    [Plugin] Sculpt Tools v 1.0...
    100 Posts 51 Posters 142.0k Views 50 Watching
      Sauronbloo
      While looking for directions on the use of vertex tools, I realized that the sandbox tools seem to be at least a minimal version for doing this type of work. Anyone like me, that didn't know this, use the free and native tool by enabling it in window/preferences/extensions, then enable the toolbar in view.
      • mitcorbM Offline
        mitcorb
        The Sandbox tools work only in the Z direction. But you can do your "sculpting" on the ground group, then tilt it up when you need to.
          bwantedstar
          the Sculpt Tools plugin is in .rb, but sketchup pro can't install it. It seems that I can only install .rbz...
          Can anyone teach me how to install .rb file in sketch up pro? Thanks a lot!
          • BepB Offline
            Bep
            Change the .zip extension into .rbz ,then install it
            "History is written by the winners"
              bwantedstar
              Installed successfully!! Thank you very much!!
              • free agentF Offline
                free agent
                Does anyone know if there is a script that works like the smooth tool in this, almost like a relax brush? i use this alot but its non responsive in 2015 😞
                http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
                • BoxB Offline
                  Artisan
                  Not free but well worth the money.
                  http://sketchucation.com/plugin/828-dm_artisan
                    free agent
                    Thanx
                      free agent
                      checking artisan it only seems to have a relax selection function is it possible for anyone who is savy with ruby script to pull the smooth brush out of this set and make it available for 2015??
                        free agent
                        will this plugin ever be updated for 2014?
                          Almost certainly NOT 😞
                            free agent
                            poo, is there any way to get the relax brush out? i do a lot of site work and it super helpful for fixing ugly meshes 😞
                              There is no license attached to this which allows anyone to extract or reuse any code.
                              You might try to contacting the author directly via email and ask if he'd be willing to open source it.
                              Short of that... grab a copy of SU2013 Make.
                                What function includes this 'Relax Brush' ?
                                There are several candidates...
                                  free agent
                                  In the initial post by BTM he seems to give permission for alteration/fixes.
                                  the specific tool i want is the smooth brush, which works very much like the 3ds max relax brush, essentially just averaging out the distance between vertices to variable strengths.
                                  • pbacotP Offline
                                    What's the difference from Artisan sculpt smooth setting?
                                      I looked at the code and it was a simple fix to make its loader >= v2014 compatible...
                                      The updated version is in the PluginStore http://sketchucation.com/pluginstore?pln=btm_Sculpt_Tools_Files Although I suspect after six years there will be more up to date / better Plugins - like 'Artisan' ...
                                      Please test and report back I have NOT tested it intensively 😮
                                        free agent
                                        TIG you are awesome, i actually meant 2015, but loaded it and still works, thank you so much!!
                                          Making it compatible with v2014's Ruby2 means that it also works with v2015 😛
                                            jwrathall
                                            I've used Sculpt Tools for a while now, because I'm too cheap and young to pay for Artisan.
                                            I'd really love the lock feature to work by choosing lines and/or points and locking them in all axes, so they stay where they are, but any associated lines/faces move with the bulge tool.
                                            I wish I had the skill to modify the code, if it's even possible.
                                            Can someone please shed light on whether this is possible/feasible?
                                            • 5 / 5
