    Rayscaper New Releases
    rayscaperrender
    460 Posts 12 Posters 81.5k Views 13 Watching
      pixelcruncher Extension Creator @Mike Amos
      @Mike-Amos If you don't like them, I can add a small feature to hide this panel so you can have more viewport?
        Yes please, the less visual clutter the better.
          Hey, Rayscaper users!
          Rayscaper 0.9.91 Beta is available. You can get it via:
          • The https://sketchucation.com/plugin/2677-rayscaper.
          • Direct download: https://rayscaper-releases.s3.amazonaws.com/SketchUp/Windows/Rayscaper_Win_0.9.91_Beta.rbz.
          I recommend upgrading to the latest version.
          What Changed?
          • Add tone mapping options β€” choose from ACES Filmic, Filmic (Hable), PBR Neutral, Linear, or Reinhard to control the look of your renders.
          • Add color grading controls β€” fine-tune renders with white balance temperature, tint, and contrast sliders.
          • Add auto-exposure β€” exposure now adjusts automatically to scene lighting, with a toolbar toggle and compensation slider.
          • Improve asset library reliability β€” fix occasional failures when browsing or downloading Poly Haven assets.
          Below screenshot shows the new post-processing capabilities:
          Full release notes: https://rayscaper.com/manual/release-notes/
          Help Me Build the Community πŸ‘
          If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its
          capabilities to new users.
          Follow me on https://x.com/rayscaper3d.
          Happy Rendering!
          Thomas
          KrassK 1 Reply Last reply Reply Quote 1
          • KrassK Offline
            Krass @pixelcruncher
            aaaah, je m'y mets tout de suite
            merci !
            Krass
              sashapepperspray @pixelcruncher
              @pixelcruncher Is there any update on the bug that if I have a group nested in a different group, that nested group is always visible even if it is on a tag that is turned off?
              • KrassK Offline
                Krass
                Hello,
                not yet, I still have this issue too, but I hide the unwanted geometry in the the scene
                Render with 0.9.91, post prod photoshop.
                But I really like the auto exposure settings, all this settings are great
                Krass
                  Nice render!
                  @krass @sashapepperspray - I can reproduce the issue, I'm looking into it for the next release. I'm sorry for the delay!
                    sashapepperspray
                    okay, thank you
                      Lightly tested this evening. Liking the auto exposure a lot.
                        Rayscaper 0.9.92 Beta is available as a hotfix release to fix asset thumbnail downloads failing in the asset library. I strongly recommend upgrading. You can get it via:
                        • The SketchUcation store.
                        • Direct download: Rayscaper_Win_0.9.92_Beta.rbz.
                        What Changed?
                        • Fix asset thumbnails occasionally failing to download in the asset library.
                        • Fix AO Distance slider having no effect in standalone AO render method.
                        Full release notes: rayscaper.com/manual/release-notes
                        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                        Follow me on X.
                        Happy Rendering!
                        Thomas
                        • KrassK Offline
                          Krass
                          you are too fast Pixelcruncher !
                          I'm still using 0.9.91 for this photomontage
                          render with Rayscaper 0.9.91, characters generated with D5 Lite and
                          character’s outline using Photoshop. To be in tune with the times, I naturally put the man in charge of the kitchen.
                          Krass
                          • KrassK Offline
                            Krass
                            Here, the same exercise, but the aim is to maintain consistency by keeping the points of view the same with the same characters.
                            Krass
                            • KrassK Offline
                              Krass
                              1- So, a "consistency" test, meaning renderings from different viewpoints with the same characters. It's not perfect, but the method is to create two 3D renderings (here in Rayscaper) and place the image in SketchUp. Then, I ask D5 Render Lite's AI to add characters to the first viewpoint. I also give D5 the same image as a reference. Then, I take the least bad result and create a Photoshop montage.
                              2- To get the same characters from a different viewpoint, I place the new rendering with a new viewpoint in SketchUp and give D5 Lite my latest image with the characters. I then request the same characters in a different location.
                              Krass
                              • KrassK Offline
                                Krass
                                Ah! Thomas, the ambient occlusion is perfect in version 0.9.92!
                                Krass
                                • KrassK Offline
                                  Krass
                                  Krass
                                    Magnifique!
                                    • KrassK Offline
                                      Krass
                                      Hello
                                      other Rayscaper render with D5 characters, but I should have changed the scale of the characters, which is messed up, but I'm too lazy.
                                      Krass
                                      • KrassK Offline
                                        Krass
                                        Krass
                                          OK, for some reason the settings are set at USE GPU but the render window states CPU and the times are slow enough.
                                            Considering that win dose is once again deleting files I am at odds as to what to do next. micro snot are less use than a pre used nasal tissue.
                                            1 Reply Last reply Reply Quote -1
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
