    Rayscaper New Releases
    rayscaperrender
    461 Posts 12 Posters 90.1k Views 13 Watching
    • KrassK Offline
      Krass
      Yes Thomas, I will send it to you tomorrow morning. I tried to reload it from Rayscaper and restart RS, but non way. But did not restart SU. Mau be it 'll work tomorrow. I m not homE now. Yes there was a triangle in front of the image slot
      Krass
        Alattab @Krass
        @Krass That's great! Could you please attach the SketchUp file, the Normal Map file, and a screenshot showing the settings you used in Rayscaper?
        KrassK 1 Reply Last reply Reply Quote 0
        • KrassK Offline
          Krass
          Hello yes, I will do it tomorrow. Remind it to me if I forget
          Krass
            @Krass These settings have no bearing on the animations that Rayscaper renders.
              pixelcruncher Extension Creator @Alattab
              @Alattab, I will have a look at this and maybe provide an installer. I'm not sure what happened here right now. Will get back to you.
              Thanks,
              Thomas
              • KrassK Offline
                Krass @pixelcruncher
                @pixelcruncher said in Rayscaper New Releases:
                THANKS
                Krass
                  pixelcruncher Extension Creator @pixelcruncher
                  @alattab
                  You can download an installer here: https://rayscaper-releases.s3.amazonaws.com/SketchUp/Windows/Rayscaper_Win_0.9.85_Beta_Setup.exe - Can you try using the installer to see if it works better for you?
                  Regards,
                  Thomas
                  A 1 Reply Last reply Reply Quote 0
                  • KrassK Offline
                    Krass
                    here is the scereen shot
                    and the log file was sent by email
                    Krass
                    • KrassK Offline
                      Krass @Alattab
                      @Alattab said in Rayscaper New Releases:
                      here is the file
                      https://we.tl/t-BUzHVyVojS
                      Krass
                      A 1 Reply Last reply Reply Quote 1
                        Alattab @pixelcruncher
                        @pixelcruncher it is work , thank you
                          Alattab @Krass
                          @Krass Thank you for your efforts.
                          • N Offline
                            NeilNovotny
                            I am trying to turn an image on a television into an emmiter. I thought I remember seeing that it was not possible in Rayscraper but I can't seem to find that thread again. Is that still the case? And if so, is that possibly something that could added in a future release? Right now I am adding that in post production, but it would be very handy if the feature could be done within Rayscraper.
                              I have not been able to replicate the effect yet.
                              • KrassK Offline
                                Krass
                                Hello, there is a tip to do that for a fixed picture : put an emissive plane a few centimeters behind your image then increase "transmission"
                                Krass
                                  Thanks for the tip/reminder.
                                    pixelcruncher Extension Creator @NeilNovotny
                                    @NeilNovotny We don't support texture emission yet, but it's on our feature list. For now, you can follow the tip @krass posted.
                                    Cheers,
                                    Thomas
                                    • N Offline
                                      NeilNovotny
                                      Excellent. And thank you for the help. After working with Twilight for so long, I am slowly working my way through Rayscraper.
                                        Hey, Rayscaper users!
                                        Rayscaper 0.9.87 Beta is available. You can get it via:
                                        • The SketchUcation store.
                                        • Direct download: Rayscaper_Win_0.9.87_Beta.rbz.
                                        I recommend upgrading to the latest version.
                                        What Changed?
                                        • Add tri-planar mapping support for textures. Materials can now use tri-planar projection instead of UV mapping, which avoids stretched textures on surfaces without proper UVs.
                                        • Automatically apply tri-planar mapping to PolyHaven materials when the model has no UVs. Downloaded materials now look correct out of the box without manual texture coordinate setup.
                                        • Sort the material list alphabetically to match SketchUp's material panel ordering.
                                        • Fix the Asset Manager sometimes getting stuck in a loading state when switching between assets quickly.
                                        • Fix color space detection for opacity and roughness textures. These textures now render correctly when using automatic color space detection.
                                        • Fix environment power slider feeling awkward near zero. The slider now smoothly blends to zero instead of snapping discontinuously at the far left.
                                        Full release notes: rayscaper.com/manual/release-notes
                                        Help Me Build the Community πŸ‘
                                        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                                        Follow me on X.
                                        Happy Rendering!
                                        Thomas
                                        • KrassK Offline
                                          Krass
                                          Thanks a lot Pixelcruncher, tri-planar mapping is great improvement !
                                          Krass
                                          • KrassK Offline
                                            Krass
                                            a small issue
                                            Krass
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 20 / 24
