[Plugin] Sculpt Tools v 1.0...
TIG you are awesome, i actually meant 2015, but loaded it and still works, thank you so much!!
Making it compatible with v2014's Ruby2 means that it also works with v2015
I've used Sculpt Tools for a while now, because I'm too cheap and young to pay for Artisan.
I'd really love the lock feature to work by choosing lines and/or points and locking them in all axes, so they stay where they are, but any associated lines/faces move with the bulge tool.
I wish I had the skill to modify the code, if it's even possible.
Can someone please shed light on whether this is possible/feasible?
Would be any update for this fantastic plugin?
Is anyone anymore interested to develop this tool?
@BTM Hello, I have fixed the code of this extension to work on more recent Sketchup versions. If you approve, I can share them here.
@JohnButler222 said in [Plugin] Sculpt Tools v 1.0...:
Share away
Here is the updated Sculpt Tools.
Added two new tools. "Spread", which pushes vertices away from the cursor, and "Constrict", which attracts them.
I didn't fix the the original "Planar Lock" function. Only tested in Sketchup 2017 on a Mac! Works well though. Hope it works for others.
Sculpt Tools 2025 update.zip -
Is there some documentation or a tutorial for this plugin?
@ntxdave Not that I know of. But it's simple. Create or import a mesh with a high-ish polygon count.
Hover over an icon in the Sculpt Tools toolbar and the name of the tool will appear by the mouse cursor.
Click on "Bulge" and then click on the mesh with the left mouse button.
The mesh will deform, creating a bulge. Press and hold shift and the Bulge tool turns into the "Push" tool, which will
create the opposite effect of pushing into the mesh. The "Smooth" tool is useful for smoothing out the mesh, creating
a uniformity in the polygons. Adjust brush radius and strength in the settings, which is the top button in the toolbar. -
I gave the code of this plugin to ai, and asked him to write a manual, here it is.Sculpt Tools Manual.pdf
With your input, this post could be even better š
