    Most annoying SU behavior
    39 Posts 15 Posters 8.3k Views 15 Watching
    • jgbJ Offline
      jgb
      The s/w behind scenes is a work-in-progress, with no progress.
      You can only have 1 scene set, and it sits there at screen top. It is cumbersome to edit, and gives only a single timing scenario for the entire set. πŸ‘Ž
      πŸ’­ What's needed is a scenes library/manager, where you can define any number of scene sets and call them up as desired, for edit or display.
      πŸ’­ You should be able to set a time-on-screen for each scene as well as a time for transition.
      πŸ’­ It does a nice smooth pan/zoom between transitions, but no fades. A few transition (2 or 3 tops) fades would be nice, maybe even a morphing transition.
      πŸ’­ As stated above by OTB Designworks layer management needs to be overhauled, with more control over handling new layers, and globally on layers within sub sets of scenes.
      πŸ’­ You also need a way to cycle a sub-set of scenes for testing or close review, rather than only the full play as is now.
      There are probably several other enhancements that could be done, but I haven't played with scenes enough to define them yet.
      jgb
      • O Offline
        otb designworks
        I really like the idea of scene sets; I had never thought of that as an option. I could see that being quite useful
        Much thanks for that plugin link; that is going to improve things around here!
        Cheers, Chuck
        OTB Designworks is on Youtube
        • O Offline
          otb designworks
          On further review, this ruby does nothing on my system.
          It gives me the input dialogue windows, but no new layers appear, and the hide/show layers has no effect either.
          Maybe a MAC thing or a SU8 thing?
          Cheers, Chuck
            Try Jim's plugin then:
            http://sketchuptips.blogspot.com/2007/08/add-hidden-layer.html
            • O Offline
              otb designworks
              Perfect! Much thanks.
              Cheers, Chuck
              • John SayersJ Offline
                John Sayers
                I find it annoying that the program always opens with the line tool instead of the select arrow.
                  You need this [free] http://www.smustard.com/script/SelectAtStartup
                    tfdesign
                    That's odd. It must be a PC thing because the Mac version (or my Mac version anyway) starts with the selection tool. A windows bug?
                    Edit; Is it something to do with how you've saved a template as? I always make my own template. Perhaps the default starts with the line tool, and making a template, to get rid of Sang, would leave you with the selection tool, which is then saved as a tool pref with the template?
                    • honoluludesktopH Offline
                      honoluludesktop
                      Tom, Not 100% sure, but I think he means when you select a skp from Sketchup.
                        Are you sure you don't have a plugin installed that modifies this? because there is no option in SU nativly to set which tool SU should activate by default. It's hard-coded to the Pencil tool.
                          tfdesign
                          Nope (I am 100% sure!).
                          To be honest, I've only got a couple of plugins installed, and that's not one of them. Try saving a template with a tool ready to use. It's just an idea. πŸ˜„
                            No - it's not model specific.
                              tfdesign
                              Well I can't explain that at all. πŸ˜• But my default is always the select tool. 😲
                              edit, I'm still on 7.1 btw.
                                Could be yet another one of SketchUp's "consistencies"... πŸ˜’
                                • wind-borneW Offline
                                  wind-borne
                                  My Mac always opens with Selection tool, on 6,7 or 8. I don't have any plugins on 6.
                                  "To read between the lines was easier than to follow the text."OSX 10.11.6
                                  %(#BF80BF)[SU 8 pro
                                    how about that. I just fired up my own Mac.
                                    sigh why do they keep on doing things differently for the platforms....
                                      tfdesign
                                      It's a bug then? But for which platform? I can see the usefulness of SU starting with either tool. 😲 πŸ˜•
                                        I wish it was the Select tool that was default, I use that more often than the pencil.
                                          I have used RickW's simple fix forever... http://forums.sketchucation.com/viewtopic.php?p=281923#p281923
                                            honoluludesktop
                                            When I first open Sketchup, even from selecting a skp, it defaults to the "Selection Tool". Once Sketchup is open, and when I open an file from File > Open, the file opens with the "Line Tool". Perhaps the confusion is simply circumstantial.
