    SketchUP 8
    345 Posts 101 Posters 94.0k Views 101 Watching
    • EscapeArtistE Offline
      EscapeArtist
      Did the upgrade to 8 Free, discovered that I lost about 30% of my plugins on the toolbar. It'll take a bit to go through and figure out which ones vanished.
        tim
        The Google video demonstrating changes to Layout? First example file is my house ๐Ÿ˜‰
        • broomstickB Offline
          broomstick
          also, if you set location and import a mesh (finally in color!) and then open the components dialog you wiil find a category named: nearby buildings, that will import the building on the terrain.
          Also, take notice that solid operations are awesome, but work only for pro... and that's bad
          • wind-borneW Offline
            wind-borne
            @drewpoeppel said:
            Looks like they removed the solar orientation setting in the geolocation area for manually setting the north angle in you model
            Solar North toolbar now but so far can only toggle on/off.
            Bottom two buttons dead at the moment.
            Do work if I put icons into customized toolbar ๐ŸŽ‰
            "To read between the lines was easier than to follow the text."OSX 10.11.6
            %(#BF80BF)[SU 8 pro
            • jeff hammondJ Offline
              jeff hammond
              has anyone used up their 8hrs yet?
              i'm pretty close and i'm just wondering if it reverts to SUfree..
              my company pays for my license but it's going to be another couple of days but i'd like to use it in the meantime..
              (that back edges view is real nice btw.. seems like i'll be using that a lot more often than xray now)
              dotdotdot
              • N Offline
                notareal
                @frederik said:
                You guys are so un-grateful... ๐Ÿ˜
                I like "Susan"... ๐Ÿ˜‰
                +1
                Toolbar fix is nice and also ruby update... seems that SU2Thea freeze (win) is gone by that. General impression for me: some needed bug fixed and some minor new features... but a major version release - it does not add up. I really was expecting 64 bit version.
                • FrederikF Offline
                  Frederik
                  @notareal said:
                  ...but a major version release - it does not add up.
                  Couldn't agree more... This should have been a v.7.2 or something... ๐Ÿ˜
                  That said... It feels more stable and seem to be handling high poly models better...
                  Also some of the better ruby plug-ins seem to work both faster and better...
                  But a major version release... Naahhh...
                  (but perhaps they've tweaked A LOT under the hood...??)
                  Just read this at the TWR Forum...
                  @chris said:
                  I was pretty disappointed that they said not only are they not planning to do 64bit, they don't even see the value of it! ๐Ÿ˜ก
                  (I think they are all Mac users anyway, which would explain why they aren't in a big hurry).
                  Cheers
                  Kim Frederik
                  • honoluludesktopH Offline
                    honoluludesktop
                    Did you copy the plugins from SU 7.x to SU 8.0?
                    • K Offline
                      Khai
                      I did...
                      and Splat!
                      so now I'm adding back a few at a time...
                      • genki.ttG Offline
                        genki.tt
                        Great Update for me..
                        I found Google SketchUp8, LayOut3 QuickReferenceCard, but pdf manuals.
                        http://sketchup.google.com/support/bin/answer.py?hl=en&answer=116693
                          Some lights about the new Push Pull 2.0? ๐Ÿ˜ณ
                          Push/Pull pre-selected faces
                          http://sketchup.google.com/images/newin8/019-push-pull.png
                          Select a face, then push/pull; it works just like the rest of SketchUpโ€™s modification tools. Super handy when you donโ€™t want to change your point of view.
                            Before PushPull would ignore pre-selected faces and only use the face you clicked on.
                            If you Pre-Pick in SU8 it will push-pull the selected face even if you are not clicking directly on it.
                              Thiago Luz
                              Unfortunately, Google just wants us to model the world in 3D for it .... The program does not do anything innovative ... once again ... disappointment!
                                cadmunkey
                                Jeez.. no 64 bit version in 2010? C'mon Google you've dropped the ball! You beta testers couldnt persuade them?
                                  Oooooooooooh! Significative progress ๐Ÿ˜ฒ ๐Ÿ’š ๐Ÿ˜ฎ
                                  I have believed that was Push Pull multiple with preselect of some facets ๐Ÿ˜•
                                  Deception ๐Ÿ˜ž
                                    johnsenior1973
                                    ~ v 6.4 for me.
                                    SU7 and SU8 are just point upgrades from SU6 IMO. Sketchup is still an awesome programme, but it is pretty much as good as it's ever going to be.
                                    • N Offline
                                      notareal
                                      @johnsenior1973 said:
                                      ~ v 6.4 for me.
                                      Luckily we have magnificent script writers - I seriously hope that they have stamina to hang on.
                                        There's been some pretty important bug fixes to the API that's going to make a big difference.
                                        • P Offline
                                          Panga
                                          So should we consider to spend the upgrade fee for ruby scripters that are able to deliver so much tools in the same time where google give so little... ?
                                          • E Offline
                                            emage
                                            Hi all,
                                            I'm unable to install SU8 here, as only the IT guys have Admin rights.
                                            Can someone please answer me 2 quick question?
                                            1. Does SU8 support Multi-Cores?
                                            2. Does SU8 support >2Gb Memory (we have 12Gb on our Workstation...)
                                            Thanks!
                                            -Avihay.
                                            • 6
                                            • 17
                                            • 18
                                            • 4 / 18
