    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
    • fredo6F Offline
      fredo6
      You have a wrong installation
      jointpushpull_main.rb should be in JPP_Dir_20, NOT in the main SU Plugins directory.
      Fredo
      • G Offline
        gigi500
        You are right. I moved it. Bezier lasted this time for maybe 8 curves, then bugsplat:(((
          Fredo, I'm seeing the same thing on my Mac. I successfully drew 5 Bezier curves but while drawing the 6th, SketchUp crashed without a Bug Splat.
          • G Offline
            gigi500
            I am attaching a new screen shot - got rid of all plugins but native sketch up and bezier. Still Crashes!
              What is the FULL path to that Plugins folder ?
              You leak out the story drip by drip... 😉
              • G Offline
                gigi500
                the normal for mac:library/application support/sketchup2013/plugins/
                Everything else works. And Dave R apparently encountered the same thing...I got rid temporarily of other plugins to make sure they do not affect that one. No change.
                • fredo6F Offline
                  fredo6
                  @gigi500, @Dave,
                  Not sure what it can be and why it appears now (I did not change anything to the plugin for a while).
                  Since you have a deterministic crash situation (after a few curve), would you mind to remove the file LibTraductor.rb (or rename it .rb!). Since you have LibFredo6 installed, it should be harmless.
                  Fredo
                    I disabled LibTraductor.rb and opened SU. I got the following:
                    I do have the most recent LibFredo6 installed.
                    • fredo6F Offline
                      fredo6
                      Dave,
                      But do you still get BezierSpline loaded?
                      And if so, do you get the crash?
                      Fredo
                        No. With LibTraductor disabled I don't get BezierSpline loaded at all. No option for toolbar nor any menu entry.
                        • fredo6F Offline
                          fredo6
                          My mistake,
                          You should replace the statement rescue by rescue LoadError on line 35 of bezierspline_main.rb.
                          This will allow checking for potential conflicts ebtween the old version (libTraductor.rb) and the new one embedded in LibFredo6.
                          If you still get a crash, then it is something else
                          Fredo
                            I can't easily see line numbers. "rescue" appears several times. Could you give me a bit of surrounding text?
                              require 'sketchup.rb'
                              begin
                              	require 'libtraductor.rb'		# for language translation
                              rescue
                              #Specify the two curve extensions; Bezier Classic and Polyline
                              BZ____LIST = ["BZ__BezierClassic", "BZ__Polyline"]
                                10Q
                                  OK, LibTraductor disabled. The rescue statement revised.
                                  Upon opening SketchUp I still get the error:
                                  %(#4000BF)[Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BZ_Dir_14/bezierspline_main.rb
                                  uninitialized constant Bezierspline::BezierContext::Traductor
                                  Error Loading File bezierspline.rb
                                  Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/JPP_Dir_20/jointpushpull_main.rb
                                  no such file to load -- libtraductor.rb
                                  Error Loading File jointpushpull.rb
                                  no such file to load -- libtraductor.rb]
                                  Edit to add: After clicking OK, I see an entry for the BezierSpline toolbar but when I enable that toolbar it is blank with only space for one button.
                                  • F Offline
                                    fatboycakeshop
                                    Hi. Im having the same issue. Done all of the above and still crashes after a few curves. Anything else I can try?
                                    • nigel_edwardN Offline
                                      nigel_edward
                                      Bloody well brilliant tool! Thank you so much! 👍 😍
                                      • U Offline
                                        ukchoiceshops
                                        I am struggling to work out how to install this onto my sketchup 8 system on a mac. any help would be much appreciated 😄
                                        • mitcorbM Offline
                                          mitcorb
                                          Hi, Ross:
                                          Did you read the advice for Mac users on the first page of this topic?
                                          Alternatively, have you considered using the Sketchucation Plugin Store tool?
                                          http://sketchucation.com/resources/plugin-store-download
                                          At the top of this page, there is a selection called Resources and in the drop down is the link to the download.
                                          There may be some other issue, so post back for someone to assist.
                                            aydee
                                            Fantastic. I can finally get more segments and smooth bezier curves. Thank you!
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
