    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • fredo6F
      Dave,
      But do you still get BezierSpline loaded?
      And if so, do you get the crash?
        No. With LibTraductor disabled I don't get BezierSpline loaded at all. No option for toolbar nor any menu entry.
        • fredo6F
          My mistake,
          You should replace the statement rescue by rescue LoadError on line 35 of bezierspline_main.rb.
          This will allow checking for potential conflicts ebtween the old version (libTraductor.rb) and the new one embedded in LibFredo6.
          If you still get a crash, then it is something else
            I can't easily see line numbers. "rescue" appears several times. Could you give me a bit of surrounding text?
              require 'sketchup.rb'
              begin
              	require 'libtraductor.rb'		# for language translation
              rescue
              #Specify the two curve extensions; Bezier Classic and Polyline
              BZ____LIST = ["BZ__BezierClassic", "BZ__Polyline"]
                10Q
                  OK, LibTraductor disabled. The rescue statement revised.
                  Upon opening SketchUp I still get the error:
                  %(#4000BF)[Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/BZ_Dir_14/bezierspline_main.rb
                  uninitialized constant Bezierspline::BezierContext::Traductor
                  Error Loading File bezierspline.rb
                  Error Loading File /Users/davidrichards/Library/Application Support/SketchUp 2013/SketchUp/Plugins/JPP_Dir_20/jointpushpull_main.rb
                  no such file to load -- libtraductor.rb
                  Error Loading File jointpushpull.rb
                  no such file to load -- libtraductor.rb]
                  Edit to add: After clicking OK, I see an entry for the BezierSpline toolbar but when I enable that toolbar it is blank with only space for one button.
                  • F
                    fatboycakeshop
                    Hi. Im having the same issue. Done all of the above and still crashes after a few curves. Anything else I can try?
                    • nigel_edwardN
                      nigel_edward
                      Bloody well brilliant tool! Thank you so much! 👍 😍
                      • U
                        ukchoiceshops
                        I am struggling to work out how to install this onto my sketchup 8 system on a mac. any help would be much appreciated 😄
                        • mitcorbM
                          mitcorb
                          Hi, Ross:
                          Did you read the advice for Mac users on the first page of this topic?
                          Alternatively, have you considered using the Sketchucation Plugin Store tool?
                          http://sketchucation.com/resources/plugin-store-download
                          At the top of this page, there is a selection called Resources and in the drop down is the link to the download.
                          There may be some other issue, so post back for someone to assist.
                            aydee
                            Fantastic. I can finally get more segments and smooth bezier curves. Thank you!
                            • O
                              oli_sketch
                              Dear Fredo,
                              I got problems with Bezier spline 1.4f , when I use it sketchup 2013 always close it.
                              My OS is macos X 10.8.5 with sketchup 2013 (spanish) version 13.0.4811 on a MacBook Pro late 2 gh intel core i7
                              Can you help me.
                              Thank you and kind regards.
                              • B
                                BillyRX
                                @oli_sketch said:
                                Dear Fredo,
                                Can you help me.
                                What he said. Please. This used to be my most commonly used extension. 😞
                                • BoxB
                                  There have been updates to fredos plugins to work with SU2013, make sure you have the latest versions including Libfredo
                                  • B
                                    Beejeez
                                    I installed Bezierspline v1.4 on my mac computer in SU2013. I really like the possibilities of this plugin but the point is that SU crashes after inserting a few bezier points.
                                    I saw that this issue was discussed a few months ago by gig500 and dave R. Does anyone know if this problem is already solved?
                                    Thanks in advance
                                    • fredo6F
                                      NEW RELEASE 1.6a - 11 Nov 2013
                                      This release is for future Sketchup compatibility
                                      Download new release at main post
                                      • fredo6F
                                        NEW RELEASE 1.6b - 12 Nov 2013
                                        It also fixes some crashes encountered on some Mac OSX configuration and SU13.. Thanks to Dave R for helping me troubleshoot the issue.
                                          Makolee
                                          THX FOR THIS PLUGIN
                                          • gonashviliG
                                            gonashvili
                                            Hi there
                                            So I'm using this a lot, umm is there a way to 'disable' the initial [Uniform B-Spline] dialog (with the Order parameter), so it would stay at the default '0' / automatic, or whatever value [without the dialog]?
                                            Cheers
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
