    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      gigi500
      I am attaching a new screen shot - got rid of all plugins but native sketch up and bezier. Still Crashes!
        What is the FULL path to that Plugins folder ?
        You leak out the story drip by drip... ๐Ÿ˜‰
          gigi500
          the normal for mac:library/application support/sketchup2013/plugins/
          Everything else works. And Dave R apparently encountered the same thing...I got rid temporarily of other plugins to make sure they do not affect that one. No change.
          • fredo6F Offline
            @gigi500, @Dave,
            Not sure what it can be and why it appears now (I did not change anything to the plugin for a while).
            Since you have a deterministic crash situation (after a few curve), would you mind to remove the file LibTraductor.rb (or rename it .rb!). Since you have LibFredo6 installed, it should be harmless.
              I disabled LibTraductor.rb and opened SU. I got the following:
              I do have the most recent LibFredo6 installed.
              • fredo6F Offline
                Dave,
                But do you still get BezierSpline loaded?
                And if so, do you get the crash?
                  No. With LibTraductor disabled I don't get BezierSpline loaded at all. No option for toolbar nor any menu entry.
                  • fredo6F Offline
                    My mistake,
                    You should replace the statement rescue by rescue LoadError on line 35 of bezierspline_main.rb.
                    This will allow checking for potential conflicts ebtween the old version (libTraductor.rb) and the new one embedded in LibFredo6.
                    If you still get a crash, then it is something else
                      I can't easily see line numbers. "rescue" appears several times. Could you give me a bit of surrounding text?
                      • Rich O BrienR Online
                        require 'sketchup.rb'
                        begin
                        	require 'libtraductor.rb'		# for language translation
                        rescue
                        #Specify the two curve extensions; Bezier Classic and Polyline
                        BZ____LIST = ["BZ__BezierClassic", "BZ__Polyline"]
                          10Q
                            OK, LibTraductor disabled. The rescue statement revised.
                            Upon opening SketchUp I still get the error:
                            %(#4000BF)[Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BZ_Dir_14/bezierspline_main.rb
                            uninitialized constant Bezierspline::BezierContext::Traductor
                            Error Loading File bezierspline.rb
                            Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/JPP_Dir_20/jointpushpull_main.rb
                            no such file to load -- libtraductor.rb
                            Error Loading File jointpushpull.rb
                            no such file to load -- libtraductor.rb]
                            Edit to add: After clicking OK, I see an entry for the BezierSpline toolbar but when I enable that toolbar it is blank with only space for one button.
                            • F Offline
                              fatboycakeshop
                              Hi. Im having the same issue. Done all of the above and still crashes after a few curves. Anything else I can try?
                              • nigel_edwardN Offline
                                nigel_edward
                                Bloody well brilliant tool! Thank you so much! ๐Ÿ‘ ๐Ÿ˜
                                • U Offline
                                  ukchoiceshops
                                  I am struggling to work out how to install this onto my sketchup 8 system on a mac. any help would be much appreciated ๐Ÿ˜„
                                  • mitcorbM Offline
                                    mitcorb
                                    Hi, Ross:
                                    Did you read the advice for Mac users on the first page of this topic?
                                    Alternatively, have you considered using the Sketchucation Plugin Store tool?
                                    http://sketchucation.com/resources/plugin-store-download
                                    At the top of this page, there is a selection called Resources and in the drop down is the link to the download.
                                    There may be some other issue, so post back for someone to assist.
                                      aydee
                                      Fantastic. I can finally get more segments and smooth bezier curves. Thank you!
                                      • O Offline
                                        oli_sketch
                                        Dear Fredo,
                                        I got problems with Bezier spline 1.4f , when I use it sketchup 2013 always close it.
                                        My OS is macos X 10.8.5 with sketchup 2013 (spanish) version 13.0.4811 on a MacBook Pro late 2 gh intel core i7
                                        Can you help me.
                                        Thank you and kind regards.
                                          BillyRX
                                          @oli_sketch said:
                                          Dear Fredo,
                                          Can you help me.
                                          What he said. Please. This used to be my most commonly used extension. ๐Ÿ˜ž
                                          • BoxB Offline
                                            There have been updates to fredos plugins to work with SU2013, make sure you have the latest versions including Libfredo
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
