    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      shemalpandya
      THANK YOU SOOOOO MUCH 😍
        gigi500
        Is anybody using this plug in on Mac Sketch Up Pro2013? My plugin crashes after a few seconds....
          Have you got the latest files and the latest LibFredo...
          Which was recast for v2013 compatibility.
          Also do you have any other know problem tools loading like Vray-beta ??
            I've been using BZ_Spline tools on Mac in SU2013 with no problems. I do have the latest version of LibFredo6.
            I wonder if you have a permissions issue.
            Revised: It seems to work fine unless I try to use a number of tools from the toolbar in succession. Even just switching tools seems to cause a crash. I hadn't ever had an occasion to do that in my normal workflow so hadn't seen it. It doesn't seem to throw any Bug Splats, either.
              gigi500
              library and all that - downloaded from the store, so all new...Tried to delete and reinstall - the same thing.Without changing tools, just a few curves on a blank file, sometimes less than a complete curve - bugsplat. I am attaching a screen shot of plug ins - maybe you see something that I do not. Permissions are all the same for other plugins,including Fredos, so should not be an issue. His other plugins work just fine, no crashes.
              • fredo6F Offline
                You have a wrong installation
                jointpushpull_main.rb should be in JPP_Dir_20, NOT in the main SU Plugins directory.
                  gigi500
                  You are right. I moved it. Bezier lasted this time for maybe 8 curves, then bugsplat:(((
                    Fredo, I'm seeing the same thing on my Mac. I successfully drew 5 Bezier curves but while drawing the 6th, SketchUp crashed without a Bug Splat.
                      gigi500
                      I am attaching a new screen shot - got rid of all plugins but native sketch up and bezier. Still Crashes!
                        What is the FULL path to that Plugins folder ?
                        You leak out the story drip by drip... πŸ˜‰
                          gigi500
                          the normal for mac:library/application support/sketchup2013/plugins/
                          Everything else works. And Dave R apparently encountered the same thing...I got rid temporarily of other plugins to make sure they do not affect that one. No change.
                          • fredo6F Offline
                            @gigi500, @Dave,
                            Not sure what it can be and why it appears now (I did not change anything to the plugin for a while).
                            Since you have a deterministic crash situation (after a few curve), would you mind to remove the file LibTraductor.rb (or rename it .rb!). Since you have LibFredo6 installed, it should be harmless.
                              I disabled LibTraductor.rb and opened SU. I got the following:
                              I do have the most recent LibFredo6 installed.
                              • fredo6F Offline
                                Dave,
                                But do you still get BezierSpline loaded?
                                And if so, do you get the crash?
                                  No. With LibTraductor disabled I don't get BezierSpline loaded at all. No option for toolbar nor any menu entry.
                                  • fredo6F Offline
                                    My mistake,
                                    You should replace the statement rescue by rescue LoadError on line 35 of bezierspline_main.rb.
                                    This will allow checking for potential conflicts ebtween the old version (libTraductor.rb) and the new one embedded in LibFredo6.
                                    If you still get a crash, then it is something else
                                      I can't easily see line numbers. "rescue" appears several times. Could you give me a bit of surrounding text?
                                        require 'sketchup.rb'
                                        begin
                                        	require 'libtraductor.rb'		# for language translation
                                        rescue
                                        #Specify the two curve extensions; Bezier Classic and Polyline
                                        BZ____LIST = ["BZ__BezierClassic", "BZ__Polyline"]
                                          10Q
                                            OK, LibTraductor disabled. The rescue statement revised.
                                            Upon opening SketchUp I still get the error:
                                            %(#4000BF)[Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BZ_Dir_14/bezierspline_main.rb
                                            uninitialized constant Bezierspline::BezierContext::Traductor
                                            Error Loading File bezierspline.rb
                                            Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/JPP_Dir_20/jointpushpull_main.rb
                                            no such file to load -- libtraductor.rb
                                            Error Loading File jointpushpull.rb
                                            no such file to load -- libtraductor.rb]
                                            Edit to add: After clicking OK, I see an entry for the BezierSpline toolbar but when I enable that toolbar it is blank with only space for one button.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
