    Rayscaper New Releases
    rayscaperrender
    743 Posts 14 Posters 312.6k Views 15 Watching
    • KrassK
      Krass @pixelcruncher
      @pixelcruncher said:
      Add tone mapping options โ€” choose from ACES Filmic, Filmic (Hable), PBR Neutral, Linear, or Reinhard to control the look of your re
      aaaah, je m'y mets tout de suite
      merci !
      Krass
        sashapepperspray @pixelcruncher
        @pixelcruncher Is there any update on the bug that if I have a group nested in a different group, that nested group is always visible even if it is on a tag that is turned off?
        • KrassK
          Krass
          Hello,
          not yet, I still have this issue too, but I hide the unwanted geometry in the the scene
          Render with 0.9.91, post prod photoshop.
          But I really like the auto exposure settings, all this settings are great
          Krass
          1 Reply Last reply ๐Ÿ‘
          • pixelcruncherP
            Nice render!
            @krass @sashapepperspray - I can reproduce the issue, I'm looking into it for the next release. I'm sorry for the delay!
              sashapepperspray
              okay, thank you
                Lightly tested this evening. Liking the auto exposure a lot.
                Reply Quote 2
                • pixelcruncherP
                  Hey, Rayscaper users!
                  Rayscaper 0.9.92 Beta is available as a hotfix release to fix asset thumbnail downloads failing in the asset library. I strongly recommend upgrading. You can get it via:
                  • The SketchUcation store.
                  • Direct download: Rayscaper_Win_0.9.92_Beta.rbz.
                  What Changed?
                  • Fix asset thumbnails occasionally failing to download in the asset library.
                  • Fix AO Distance slider having no effect in standalone AO render method.
                  Full release notes: rayscaper.com/manual/release-notes
                  Help Me Build the Community ๐Ÿ‘
                  If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                  Follow me on X.
                  Happy Rendering!
                  Thomas
                  • KrassK
                    Krass
                    you are too fast Pixelcruncher !
                    I'm still using 0.9.91 for this photomontage
                    render with Rayscaper 0.9.91, characters generated with D5 Lite and
                    characterโ€™s outline using Photoshop. To be in tune with the times, I naturally put the man in charge of the kitchen.
                    Krass
                    • KrassK
                      Krass
                      Here, the same exercise, but the aim is to maintain consistency by keeping the points of view the same with the same characters.
                      Krass
                      • KrassK
                        Krass
                        1- So, a "consistency" test, meaning renderings from different viewpoints with the same characters. It's not perfect, but the method is to create two 3D renderings (here in Rayscaper) and place the image in SketchUp. Then, I ask D5 Render Lite's AI to add characters to the first viewpoint. I also give D5 the same image as a reference. Then, I take the least bad result and create a Photoshop montage.
                        2- To get the same characters from a different viewpoint, I place the new rendering with a new viewpoint in SketchUp and give D5 Lite my latest image with the characters. I then request the same characters in a different location.
                        Krass
                        • KrassK
                          Krass
                          Ah! Thomas, the ambient occlusion is perfect in version 0.9.92!
                          Krass
                          • KrassK
                            Krass
                            Krass
                            • pixelcruncherP
                              Magnifique!
                              • KrassK
                                Krass
                                Hello
                                other Rayscaper render with D5 characters, but I should have changed the scale of the characters, which is messed up, but I'm too lazy.
                                Krass
                                • KrassK
                                  Krass
                                  Krass
                                    OK, for some reason the settings are set at USE GPU but the render window states CPU and the times are slow enough.
                                      Considering that win dose is once again deleting files I am at odds as to what to do next. micro snot are less use than a pre used nasal tissue.
                                      Reply Quote -1
                                        Is there a preferred method of removing Rayscaper? Issues with the latest build have been impossible to recover from so far.
                                          @pixelcruncher would be best placed to advise. Did you send him log files?
                                            He is away for a week, a well earned break but he believes there is an issue with the latest build which he aims to fix when he gets back.
                                            I got a new office chair today, supposedly good for bad backs.
                                            If anyone suggests this, https://www.amazon.co.uk/dp/B0D2HB14FK?ref=ppx_yo2ov_dt_b_fed_asin_title
                                            DON'T. More wobbly than a bathtub in the ocean.
                                            Hence headache/backache etc. Jolly good fun. Actually I could give it a pass.
                                            I had a notification of a noo Sketchup build, downloaded it and the only way forwards was repair or delete. Not much of anything working today and Maxwell which WAS working, off on hols too.
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 37
                                            • 38
                                            • 22 / 38
