    Top 3 SU plugins
    80 Posts 40 Posters 20.4k Views 40 Watching
    • K Offline
      kate-art
      As i'm relatively new to SketchUp i'm keen to find out which plugins you guys use to get the most out of SketchUp. There are no shortage to choose from but if you could only insall 3 what would they be and why?
      my top 3 are:
      Fur
      Round corners
      Shaderlight (of course!)
      Shaderlight delivers interactive, photorealistic rendering to Google SketchUp. Download it for FREE at http://www.shaderlight.com
      • soloS Offline
        solo
        SDS (Subdivide and smooth)
        Cleanup
        round corner
        (used most often)
        http://www.solos-art.com
          Fredoscale
          Bezier Tools
          Thea Exporter
            • Selection Toys
            • Tools On Surface
            • Plan Tools
            • boofredlayB Offline
              boofredlay
              Weld
              Round Corners
              Joint Push Pull
              (Subdivide and Smooth) Honorable mention.
              • ely862meE Offline
                ely862me
                SDS
                JPP
                TOS
                Elisei (sketchupper)
                Come and See EliseiDesign
                • charly2008C Offline
                  charly2008
                  • Curviloft
                  • Extrusion Tools
                  • Kerkythea Exporter
                    Daniel S
                    • Round Corners
                    • Curviloft
                    • SketchyPhysics
                    • BurkhardB Offline
                      Burkhard
                      Round Corners
                      CleanUp
                      Delete Cons ( Seems I worked to much with Lines and points )
                      http://www.ia-plus.de
                        rv1974
                        1.extrude line
                        2.extrude along path
                        3.mirror
                          It deletes construction lines and points? That's a native function...
                          • Chris FullmerC Offline
                            @ely862me said:
                            SDS
                            JPP
                            TOS
                            To translate that - SubDivide and Smooth, Joint PushPull, and Tools On Surface.
                            Mine are:
                            Weld
                            Make Faces
                            Repeat Copy
                            All my Plugins I've written
                            • TIGT Online
                              But the built-in one is brutal and removes all - some such as this erase all cpoints/clines in the current context only ?
                              • TIGT Online
                                My three most commonly used tools:
                                Weld
                                Make Face
                                Mirror
                                • mitcorbM Offline
                                  mitcorb
                                  Fredo PushPull--Joint,Vector,Normal
                                  Mirror Selection
                                  FredoScale,Taper,Bend
                                  • KrisidiousK Offline
                                    Krisidious
                                    Weld
                                    Curviloft
                                    Thom's Curve Select
                                    By: Kristoff Rand
                                      tfdesign
                                      This is a good thread, as I was also about to ask the same question- but for ten plugins(!).
                                      Three is a good number, but what still confuses me, and probably others too, who are new to SketchUp is why.
                                      Why do you use these plugins, and what advantages to they give you over the current set of tools, and what is your main objective, taking into account, your chosen subject? For eg, are you an architect? A product designer or just a general modeller? Why are these three so important?
                                      I've started to experiment with Fredo6's Bezierspline plugin, mainly because it is impossible to draw bezier curves by any other way in SketchUp, and bezier curves come in hand for many things, both architectural and product-wise.
                                      I'll probably also add Fredo6's Curviloft plugin too, because the creation of organic surfaces that morph from one shape to another can also have its use, especially when modelling Victorian rendering- such as plaster.
                                      One more only would be very hard to suggest, as many are so brilliant and useful!
                                      Tom
                                      My book "Let's SketchUp!" Download from here
                                        Weld
                                        CutList
                                        BZ Spline
                                          tfdesign
                                          Why?
                                            Weld: To weld line segments so they behave as single entities for selection purposes and to reduce the need to soften/smooth edges.
                                            CutList: Nearly every project I draw these days is a plan for a piece of furniture or cabinets and my clients require cut lists so they can quote for materials. I could do it manually but Cut List takes only a couple of seconds.
                                            BZ Spline: For drawing non-circular curves.
                                            • 1 / 4
