    [Plugin] Sculpt Tools v 1.0...
    100 Posts 51 Posters 132.1k Views 50 Watching
    • free agentF Offline
      free agent
      checking artisan it only seems to have a relax selection function is it possible for anyone who is savy with ruby script to pull the smooth brush out of this set and make it available for 2015??
        free agent
        will this plugin ever be updated for 2014?
          Almost certainly NOT 😞
            free agent
            poo, is there any way to get the relax brush out? i do a lot of site work and it super helpful for fixing ugly meshes 😞
              There is no license attached to this which allows anyone to extract or reuse any code.
              You might try to contacting the author directly via email and ask if he'd be willing to open source it.
              Short of that... grab a copy of SU2013 Make.
                What function includes this 'Relax Brush' ?
                There are several candidates...
                  free agent
                  In the initial post by BTM he seems to give permission for alteration/fixes.
                  the specific tool i want is the smooth brush, which works very much like the 3ds max relax brush, essentially just averaging out the distance between vertices to variable strengths.
                  • pbacotP Offline
                    What's the difference from Artisan sculpt smooth setting?
                      I looked at the code and it was a simple fix to make its loader >= v2014 compatible...
                      The updated version is in the PluginStore http://sketchucation.com/pluginstore?pln=btm_Sculpt_Tools_Files Although I suspect after six years there will be more up to date / better Plugins - like 'Artisan' ...
                      Please test and report back I have NOT tested it intensively 😮
                        free agent
                        TIG you are awesome, i actually meant 2015, but loaded it and still works, thank you so much!!
                          Making it compatible with v2014's Ruby2 means that it also works with v2015 😛
                            jwrathall
                            I've used Sculpt Tools for a while now, because I'm too cheap and young to pay for Artisan.
                            I'd really love the lock feature to work by choosing lines and/or points and locking them in all axes, so they stay where they are, but any associated lines/faces move with the bulge tool.
                            I wish I had the skill to modify the code, if it's even possible.
                            Can someone please shed light on whether this is possible/feasible?
                            • majidM Offline
                              majid
                              Would be any update for this fantastic plugin?
                              • majidM Offline
                                majid
                                Is anyone anymore interested to develop this tool?
                                  JohnButler222 @BTM
                                  @BTM Hello, I have fixed the code of this extension to work on more recent Sketchup versions. If you approve, I can share them here.
                                    Rich O Brien Moderator @JohnButler222
                                    @JohnButler222 said in [Plugin] Sculpt Tools v 1.0...:
                                    Share away
                                      JohnButler222
                                      Here is the updated Sculpt Tools.
                                      Added two new tools. "Spread", which pushes vertices away from the cursor, and "Constrict", which attracts them.
                                      I didn't fix the the original "Planar Lock" function. Only tested in Sketchup 2017 on a Mac! Works well though. Hope it works for others.
                                      Sculpt Tools 2025 update.zip
                                      • ntxdaveN Offline
                                        ntxdave
                                        Is there some documentation or a tutorial for this plugin?
                                        Press F1...thank me later
                                        J 1 Reply Last reply Reply Quote 0
                                          JohnButler222 @ntxdave
                                          @ntxdave Not that I know of. But it's simple. Create or import a mesh with a high-ish polygon count.
                                          Hover over an icon in the Sculpt Tools toolbar and the name of the tool will appear by the mouse cursor.
                                          Click on "Bulge" and then click on the mesh with the left mouse button.
                                          The mesh will deform, creating a bulge. Press and hold shift and the Bulge tool turns into the "Push" tool, which will
                                          create the opposite effect of pushing into the mesh. The "Smooth" tool is useful for smoothing out the mesh, creating
                                          a uniformity in the polygons. Adjust brush radius and strength in the settings, which is the top button in the toolbar.
                                            sashapepperspray
                                            I gave the code of this plugin to ai, and asked him to write a manual, here it is.Sculpt Tools Manual.pdf
                                            1 Reply Last reply 👍 Reply Quote 1
                                            • 5 / 5
