    Rayscaper New Releases
    rayscaperrender
    466 Posts 12 Posters 207.0k Views 13 Watching
      @Krass These settings have no bearing on the animations that Rayscaper renders.
      KrassK 1 Reply Last reply Reply Quote 0
        pixelcruncher Extension Creator @Alattab
        @Alattab, I will have a look at this and maybe provide an installer. I'm not sure what happened here right now. Will get back to you.
        Thanks,
        Thomas
        • KrassK Offline
          Krass @pixelcruncher
          @pixelcruncher said in Rayscaper New Releases:
          THANKS
          Krass
            pixelcruncher Extension Creator @pixelcruncher
            @alattab
            You can download an installer here: https://rayscaper-releases.s3.amazonaws.com/SketchUp/Windows/Rayscaper_Win_0.9.85_Beta_Setup.exe - Can you try using the installer to see if it works better for you?
            Regards,
            Thomas
            A 1 Reply Last reply Reply Quote 0
            • KrassK Offline
              Krass
              here is the scereen shot
              and the log file was sent by email
              Krass
              • KrassK Offline
                Krass @Alattab
                @Alattab said in Rayscaper New Releases:
                @Krass That's great! Could you please attach the SketchUp file, the Normal Map file, and a screenshot showing the settings you used in Rayscaper?
                here is the file
                https://we.tl/t-BUzHVyVojS
                Krass
                A 1 Reply Last reply Reply Quote 1
                  Alattab @pixelcruncher
                  @pixelcruncher it is work , thank you
                    Alattab @Krass
                    @Krass Thank you for your efforts.
                    • N Offline
                      NeilNovotny
                      I am trying to turn an image on a television into an emmiter. I thought I remember seeing that it was not possible in Rayscraper but I can't seem to find that thread again. Is that still the case? And if so, is that possibly something that could added in a future release? Right now I am adding that in post production, but it would be very handy if the feature could be done within Rayscraper.
                        I have not been able to replicate the effect yet.
                        • KrassK Offline
                          Krass
                          Hello, there is a tip to do that for a fixed picture : put an emissive plane a few centimeters behind your image then increase "transmission"
                          Krass
                            Thanks for the tip/reminder.
                              pixelcruncher Extension Creator @NeilNovotny
                              @NeilNovotny We don't support texture emission yet, but it's on our feature list. For now, you can follow the tip @krass posted.
                              Cheers,
                              Thomas
                              • N Offline
                                NeilNovotny
                                Excellent. And thank you for the help. After working with Twilight for so long, I am slowly working my way through Rayscraper.
                                  Hey, Rayscaper users!
                                  Rayscaper 0.9.87 Beta is available. You can get it via:
                                  • The SketchUcation store.
                                  • Direct download: Rayscaper_Win_0.9.87_Beta.rbz.
                                  I recommend upgrading to the latest version.
                                  What Changed?
                                  • Add tri-planar mapping support for textures. Materials can now use tri-planar projection instead of UV mapping, which avoids stretched textures on surfaces without proper UVs.
                                  • Automatically apply tri-planar mapping to PolyHaven materials when the model has no UVs. Downloaded materials now look correct out of the box without manual texture coordinate setup.
                                  • Sort the material list alphabetically to match SketchUp's material panel ordering.
                                  • Fix the Asset Manager sometimes getting stuck in a loading state when switching between assets quickly.
                                  • Fix color space detection for opacity and roughness textures. These textures now render correctly when using automatic color space detection.
                                  • Fix environment power slider feeling awkward near zero. The slider now smoothly blends to zero instead of snapping discontinuously at the far left.
                                  Full release notes: rayscaper.com/manual/release-notes
                                  Help Me Build the Community πŸ‘
                                  If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and helps me showcase its capabilities to new users.
                                  Follow me on X.
                                  Happy Rendering!
                                  Thomas
                                  • KrassK Offline
                                    Krass
                                    Thanks a lot Pixelcruncher, tri-planar mapping is great improvement !
                                    Krass
                                    • KrassK Offline
                                      Krass
                                      a small issue
                                      Krass
                                      • KrassK Offline
                                        Krass
                                        I just sent you my log file
                                        Krass
                                          IMHO, there is zero requirement to "Load assets" full stop. Perhaps instead, just have links to load what we need at the time. It gets in the way and for me has little in the way of voracity for the render in hand. Sorry, just my ten pence worth.
                                          P 2 Replies Last reply Reply Quote 0
                                          • KrassK Offline
                                            Krass
                                            I don't entirely agree, especially since the assets are only loaded as links... the thumbnails are loaded, unless I'm mistaken. It's very lightweight and convenient. On the contrary, I'd like to have a whole catalog of PBR materials like this one, without having to manually enter each map. The catalog is available, for example, at https://3dassets.one/?q=&license=any&sort=latest, but we're not going to ask Thomas to do that work again.
                                            Furthermore, the size and presentation of the materials is rarely done this well in a rendering program. Just take a look at V-Ray.
                                            Krass
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 21 / 24
