    Rayscaper New Releases
    rayscaperrender
    744 Posts 14 Posters 317.8k Views 15 Watching
    • KrassK
      Krass @Alattab
      @Alattab said in Rayscaper New Releases:
      @Krass That's great! Could you please attach the SketchUp file, the Normal Map file, and a screenshot showing the settings you used in Rayscaper?
      here is the file
      https://we.tl/t-BUzHVyVojS
      Krass
      A 1 Reply Last reply
        Alattab @pixelcruncher
        @pixelcruncher it is work , thank you
        1 Reply Last reply πŸ‘
          Alattab @Krass
          @Krass Thank you for your efforts.
          Reply Quote 2
          • N
            NeilNovotny
            I am trying to turn an image on a television into an emmiter. I thought I remember seeing that it was not possible in Rayscraper but I can't seem to find that thread again. Is that still the case? And if so, is that possibly something that could added in a future release? Right now I am adding that in post production, but it would be very handy if the feature could be done within Rayscraper.
              I have not been able to replicate the effect yet.
              • KrassK
                Krass
                Hello, there is a tip to do that for a fixed picture : put an emissive plane a few centimeters behind your image then increase "transmission"
                Krass
                Reply Quote 2
                  Thanks for the tip/reminder.
                  • pixelcruncherP
                    pixelcruncher Extension Creator @NeilNovotny
                    @NeilNovotny We don't support texture emission yet, but it's on our feature list. For now, you can follow the tip @krass posted.
                    Cheers,
                    Thomas
                    • N
                      NeilNovotny
                      Excellent. And thank you for the help. After working with Twilight for so long, I am slowly working my way through Rayscraper.
                      • pixelcruncherP
                        Hey, Rayscaper users!
                        Rayscaper 0.9.87 Beta is available. You can get it via:
                        • The SketchUcation store.
                        • Direct download: Rayscaper_Win_0.9.87_Beta.rbz.
                        I recommend upgrading to the latest version.
                        What Changed?
                        • Add tri-planar mapping support for textures. Materials can now use tri-planar projection instead of UV mapping, which avoids stretched textures on surfaces without proper UVs.
                        • Automatically apply tri-planar mapping to PolyHaven materials when the model has no UVs. Downloaded materials now look correct out of the box without manual texture coordinate setup.
                        • Sort the material list alphabetically to match SketchUp's material panel ordering.
                        • Fix the Asset Manager sometimes getting stuck in a loading state when switching between assets quickly.
                        • Fix color space detection for opacity and roughness textures. These textures now render correctly when using automatic color space detection.
                        • Fix environment power slider feeling awkward near zero. The slider now smoothly blends to zero instead of snapping discontinuously at the far left.
                        Full release notes: rayscaper.com/manual/release-notes
                        Help Me Build the Community πŸ‘
                        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                        Follow me on X.
                        Happy Rendering!
                        Thomas
                        • KrassK
                          Krass
                          Thanks a lot Pixelcruncher, tri-planar mapping is great improvement !
                          Krass
                          • KrassK
                            Krass
                            a small issue
                            Krass
                            • KrassK
                              Krass
                              I just sent you my log file
                              Krass
                                IMHO, there is zero requirement to "Load assets" full stop. Perhaps instead, just have links to load what we need at the time. It gets in the way and for me has little in the way of voracity for the render in hand. Sorry, just my ten pence worth.
                                pixelcruncherP 2 Replies Last reply
                                • KrassK
                                  Krass
                                  I don't entirely agree, especially since the assets are only loaded as links... the thumbnails are loaded, unless I'm mistaken. It's very lightweight and convenient. On the contrary, I'd like to have a whole catalog of PBR materials like this one, without having to manually enter each map. The catalog is available, for example, at https://3dassets.one/?q=&license=any&sort=latest, but we're not going to ask Thomas to do that work again.
                                  Furthermore, the size and presentation of the materials is rarely done this well in a rendering program. Just take a look at V-Ray.
                                  Krass
                                  • pixelcruncherP
                                    @Krass Thanks for the log file, I'm looking into this.
                                    • pixelcruncherP
                                      pixelcruncher Extension Creator @Mike Amos
                                      This is only loading the thumbnails. Loading the actual assets, which can be several megabytes, is done on demand. I.e. why you drag & drop an asset on your scene.
                                      Having the assets at your fingertips is one of the reasons people like Rayscaper so much, so I'm not dropping that.
                                      Happy to support more asset providers, as long as they offer them as cc0. I don't have the funds to license assets to ship with Rayscaper.
                                      Cheers,
                                      Thomas
                                      • pixelcruncherP
                                        @Mike-Amos If you don't like them, I can add a small feature to hide this panel so you can have more viewport?
                                          Yes please, the less visual clutter the better.
                                          • pixelcruncherP
                                            Rayscaper 0.9.91 Beta is available. You can get it via:
                                            • The https://sketchucation.com/plugin/2677-rayscaper.
                                            • Direct download: https://rayscaper-releases.s3.amazonaws.com/SketchUp/Windows/Rayscaper_Win_0.9.91_Beta.rbz.
                                            What Changed?
                                            • Add tone mapping options β€” choose from ACES Filmic, Filmic (Hable), PBR Neutral, Linear, or Reinhard to control the look of your renders.
                                            • Add color grading controls β€” fine-tune renders with white balance temperature, tint, and contrast sliders.
                                            • Add auto-exposure β€” exposure now adjusts automatically to scene lighting, with a toolbar toggle and compensation slider.
                                            • Improve asset library reliability β€” fix occasional failures when browsing or downloading Poly Haven assets.
                                            Below screenshot shows the new post-processing capabilities:
                                            Full release notes: https://rayscaper.com/manual/release-notes/
                                            Follow me on https://x.com/rayscaper3d.
                                            Happy Rendering!
                                            Thomas
                                            KrassK 1 Reply Last reply
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 37
                                            • 38
                                            • 21 / 38
