    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      gigi500
      the normal for mac:library/application support/sketchup2013/plugins/
      Everything else works. And Dave R apparently encountered the same thing...I got rid temporarily of other plugins to make sure they do not affect that one. No change.
      • fredo6F Offline
        @gigi500, @Dave,
        Not sure what it can be and why it appears now (I did not change anything to the plugin for a while).
        Since you have a deterministic crash situation (after a few curve), would you mind to remove the file LibTraductor.rb (or rename it .rb!). Since you have LibFredo6 installed, it should be harmless.
          I disabled LibTraductor.rb and opened SU. I got the following:
          I do have the most recent LibFredo6 installed.
          • fredo6F Offline
            Dave,
            But do you still get BezierSpline loaded?
            And if so, do you get the crash?
              No. With LibTraductor disabled I don't get BezierSpline loaded at all. No option for toolbar nor any menu entry.
              • fredo6F Offline
                My mistake,
                You should replace the statement rescue by rescue LoadError on line 35 of bezierspline_main.rb.
                This will allow checking for potential conflicts ebtween the old version (libTraductor.rb) and the new one embedded in LibFredo6.
                If you still get a crash, then it is something else
                  I can't easily see line numbers. "rescue" appears several times. Could you give me a bit of surrounding text?
                    require 'sketchup.rb'
                    begin
                    	require 'libtraductor.rb'		# for language translation
                    rescue
                    #Specify the two curve extensions; Bezier Classic and Polyline
                    BZ____LIST = ["BZ__BezierClassic", "BZ__Polyline"]
                      10Q
                        OK, LibTraductor disabled. The rescue statement revised.
                        Upon opening SketchUp I still get the error:
                        %(#4000BF)[Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BZ_Dir_14/bezierspline_main.rb
                        uninitialized constant Bezierspline::BezierContext::Traductor
                        Error Loading File bezierspline.rb
                        Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/JPP_Dir_20/jointpushpull_main.rb
                        no such file to load -- libtraductor.rb
                        Error Loading File jointpushpull.rb
                        no such file to load -- libtraductor.rb]
                        Edit to add: After clicking OK, I see an entry for the BezierSpline toolbar but when I enable that toolbar it is blank with only space for one button.
                        • F Offline
                          fatboycakeshop
                          Hi. Im having the same issue. Done all of the above and still crashes after a few curves. Anything else I can try?
                          • nigel_edwardN Offline
                            nigel_edward
                            Bloody well brilliant tool! Thank you so much! 👍 😍
                            • U Offline
                              ukchoiceshops
                              I am struggling to work out how to install this onto my sketchup 8 system on a mac. any help would be much appreciated 😄
                              • mitcorbM Offline
                                mitcorb
                                Hi, Ross:
                                Did you read the advice for Mac users on the first page of this topic?
                                Alternatively, have you considered using the Sketchucation Plugin Store tool?
                                http://sketchucation.com/resources/plugin-store-download
                                At the top of this page, there is a selection called Resources and in the drop down is the link to the download.
                                There may be some other issue, so post back for someone to assist.
                                  aydee
                                  Fantastic. I can finally get more segments and smooth bezier curves. Thank you!
                                  • O Offline
                                    oli_sketch
                                    Dear Fredo,
                                    I got problems with Bezier spline 1.4f , when I use it sketchup 2013 always close it.
                                    My OS is macos X 10.8.5 with sketchup 2013 (spanish) version 13.0.4811 on a MacBook Pro late 2 gh intel core i7
                                    Can you help me.
                                    Thank you and kind regards.
                                      BillyRX
                                      @oli_sketch said:
                                      Dear Fredo,
                                      Can you help me.
                                      What he said. Please. This used to be my most commonly used extension. 😞
                                      • BoxB Offline
                                        There have been updates to fredos plugins to work with SU2013, make sure you have the latest versions including Libfredo
                                          Beejeez
                                          I installed Bezierspline v1.4 on my mac computer in SU2013. I really like the possibilities of this plugin but the point is that SU crashes after inserting a few bezier points.
                                          I saw that this issue was discussed a few months ago by gig500 and dave R. Does anyone know if this problem is already solved?
                                          Thanks in advance
                                          • fredo6F Offline
                                            NEW RELEASE 1.6a - 11 Nov 2013
                                            This release is for future Sketchup compatibility
                                            Download new release at main post
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
