    Most annoying SU behavior
    39 Posts 15 Posters 8.2k Views 15 Watching
    • O Offline
      otb designworks
      has got to be that a new layer is on by default on every scene.
      So, if I have a model with 25 scenes, all set up nicely for Layout, and I need to add a new layer for something or another, then I have to manually go through all 25 scenes and turn it back off?!
      By far, for me, the most inefficient aspect of SU. And counterintuitive as heck; new layers should be OFF by default.
      Cheers, Chuck
      OTB Designworks is on Youtube
        dedmin
        Use this plugin - http://www.srww.com/blog/wp-content/uploads/2010/05/layers.zip
        • jgbJ Offline
          jgb
          The s/w behind scenes is a work-in-progress, with no progress.
          You can only have 1 scene set, and it sits there at screen top. It is cumbersome to edit, and gives only a single timing scenario for the entire set. πŸ‘Ž
          πŸ’­ What's needed is a scenes library/manager, where you can define any number of scene sets and call them up as desired, for edit or display.
          πŸ’­ You should be able to set a time-on-screen for each scene as well as a time for transition.
          πŸ’­ It does a nice smooth pan/zoom between transitions, but no fades. A few transition (2 or 3 tops) fades would be nice, maybe even a morphing transition.
          πŸ’­ As stated above by OTB Designworks layer management needs to be overhauled, with more control over handling new layers, and globally on layers within sub sets of scenes.
          πŸ’­ You also need a way to cycle a sub-set of scenes for testing or close review, rather than only the full play as is now.
          There are probably several other enhancements that could be done, but I haven't played with scenes enough to define them yet.
          jgb
          • O Offline
            otb designworks
            I really like the idea of scene sets; I had never thought of that as an option. I could see that being quite useful
            Much thanks for that plugin link; that is going to improve things around here!
            Cheers, Chuck
            • O Offline
              otb designworks
              On further review, this ruby does nothing on my system.
              It gives me the input dialogue windows, but no new layers appear, and the hide/show layers has no effect either.
              Maybe a MAC thing or a SU8 thing?
              Cheers, Chuck
                Try Jim's plugin then:
                http://sketchuptips.blogspot.com/2007/08/add-hidden-layer.html
                • O Offline
                  otb designworks
                  Perfect! Much thanks.
                  Cheers, Chuck
                  • John SayersJ Offline
                    John Sayers
                    I find it annoying that the program always opens with the line tool instead of the select arrow.
                      You need this [free] http://www.smustard.com/script/SelectAtStartup
                        tfdesign
                        That's odd. It must be a PC thing because the Mac version (or my Mac version anyway) starts with the selection tool. A windows bug?
                        Edit; Is it something to do with how you've saved a template as? I always make my own template. Perhaps the default starts with the line tool, and making a template, to get rid of Sang, would leave you with the selection tool, which is then saved as a tool pref with the template?
                        My book "Let's SketchUp!" Download from here
                        • honoluludesktopH Offline
                          honoluludesktop
                          Tom, Not 100% sure, but I think he means when you select a skp from Sketchup.
                            Are you sure you don't have a plugin installed that modifies this? because there is no option in SU nativly to set which tool SU should activate by default. It's hard-coded to the Pencil tool.
                              tfdesign
                              Nope (I am 100% sure!).
                              To be honest, I've only got a couple of plugins installed, and that's not one of them. Try saving a template with a tool ready to use. It's just an idea. πŸ˜„
                                No - it's not model specific.
                                  tfdesign
                                  Well I can't explain that at all. πŸ˜• But my default is always the select tool. 😲
                                  edit, I'm still on 7.1 btw.
                                    Could be yet another one of SketchUp's "consistencies"... πŸ˜’
                                    • wind-borneW Offline
                                      wind-borne
                                      My Mac always opens with Selection tool, on 6,7 or 8. I don't have any plugins on 6.
                                      "To read between the lines was easier than to follow the text."OSX 10.11.6
                                      %(#BF80BF)[SU 8 pro
                                        how about that. I just fired up my own Mac.
                                        sigh why do they keep on doing things differently for the platforms....
                                          tfdesign
                                          It's a bug then? But for which platform? I can see the usefulness of SU starting with either tool. 😲 πŸ˜•
                                            I wish it was the Select tool that was default, I use that more often than the pencil.
                                            • 2 / 2
