    Batch rendering?
    renderpluginsextensions
    37 Posts 15 Posters 33.5k Views 15 Watching
    • andybotA Offline
      andybot
      @davelee: which version of vfsu? Also, is the vray frame buffer window (render window) showing up? If not, can you do a rendering without animation from that file? If you don't see the window, the render isn't happening.
        davelee100
        I am using the latest version for the mac 1.49 i think.
        The frame buffer shows yes and I see the scenes render one by one on the screen but only on the screen. Shouldn't they save out to my drive?
        Ill try rendering one scene to disk as per your advice.
        • andybotA Offline
          andybot
          It sounds like the render works fine. You need to make sure in your output option you have an autosave file name specified.
          • V Offline
            valerostudio
            You also have to make sure you have INCLUDE FRAME NUMBER ticked on.
            • FlatchoumF Offline
              Flatchoum
              Hello, I don't know wether or not Davelle solved his problem, but I do have the same one, with sketchup 8 and I think the last version of VFSU, but on PC. The batch rendering operates, but doesn't save the picture files anywhere, that's very frustrating. Any idea?
              • panixiaP Offline
                panixia
                did you check "enable scene transition" in sketchup animation settings???
                  Flatchoum
                  Yes I did, the scenes render, but just don't get saved anywhere...
                    Flatchoum
                    HI, still haven't found a solution, except for wacking up every hour last night, change scenes manually, pray and go back to bed...for one hour. I tryed several ways, calculating pictures of 5x5...They always calculate but don't get saved anywhere. I wish I could find a solution before the end of this world, please help!
                    • ATLAStudioA Offline
                      ATLAStudio
                      This tutorial has fairly comprehensive options setup, not sure if it'll solve the issues though as haven't tried animation myself.
                      http://sketchupvrayresources.blogspot.co.uk/2011/08/tutorial-vray-sketchup-animation.html
                      http://www.atlas-studio.co.uk
                      • andybotA Offline
                        andybot
                        Just a simple thing to check - have you specified a file name for your saved images? You have to have autosave enabled so vray can save your images.
                          pierreaudouin
                          I also had this problem recording.
                          I did a search in windows and the files were stored in TEMP / vfstextureCache.
                          I hope you find it!
                            pierreaudouin
                            @lvl1201 said:
                            In some older version of vray the scene 1 will be rendered 2 times in version 1.49.01 this no longer happens.
                            I have the last version of Vray (1.49.01), but the first scene is rendered two times!!!
                            I don't know why.
                            Is it the same for you?
                              Flatchoum
                              Thanks for your answers, I still have the same problem; to Andybot, yes I specified a name, and to PierreAudouin, I'm very surprised, it looks like I don't have such a file named vfstextureCache? I looked for it, I don't think I have Hidden files, on Windows 7... Still trying to do a Batch rendering now, I hope 2013 gives me the answer. I'm on Sketchup 8 and bought my Vrayfor SU version in August. To Pierre, you must have an option like "reboot on first scene"?
                                Flatchoum
                                Wow! I just looked again, and I finally found the pictures! They were hidden in the OS(C:)/User/(Me)/AppData/Local/Temp/VfsTextureCache!!!
                                Thank god I can now work and sleep 8 hours in a row!! And Special thanks to PierreAudouin too, you were right! I just wonder why the pics are saved ther and not where I told Vray to save it? an other bug? And the search tool on windows 7 is just useless, perhaps should I stay on a mac next time I buy a Computer...This little gag almost cost me a project
                                  pierreaudouin
                                  Yes, good, this is 2013!!!
                                  Happy new year!
                                  it's weird, it is thanks to the windows search tool I have found my files.
                                  Good for you.
                                  I search "reboot on first scene".I don't have option like this.
                                  it doesn't matter,but if you have a solution...
                                    Flatchoum
                                    Happy new year too! I can't find this option any more, but I'm pretty sure it was part of the previous sketchup versions. By the way I also have the first scene doubled in my file this morning...And they look strictly the same? Now I have a little bug with the "face me components": some of them are grouped at the origin of the axes...Weird, but I may find an explanation on this forum...
                                    • peter_shawP Offline
                                      peter_shaw
                                      is it possible to change layer states during a batch render? i'm trying to render an animation made with SU animate, but vray only seems to accept the layer state of the first scene.
                                      check the attachement to see what i mean
                                      Untitled.skp
                                      • andybotA Offline
                                        andybot
                                        unfortunately, no. That's just the way vray works currently. It only loads the model once at the beginning for batch rendering.
                                          pierreaudouin
                                          and i ask the same question with camera setting (focal, aspect ratio...)?
                                            peter_shaw
                                            only position if i remember correctly
