    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
    • jeff hammondJ Offline
      @mwm5053 said:
      In using the Classic Bezier Curve, I tried to change segments from 20s to 6s but doesn't seem to want do that and pressing tab doesn't seem to bring up anything obviously I'm missing something here I'm sure maybe someone can help. Thanks
      i'm not 100% sure of the # with classic bezier but i do know that if you're using a uniform B-spline, the lowest acceptable amount of segments is 15s (and if you enter something lower, it will still be 15 segments)
      [EDIT]-- with classic bezier curves, the lowest acceptable # is 7
        mwm5053
        Thanks Jeff will try that
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
        • W Offline
          Woody Longspike
          Thank you Fredo, a most excellent plugin and easy to use!
            shemalpandya
            THANK YOU SOOOOO MUCH 😍
              gigi500
              Is anybody using this plug in on Mac Sketch Up Pro2013? My plugin crashes after a few seconds....
                Have you got the latest files and the latest LibFredo...
                Which was recast for v2013 compatibility.
                Also do you have any other know problem tools loading like Vray-beta ??
                  I've been using BZ_Spline tools on Mac in SU2013 with no problems. I do have the latest version of LibFredo6.
                  I wonder if you have a permissions issue.
                  Revised: It seems to work fine unless I try to use a number of tools from the toolbar in succession. Even just switching tools seems to cause a crash. I hadn't ever had an occasion to do that in my normal workflow so hadn't seen it. It doesn't seem to throw any Bug Splats, either.
                    gigi500
                    library and all that - downloaded from the store, so all new...Tried to delete and reinstall - the same thing.Without changing tools, just a few curves on a blank file, sometimes less than a complete curve - bugsplat. I am attaching a screen shot of plug ins - maybe you see something that I do not. Permissions are all the same for other plugins,including Fredos, so should not be an issue. His other plugins work just fine, no crashes.
                    • fredo6F Offline
                      You have a wrong installation
                      jointpushpull_main.rb should be in JPP_Dir_20, NOT in the main SU Plugins directory.
                        gigi500
                        You are right. I moved it. Bezier lasted this time for maybe 8 curves, then bugsplat:(((
                          Fredo, I'm seeing the same thing on my Mac. I successfully drew 5 Bezier curves but while drawing the 6th, SketchUp crashed without a Bug Splat.
                            gigi500
                            I am attaching a new screen shot - got rid of all plugins but native sketch up and bezier. Still Crashes!
                              What is the FULL path to that Plugins folder ?
                              You leak out the story drip by drip... 😉
                                gigi500
                                the normal for mac:library/application support/sketchup2013/plugins/
                                Everything else works. And Dave R apparently encountered the same thing...I got rid temporarily of other plugins to make sure they do not affect that one. No change.
                                • fredo6F Offline
                                  @gigi500, @Dave,
                                  Not sure what it can be and why it appears now (I did not change anything to the plugin for a while).
                                  Since you have a deterministic crash situation (after a few curve), would you mind to remove the file LibTraductor.rb (or rename it .rb!). Since you have LibFredo6 installed, it should be harmless.
                                    I disabled LibTraductor.rb and opened SU. I got the following:
                                    I do have the most recent LibFredo6 installed.
                                    • fredo6F Offline
                                      Dave,
                                      But do you still get BezierSpline loaded?
                                      And if so, do you get the crash?
                                        No. With LibTraductor disabled I don't get BezierSpline loaded at all. No option for toolbar nor any menu entry.
                                        • fredo6F Offline
                                          My mistake,
                                          You should replace the statement rescue by rescue LoadError on line 35 of bezierspline_main.rb.
                                          This will allow checking for potential conflicts ebtween the old version (libTraductor.rb) and the new one embedded in LibFredo6.
                                          If you still get a crash, then it is something else
                                            I can't easily see line numbers. "rescue" appears several times. Could you give me a bit of surrounding text?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
