                  • panixiaP Offline
                    panixia
                    did you check "enable scene transition" in sketchup animation settings???
                      Flatchoum
                      Yes I did, the scenes render, but just don't get saved anywhere...
                        Flatchoum
                        HI, still haven't found a solution, except for wacking up every hour last night, change scenes manually, pray and go back to bed...for one hour. I tryed several ways, calculating pictures of 5x5...They always calculate but don't get saved anywhere. I wish I could find a solution before the end of this world, please help!
                        • ATLAStudioA Offline
                          ATLAStudio
                          This tutorial has fairly comprehensive options setup, not sure if it'll solve the issues though as haven't tried animation myself.
                          http://sketchupvrayresources.blogspot.co.uk/2011/08/tutorial-vray-sketchup-animation.html
                          http://www.atlas-studio.co.uk
                          • andybotA Offline
                            andybot
                            Just a simple thing to check - have you specified a file name for your saved images? You have to have autosave enabled so vray can save your images.
                              pierreaudouin
                              I also had this problem recording.
                              I did a search in windows and the files were stored in TEMP / vfstextureCache.
                              I hope you find it!
                                pierreaudouin
                                @lvl1201 said:
                                In some older version of vray the scene 1 will be rendered 2 times in version 1.49.01 this no longer happens.
                                I have the last version of Vray (1.49.01), but the first scene is rendered two times!!!
                                I don't know why.
                                Is it the same for you?
                                  Flatchoum
                                  Thanks for your answers, I still have the same problem; to Andybot, yes I specified a name, and to PierreAudouin, I'm very surprised, it looks like I don't have such a file named vfstextureCache? I looked for it, I don't think I have Hidden files, on Windows 7... Still trying to do a Batch rendering now, I hope 2013 gives me the answer. I'm on Sketchup 8 and bought my Vrayfor SU version in August. To Pierre, you must have an option like "reboot on first scene"?
                                    Flatchoum
                                    Wow! I just looked again, and I finally found the pictures! They were hidden in the OS(C:)/User/(Me)/AppData/Local/Temp/VfsTextureCache!!!
                                    Thank god I can now work and sleep 8 hours in a row!! And Special thanks to PierreAudouin too, you were right! I just wonder why the pics are saved ther and not where I told Vray to save it? an other bug? And the search tool on windows 7 is just useless, perhaps should I stay on a mac next time I buy a Computer...This little gag almost cost me a project
                                      pierreaudouin
                                      Yes, good, this is 2013!!!
                                      Happy new year!
                                      it's weird, it is thanks to the windows search tool I have found my files.
                                      Good for you.
                                      I search "reboot on first scene".I don't have option like this.
                                      it doesn't matter,but if you have a solution...
                                        Flatchoum
                                        Happy new year too! I can't find this option any more, but I'm pretty sure it was part of the previous sketchup versions. By the way I also have the first scene doubled in my file this morning...And they look strictly the same? Now I have a little bug with the "face me components": some of them are grouped at the origin of the axes...Weird, but I may find an explanation on this forum...
                                          peter_shaw
                                          is it possible to change layer states during a batch render? i'm trying to render an animation made with SU animate, but vray only seems to accept the layer state of the first scene.
                                          check the attachement to see what i mean
                                          Untitled.skp
                                          • andybotA Offline
                                            andybot
                                            unfortunately, no. That's just the way vray works currently. It only loads the model once at the beginning for batch rendering.
