    Most annoying SU behavior
    39 Posts 15 Posters 8.3k Views 15 Watching
      Try Jim's plugin then:
      http://sketchuptips.blogspot.com/2007/08/add-hidden-layer.html
      • O Offline
        otb designworks
        Perfect! Much thanks.
        Cheers, Chuck
        OTB Designworks is on Youtube
        • John SayersJ Offline
          John Sayers
          I find it annoying that the program always opens with the line tool instead of the select arrow.
            You need this [free] http://www.smustard.com/script/SelectAtStartup
              tfdesign
              That's odd. It must be a PC thing because the Mac version (or my Mac version anyway) starts with the selection tool. A windows bug?
              Edit; Is it something to do with how you've saved a template as? I always make my own template. Perhaps the default starts with the line tool, and making a template, to get rid of Sang, would leave you with the selection tool, which is then saved as a tool pref with the template?
              • honoluludesktopH Offline
                honoluludesktop
                Tom, Not 100% sure, but I think he means when you select a skp from Sketchup.
                  Are you sure you don't have a plugin installed that modifies this? because there is no option in SU nativly to set which tool SU should activate by default. It's hard-coded to the Pencil tool.
                    tfdesign
                    Nope (I am 100% sure!).
                    To be honest, I've only got a couple of plugins installed, and that's not one of them. Try saving a template with a tool ready to use. It's just an idea. πŸ˜„
                      No - it's not model specific.
                        tfdesign
                        Well I can't explain that at all. πŸ˜• But my default is always the select tool. 😲
                        edit, I'm still on 7.1 btw.
                          Could be yet another one of SketchUp's "consistencies"... πŸ˜’
                          • wind-borneW Offline
                            wind-borne
                            My Mac always opens with Selection tool, on 6,7 or 8. I don't have any plugins on 6.
                            "To read between the lines was easier than to follow the text."OSX 10.11.6
                            %(#BF80BF)[SU 8 pro
                              how about that. I just fired up my own Mac.
                              sigh why do they keep on doing things differently for the platforms....
                                tfdesign
                                It's a bug then? But for which platform? I can see the usefulness of SU starting with either tool. 😲 πŸ˜•
                                  I wish it was the Select tool that was default, I use that more often than the pencil.
                                    I have used RickW's simple fix forever... http://forums.sketchucation.com/viewtopic.php?p=281923#p281923
                                      honoluludesktop
                                      When I first open Sketchup, even from selecting a skp, it defaults to the "Selection Tool". Once Sketchup is open, and when I open an file from File > Open, the file opens with the "Line Tool". Perhaps the confusion is simply circumstantial.
                                        John Sayers
                                        must be a windows thing. :0
                                        Thanks TIG for the script - works perfectly. πŸ˜„
                                        • jgbJ Offline
                                          jgb
                                          When I first started using SU 3 years ago with V6.0 on my PC, that was the very first thing I complained about in a previous forum.
                                          I was directed to a Ruby plugin fix.
                                          But the select pointer SHOULD be the default startup pointer, not the line or any other construction tool.
                                          It makes no sense otherwise.
                                          jgb
                                          • O Offline
                                            OldNick
                                            Unwanted lines that cause disappearing surfaces when deleted. As far as I can see the disappearance does not always relate to lines bounding areas. Sometimes it's because a surface I did NOT want was formed mysteriously.
                                            I just know that I tried to do a table top, and eve3ry time I rotated the view I would find surfaces gone, surfaces appearing etc.
                                            I actually find that5 creation of surfaces a nuisance: sometimes you just want lines.....this IS "SKETCH-up"
                                            Colour me old fashioned and maybe I need that "paradigm", but I want to be able to create and delete surfaces as I require, not at the whim of the programme.
