    Rayscaper New Releases
    rayscaperrender
    462 Posts 12 Posters 187.0k Views 13 Watching
      Alattab @Krass
      @Krass That's great! Could you please attach the SketchUp file, the Normal Map file, and a screenshot showing the settings you used in Rayscaper?
      KrassK 1 Reply Last reply Reply Quote 0
      • KrassK Offline
        Krass
        Hello yes, I will do it tomorrow. Remind it to me if I forget
        Krass
          @Krass These settings have no bearing on the animations that Rayscaper renders.
            pixelcruncher Extension Creator @Alattab
            @Alattab, I will have a look at this and maybe provide an installer. I'm not sure what happened here right now. Will get back to you.
            Thanks,
            Thomas
            • KrassK Offline
              Krass @pixelcruncher
              @pixelcruncher said in Rayscaper New Releases:
              THANKS
              Krass
                pixelcruncher Extension Creator @pixelcruncher
                @alattab
                You can download an installer here: https://rayscaper-releases.s3.amazonaws.com/SketchUp/Windows/Rayscaper_Win_0.9.85_Beta_Setup.exe - Can you try using the installer to see if it works better for you?
                Regards,
                Thomas
                A 1 Reply Last reply Reply Quote 0
                • KrassK Offline
                  Krass
                  here is the scereen shot
                  and the log file was sent by email
                  Krass
                  • KrassK Offline
                    Krass @Alattab
                    @Alattab said in Rayscaper New Releases:
                    here is the file
                    https://we.tl/t-BUzHVyVojS
                    Krass
                    A 1 Reply Last reply Reply Quote 1
                      Alattab @pixelcruncher
                      @pixelcruncher it is work , thank you
                        Alattab @Krass
                        @Krass Thank you for your efforts.
                        • N Offline
                          NeilNovotny
                          I am trying to turn an image on a television into an emmiter. I thought I remember seeing that it was not possible in Rayscraper but I can't seem to find that thread again. Is that still the case? And if so, is that possibly something that could added in a future release? Right now I am adding that in post production, but it would be very handy if the feature could be done within Rayscraper.
                          • Mike AmosM Online
                            I have not been able to replicate the effect yet.
                            • KrassK Offline
                              Krass
                              Hello, there is a tip to do that for a fixed picture : put an emissive plane a few centimeters behind your image then increase "transmission"
                              Krass
                              • Mike AmosM Online
                                Thanks for the tip/reminder.
                                  pixelcruncher Extension Creator @NeilNovotny
                                  @NeilNovotny We don't support texture emission yet, but it's on our feature list. For now, you can follow the tip @krass posted.
                                  Cheers,
                                  Thomas
                                  • N Offline
                                    NeilNovotny
                                    Excellent. And thank you for the help. After working with Twilight for so long, I am slowly working my way through Rayscraper.
                                      Hey, Rayscaper users!
                                      Rayscaper 0.9.87 Beta is available. You can get it via:
                                      • The SketchUcation store.
                                      • Direct download: Rayscaper_Win_0.9.87_Beta.rbz.
                                      I recommend upgrading to the latest version.
                                      What Changed?
                                      • Add tri-planar mapping support for textures. Materials can now use tri-planar projection instead of UV mapping, which avoids stretched textures on surfaces without proper UVs.
                                      • Automatically apply tri-planar mapping to PolyHaven materials when the model has no UVs. Downloaded materials now look correct out of the box without manual texture coordinate setup.
                                      • Sort the material list alphabetically to match SketchUp's material panel ordering.
                                      • Fix the Asset Manager sometimes getting stuck in a loading state when switching between assets quickly.
                                      • Fix color space detection for opacity and roughness textures. These textures now render correctly when using automatic color space detection.
                                      • Fix environment power slider feeling awkward near zero. The slider now smoothly blends to zero instead of snapping discontinuously at the far left.
                                      Full release notes: rayscaper.com/manual/release-notes
                                      Help Me Build the Community πŸ‘
                                      If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                                      Follow me on X.
                                      Happy Rendering!
                                      Thomas
                                      • KrassK Offline
                                        Krass
                                        Thanks a lot Pixelcruncher, tri-planar mapping is great improvement !
                                        Krass
                                        • KrassK Offline
                                          Krass
                                          a small issue
                                          Krass
                                          • KrassK Offline
                                            Krass
                                            I just sent you my log file
                                            Krass
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 21 / 24
