    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.8k Views 14 Watching
    • KrassK
      Krass
      Hello,
      not yet, I still have this issue too, but I hide the unwanted geometry in the the scene
      Render with 0.9.91, post prod photoshop.
      But I really like the auto exposure settings, all this settings are great
      Krass
      1 Reply Last reply 👍
      • pixelcruncherP
        Nice render!
        @krass @sashapepperspray - I can reproduce the issue, I'm looking into it for the next release. I'm sorry for the delay!
          sashapepperspray
          okay, thank you
            Lightly tested this evening. Liking the auto exposure a lot.
            Reply Quote 2
            • pixelcruncherP
              Hey, Rayscaper users!
              Rayscaper 0.9.92 Beta is available as a hotfix release to fix asset thumbnail downloads failing in the asset library. I strongly recommend upgrading. You can get it via:
              • The SketchUcation store.
              • Direct download: Rayscaper_Win_0.9.92_Beta.rbz.
              What Changed?
              • Fix asset thumbnails occasionally failing to download in the asset library.
              • Fix AO Distance slider having no effect in standalone AO render method.
              Full release notes: rayscaper.com/manual/release-notes
              Help Me Build the Community 👍
              If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
              Follow me on X.
              Happy Rendering!
              Thomas
              • KrassK
                Krass
                you are too fast Pixelcruncher !
                I'm still using 0.9.91 for this photomontage
                render with Rayscaper 0.9.91, characters generated with D5 Lite and
                character’s outline using Photoshop. To be in tune with the times, I naturally put the man in charge of the kitchen.
                Krass
                • KrassK
                  Krass
                  Here, the same exercise, but the aim is to maintain consistency by keeping the points of view the same with the same characters.
                  Krass
                  • KrassK
                    Krass
                    1- So, a "consistency" test, meaning renderings from different viewpoints with the same characters. It's not perfect, but the method is to create two 3D renderings (here in Rayscaper) and place the image in SketchUp. Then, I ask D5 Render Lite's AI to add characters to the first viewpoint. I also give D5 the same image as a reference. Then, I take the least bad result and create a Photoshop montage.
                    2- To get the same characters from a different viewpoint, I place the new rendering with a new viewpoint in SketchUp and give D5 Lite my latest image with the characters. I then request the same characters in a different location.
                    Krass
                    • KrassK
                      Krass
                      Ah! Thomas, the ambient occlusion is perfect in version 0.9.92!
                      Krass
                      • KrassK
                        Krass
                        Krass
                        • pixelcruncherP
                          Magnifique!
                          • KrassK
                            Krass
                            Hello
                            other Rayscaper render with D5 characters, but I should have changed the scale of the characters, which is messed up, but I'm too lazy.
                            Krass
                            • KrassK
                              Krass
                              Krass
                                OK, for some reason the settings are set at USE GPU but the render window states CPU and the times are slow enough.
                                  Considering that win dose is once again deleting files I am at odds as to what to do next. micro snot are less use than a pre used nasal tissue.
                                  Reply Quote -1
                                    Is there a preferred method of removing Rayscaper? Issues with the latest build have been impossible to recover from so far.
                                      @pixelcruncher would be best placed to advise. Did you send him log files?
                                        He is away for a week, a well earned break but he believes there is an issue with the latest build which he aims to fix when he gets back.
                                        I got a new office chair today, supposedly good for bad backs.
                                        If anyone suggests this, https://www.amazon.co.uk/dp/B0D2HB14FK?ref=ppx_yo2ov_dt_b_fed_asin_title
                                        DON'T. More wobbly than a bathtub in the ocean.
                                        Hence headache/backache etc. Jolly good fun. Actually I could give it a pass.
                                        I had a notification of a noo Sketchup build, downloaded it and the only way forwards was repair or delete. Not much of anything working today and Maxwell which WAS working, off on hols too.
                                          OK, after a LOT of faffing, it seems that .92 is being installed adjacent to .91 rather than over it.
                                          I uninstalled .92 today and did a pc restart.
                                          Rayscaper is still present.
                                          Started to render to, on checking it is .91.
                                          Also, not finding the graphics card so reverting to cpu rendering.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 22 / 27
