    Most annoying SU behavior
    39 Posts 15 Posters 8.3k Views 15 Watching
      tfdesign
      That's odd. It must be a PC thing because the Mac version (or my Mac version anyway) starts with the selection tool. A windows bug?
      Edit; Is it something to do with how you've saved a template as? I always make my own template. Perhaps the default starts with the line tool, and making a template, to get rid of Sang, would leave you with the selection tool, which is then saved as a tool pref with the template?
      • honoluludesktopH Offline
        honoluludesktop
        Tom, Not 100% sure, but I think he means when you select a skp from Sketchup.
          Are you sure you don't have a plugin installed that modifies this? because there is no option in SU nativly to set which tool SU should activate by default. It's hard-coded to the Pencil tool.
            tfdesign
            Nope (I am 100% sure!).
            To be honest, I've only got a couple of plugins installed, and that's not one of them. Try saving a template with a tool ready to use. It's just an idea. πŸ˜„
              No - it's not model specific.
                tfdesign
                Well I can't explain that at all. πŸ˜• But my default is always the select tool. 😲
                edit, I'm still on 7.1 btw.
                  Could be yet another one of SketchUp's "consistencies"... πŸ˜’
                  • wind-borneW Offline
                    wind-borne
                    My Mac always opens with Selection tool, on 6,7 or 8. I don't have any plugins on 6.
                    "To read between the lines was easier than to follow the text."OSX 10.11.6
                    %(#BF80BF)[SU 8 pro
                      how about that. I just fired up my own Mac.
                      sigh why do they keep on doing things differently for the platforms....
                        tfdesign
                        It's a bug then? But for which platform? I can see the usefulness of SU starting with either tool. 😲 πŸ˜•
                          I wish it was the Select tool that was default, I use that more often than the pencil.
                            I have used RickW's simple fix forever... http://forums.sketchucation.com/viewtopic.php?p=281923#p281923
                              honoluludesktop
                              When I first open Sketchup, even from selecting a skp, it defaults to the "Selection Tool". Once Sketchup is open, and when I open an file from File > Open, the file opens with the "Line Tool". Perhaps the confusion is simply circumstantial.
                              • John SayersJ Offline
                                John Sayers
                                must be a windows thing. :0
                                Thanks TIG for the script - works perfectly. πŸ˜„
                                • jgbJ Offline
                                  jgb
                                  @john sayers said:
                                  I find it annoying that the program always opens with the line tool instead of the select arrow.
                                  When I first started using SU 3 years ago with V6.0 on my PC, that was the very first thing I complained about in a previous forum.
                                  I was directed to a Ruby plugin fix.
                                  But the select pointer SHOULD be the default startup pointer, not the line or any other construction tool.
                                  It makes no sense otherwise.
                                  jgb
                                  • O Offline
                                    OldNick
                                    Unwanted lines that cause disappearing surfaces when deleted. As far as I can see the disappearance does not always relate to lines bounding areas. Sometimes it's because a surface I did NOT want was formed mysteriously.
                                    I just know that I tried to do a table top, and eve3ry time I rotated the view I would find surfaces gone, surfaces appearing etc.
                                    I actually find that5 creation of surfaces a nuisance: sometimes you just want lines.....this IS "SKETCH-up"
                                    Colour me old fashioned and maybe I need that "paradigm", but I want to be able to create and delete surfaces as I require, not at the whim of the programme.
                                    • MarianM Offline
                                      Marian
                                      Just found this out.....apparently SU doesn't like having to share resources with Adobe Reader. While I have one or more pdfs open SU doesn't want't to open. I have to close the pdfs and then it works and if I open pdfs again while it's open then both the open and save windows don't appear when I press the button.
                                      This is new behaviour as I haven't noticed it until today. It might have something to do with the fact that I unistalled Adobe Reader X yesterday because it was unstable and reinstalled version 9.40 which works perfect...but now this happens........ugh software..... πŸ˜’
                                        bjornkn
                                        Re selection sets:
                                        You could always save/update all your scenes without any layer visibility stored.
                                        Then you make a few scenes with only the Layer visibility stored,
                                        like L-All, L-NoPlans, L-NoModel and so on.
                                        I do this all the time, as it saves a lot of time and frustrations when working on big projects with lots of layers, versions of dwg-imports etc.
                                        • O Offline
                                          OldNick
                                          OK.. No bro's.
                                          Must just be me. Sorry guys. This kills SU for me
                                          • jeff hammondJ Offline
                                            honestly, this sounds like mistakes on your part.. uploading a model which shows the behavior you're talking about would help understand the problem better but i think it would be more about people pointing out errors you made instead of sketchup errors.
                                            meh.. there are apps out there that work the way you describe.. more times than not, you want the surfaces to auto fill and having to manually fill in surfaces from edges is more of a headache than deleting an occasional undesired surface.. if you want to do a lot of line only drawings in sketchup, use wireframe mode.. surfaces will still be formed though you won't see them.. before you exit wireframe mode, select all the lines you'd like to keep as lines only then copy (ctrlC on windows).. switch to another render mode which shows surfaces then edit->paste in place.. only the lines will be pasted.
