    SketchUP 8
    345 Posts 101 Posters 95.6k Views 101 Watching
    • wind-borneW Offline
      wind-borne
      @drewpoeppel said:
      Looks like they removed the solar orientation setting in the geolocation area for manually setting the north angle in you model
      Solar North toolbar now but so far can only toggle on/off.
      Bottom two buttons dead at the moment.
      Do work if I put icons into customized toolbar ๐ŸŽ‰
      "To read between the lines was easier than to follow the text."OSX 10.11.6
      %(#BF80BF)[SU 8 pro
      • jeff hammondJ Offline
        has anyone used up their 8hrs yet?
        i'm pretty close and i'm just wondering if it reverts to SUfree..
        my company pays for my license but it's going to be another couple of days but i'd like to use it in the meantime..
        (that back edges view is real nice btw.. seems like i'll be using that a lot more often than xray now)
        • N Offline
          notareal
          @frederik said:
          You guys are so un-grateful... ๐Ÿ˜
          I like "Susan"... ๐Ÿ˜‰
          +1
          Toolbar fix is nice and also ruby update... seems that SU2Thea freeze (win) is gone by that. General impression for me: some needed bug fixed and some minor new features... but a major version release - it does not add up. I really was expecting 64 bit version.
          • FrederikF Offline
            Frederik
            @notareal said:
            ...but a major version release - it does not add up.
            Couldn't agree more... This should have been a v.7.2 or something... ๐Ÿ˜
            That said... It feels more stable and seem to be handling high poly models better...
            Also some of the better ruby plug-ins seem to work both faster and better...
            But a major version release... Naahhh...
            (but perhaps they've tweaked A LOT under the hood...??)
            Just read this at the TWR Forum...
            @chris said:
            I was pretty disappointed that they said not only are they not planning to do 64bit, they don't even see the value of it! ๐Ÿ˜ก
            (I think they are all Mac users anyway, which would explain why they aren't in a big hurry).
            Cheers
            Kim Frederik
            • honoluludesktopH Offline
              honoluludesktop
              @escapeartist said:
              Did the upgrade to 8 Free, discovered that I lost about 30% of my plugins on the toolbar. It'll take a bit to go through and figure out which ones vanished.
              Did you copy the plugins from SU 7.x to SU 8.0?
                Khai
                I did...
                and Splat!
                so now I'm adding back a few at a time...
                • genki.ttG Offline
                  genki.tt
                  Great Update for me..
                  I found Google SketchUp8, LayOut3 QuickReferenceCard, but pdf manuals.
                  http://sketchup.google.com/support/bin/answer.py?hl=en&answer=116693
                    Some lights about the new Push Pull 2.0? ๐Ÿ˜ณ
                    Push/Pull pre-selected faces
                    http://sketchup.google.com/images/newin8/019-push-pull.png
                    Select a face, then push/pull; it works just like the rest of SketchUpโ€™s modification tools. Super handy when you donโ€™t want to change your point of view.
                      Before PushPull would ignore pre-selected faces and only use the face you clicked on.
                      If you Pre-Pick in SU8 it will push-pull the selected face even if you are not clicking directly on it.
                        Thiago Luz
                        Unfortunately, Google just wants us to model the world in 3D for it .... The program does not do anything innovative ... once again ... disappointment!
                          cadmunkey
                          Jeez.. no 64 bit version in 2010? C'mon Google you've dropped the ball! You beta testers couldnt persuade them?
                            Oooooooooooh! Significative progress ๐Ÿ˜ฒ ๐Ÿ’š ๐Ÿ˜ฎ
                            I have believed that was Push Pull multiple with preselect of some facets ๐Ÿ˜•
                            Deception ๐Ÿ˜ž
                              johnsenior1973
                              ~ v 6.4 for me.
                              SU7 and SU8 are just point upgrades from SU6 IMO. Sketchup is still an awesome programme, but it is pretty much as good as it's ever going to be.
                              • N Offline
                                notareal
                                @johnsenior1973 said:
                                ~ v 6.4 for me.
                                Luckily we have magnificent script writers - I seriously hope that they have stamina to hang on.
                                  There's been some pretty important bug fixes to the API that's going to make a big difference.
                                    Panga
                                    So should we consider to spend the upgrade fee for ruby scripters that are able to deliver so much tools in the same time where google give so little... ?
                                    • E Offline
                                      emage
                                      Hi all,
                                      I'm unable to install SU8 here, as only the IT guys have Admin rights.
                                      Can someone please answer me 2 quick question?
                                      1. Does SU8 support Multi-Cores?
                                      2. Does SU8 support >2Gb Memory (we have 12Gb on our Workstation...)
                                      -Avihay.
                                        No
                                        @emage said:
                                        1. Does SU8 support >2Gb Memory (we have 12Gb on our Workstation...)
                                        No
                                          You decide - when the plugins that require SU8 comes out.
                                          I'm upgrading to SU8 - even just for the modelling part. Some important fixes and improvement here as well. I don't expect SU to make much a wow factor any more - it's a mature product. There are of course lots of room for improvement - though personally I'd prefer SU being maintained as a platform for where developers can make specialised tools. It's why I like SU - like Firefox, I can install the features I want. I'm not too bothered who makes the actual implementation of the features/plugins as long as the platform for which to build them are good enough for continued development.
                                          Personally I feel that 7.1 was a bigger update - with the speed improvements it had. But SU8 is fine.
                                            dacad
                                            (i don't know if i should laugh or cry...)
                                            and AMAZING!
                                            The post i did 2 years ago still aplies here (http://forums.sketchucation.com/viewtopic.php?f=15&t=14207&start=165#p107667๐Ÿ˜ž
                                            "This must be a joke...
                                            For the ones saying this was a good release:
                                            New modeling tools: NO
                                            new animation tools: NO
                                            new uv maping tools: NO
                                            new engine that suport more heavy scenes: NO
                                            new engine that do better images and shadows: NO
                                            new (even very basic) ways to simulate diferent light sources from the sun: NO"
                                            But to be fair, in modeling now we can do better bolean operations (too bad there's the script booltools...damn you Whaat ๐Ÿ˜› ), in animation we now have a litle image preview (i don't even know what to say for this one...), and for maping we can now work even better with google earth (we all know how great quality and professional textures that gives us, unless we're doing it for google earth...is there even someone who does that for a living?).
                                            Soooo...2 years in development for this...lolol
                                            Ha Ha Ha! Even the shadow bug is here too! HA HA HA HA!
                                            This is just getting better and better ๐Ÿ‘
                                            • 17
                                            • 18
                                            • 4 / 18
