    Rayscaper New Releases
    rayscaperrender
    791 Posts 14 Posters 369.4k Views 15 Watching
    • pixelcruncherP
      pixelcruncher Extension Creator @pixelcruncher
      @alattab
      You can download an installer here: https://rayscaper-releases.s3.amazonaws.com/SketchUp/Windows/Rayscaper_Win_0.9.85_Beta_Setup.exe - Can you try using the installer to see if it works better for you?
      Regards,
      Thomas
      A 1 Reply Last reply
      • KrassK
        Krass
        here is the scereen shot
        and the log file was sent by email
        Krass
        • KrassK
          Krass @Alattab
          @Alattab said in Rayscaper New Releases:
          @Krass That's great! Could you please attach the SketchUp file, the Normal Map file, and a screenshot showing the settings you used in Rayscaper?
          here is the file
          https://we.tl/t-BUzHVyVojS
          Krass
            Alattab @pixelcruncher
            @pixelcruncher it is work , thank you
            1 Reply Last reply πŸ‘
              Alattab @Krass
              @Krass Thank you for your efforts.
              Reply Quote 2
              • N
                NeilNovotny
                I am trying to turn an image on a television into an emmiter. I thought I remember seeing that it was not possible in Rayscraper but I can't seem to find that thread again. Is that still the case? And if so, is that possibly something that could added in a future release? Right now I am adding that in post production, but it would be very handy if the feature could be done within Rayscraper.
                  I have not been able to replicate the effect yet.
                  • KrassK
                    Krass
                    Hello, there is a tip to do that for a fixed picture : put an emissive plane a few centimeters behind your image then increase "transmission"
                    Krass
                    Reply Quote 2
                      Thanks for the tip/reminder.
                      • pixelcruncherP
                        pixelcruncher Extension Creator @NeilNovotny
                        @NeilNovotny We don't support texture emission yet, but it's on our feature list. For now, you can follow the tip @krass posted.
                        Cheers,
                        Thomas
                        • N
                          NeilNovotny
                          Excellent. And thank you for the help. After working with Twilight for so long, I am slowly working my way through Rayscraper.
                          • pixelcruncherP
                            Hey, Rayscaper users!
                            Rayscaper 0.9.87 Beta is available. You can get it via:
                            • The SketchUcation store.
                            • Direct download: Rayscaper_Win_0.9.87_Beta.rbz.
                            I recommend upgrading to the latest version.
                            What Changed?
                            • Add tri-planar mapping support for textures. Materials can now use tri-planar projection instead of UV mapping, which avoids stretched textures on surfaces without proper UVs.
                            • Automatically apply tri-planar mapping to PolyHaven materials when the model has no UVs. Downloaded materials now look correct out of the box without manual texture coordinate setup.
                            • Sort the material list alphabetically to match SketchUp's material panel ordering.
                            • Fix the Asset Manager sometimes getting stuck in a loading state when switching between assets quickly.
                            • Fix color space detection for opacity and roughness textures. These textures now render correctly when using automatic color space detection.
                            • Fix environment power slider feeling awkward near zero. The slider now smoothly blends to zero instead of snapping discontinuously at the far left.
                            Full release notes: rayscaper.com/manual/release-notes
                            Help Me Build the Community πŸ‘
                            If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                            Follow me on X.
                            Happy Rendering!
                            Thomas
                            • KrassK
                              Krass
                              Thanks a lot Pixelcruncher, tri-planar mapping is great improvement !
                              Krass
                              • KrassK
                                Krass
                                a small issue
                                Krass
                                • KrassK
                                  Krass
                                  I just sent you my log file
                                  Krass
                                    IMHO, there is zero requirement to "Load assets" full stop. Perhaps instead, just have links to load what we need at the time. It gets in the way and for me has little in the way of voracity for the render in hand. Sorry, just my ten pence worth.
                                    pixelcruncherP 2 Replies Last reply
                                    • KrassK
                                      Krass
                                      I don't entirely agree, especially since the assets are only loaded as links... the thumbnails are loaded, unless I'm mistaken. It's very lightweight and convenient. On the contrary, I'd like to have a whole catalog of PBR materials like this one, without having to manually enter each map. The catalog is available, for example, at https://3dassets.one/?q=&license=any&sort=latest, but we're not going to ask Thomas to do that work again.
                                      Furthermore, the size and presentation of the materials is rarely done this well in a rendering program. Just take a look at V-Ray.
                                      Krass
                                      • pixelcruncherP
                                        @Krass Thanks for the log file, I'm looking into this.
                                        • pixelcruncherP
                                          pixelcruncher Extension Creator @Mike Amos
                                          This is only loading the thumbnails. Loading the actual assets, which can be several megabytes, is done on demand. I.e. why you drag & drop an asset on your scene.
                                          Having the assets at your fingertips is one of the reasons people like Rayscaper so much, so I'm not dropping that.
                                          Happy to support more asset providers, as long as they offer them as cc0. I don't have the funds to license assets to ship with Rayscaper.
                                          Cheers,
                                          Thomas
                                          • pixelcruncherP
                                            @Mike-Amos If you don't like them, I can add a small feature to hide this panel so you can have more viewport?
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 39
                                            • 40
                                            • 21 / 40
