    Rayscaper New Releases
    rayscaperrender
    743 Posts 14 Posters 312.6k Views 15 Watching
    • KrassK
      Krass
      Ah! Thomas, the ambient occlusion is perfect in version 0.9.92!
      Krass
      1 Reply Last reply ๐Ÿ‘
      • KrassK
        Krass
        Krass
        • pixelcruncherP
          Magnifique!
          • KrassK
            Krass
            Hello
            other Rayscaper render with D5 characters, but I should have changed the scale of the characters, which is messed up, but I'm too lazy.
            Krass
            • KrassK
              Krass
              Krass
                OK, for some reason the settings are set at USE GPU but the render window states CPU and the times are slow enough.
                  Considering that win dose is once again deleting files I am at odds as to what to do next. micro snot are less use than a pre used nasal tissue.
                  Reply Quote -1
                    Is there a preferred method of removing Rayscaper? Issues with the latest build have been impossible to recover from so far.
                      @pixelcruncher would be best placed to advise. Did you send him log files?
                        He is away for a week, a well earned break but he believes there is an issue with the latest build which he aims to fix when he gets back.
                        I got a new office chair today, supposedly good for bad backs.
                        If anyone suggests this, https://www.amazon.co.uk/dp/B0D2HB14FK?ref=ppx_yo2ov_dt_b_fed_asin_title
                        DON'T. More wobbly than a bathtub in the ocean.
                        Hence headache/backache etc. Jolly good fun. Actually I could give it a pass.
                        I had a notification of a noo Sketchup build, downloaded it and the only way forwards was repair or delete. Not much of anything working today and Maxwell which WAS working, off on hols too.
                          OK, after a LOT of faffing, it seems that .92 is being installed adjacent to .91 rather than over it.
                          I uninstalled .92 today and did a pc restart.
                          Rayscaper is still present.
                          Started to render to, on checking it is .91.
                          Also, not finding the graphics card so reverting to cpu rendering.
                            • pixelcruncherP
                              Hey, Rayscaper users!
                              Rayscaper 0.9.93 Beta is available. You can get it via:
                              • The SketchUcation store.
                              • Direct download: Rayscaper_Win_0.9.93_Beta.rbz.
                              I recommend upgrading to the latest version.
                              What Changed?
                              • Fix SketchUp tag visibility updates for nested groups and components. Nested geometry now appears and reappears correctly in Rayscaper when you toggle tags in SketchUp, matching the SketchUp viewport more reliably.
                              • Fix material picking when hidden or invisible objects sit in front of visible geometry. The picker now selects the material you clicked instead of the hidden object blocking it.
                              • Fix crashes after exploding SketchUp tag folders and then changing tag visibility.
                              • Improve viewport navigation and panel controls with a simpler pan/zoom path and a fixed panel layout.
                              Full release notes: rayscaper.com/manual/release-notes
                              Help Me Build the Community ๐Ÿ‘
                              If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
                              and helps me showcase its capabilities to new users.
                              Follow me on X.
                              Happy Rendering!
                              Thomas
                              • pixelcruncherP
                                Rayscaper users, a heads up: I accidentally uploaded the previous 0.9.92 version to the SketchUcation Extension Store. If you installed Rayscaper in the last 4 days, you may have reinstalled the previous version. (@mike-amos Thanks for the heads up!).
                                Iโ€™ve uploaded the latest 0.9.93 version now. If you download and install the extension again, it should install version 0.9.93 correctly.
                                Apologies for the hassle.
                                Happy Rendering!
                                Thomas
                                ntxdaveN 1 Reply Last reply
                                  No hassle, stuff happens remain chill mate.
                                    The new build is good, when hiding the 'assets' panel the progress bar is also lost. Not a major issue as when it comes to labelling the render, unhiding the assets is doable.
                                    It would be useful when progress is slow as a stalled render is not so obvious when the progress bar is hidden.
                                    • ntxdaveN
                                      ntxdave @pixelcruncher
                                      Happy Rendering!
                                      Thomas
                                      Is there a way within Rayscaper to update to the latest version? If not, is this something you could add to the ui?
                                      Press F1...thank me later
                                        On a few occasions I have downloaded the latest build and used the sketchup extension manager. This it what I have used for rollback to last version to check behaviour.
                                          Rich O Brien Moderator @ntxdave
                                          If you install extensions using Sketchucation Tools then it will prompt you to update. It has been that way for years.
                                          • KrassK
                                            Krass
                                            hello, I'm trying this new version but I get a bugg, It doens't want to render anymore. I get this error message
                                            I will send you my log file
                                            Krass
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 37
                                            • 38
                                            • 22 / 38
